Dip stick tube doesn't fit
Discussion in '1st Gen. Tacomas (1995-2004)' started by mech160, Aug 1, 2020.
  1. Aug 1, 2020 at 11:11 AM
    mech160
    mech160 [OP] Well-Known Member
    50th
    1995.5 Tacoma
    Hello all, I just replaced my front timing chain cover on my 1995 2.4 2RZ FE with what I thought was a direct replacement. However, my original engine oil dipstick tube is too large for the hole that is machined in the new front cover. Would anyone know what year Taco dipstick tube went to a small diameter?
    Thanks in advance!
  2. Aug 1, 2020 at 11:19 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Around here you better watch that kind of language these guys are brutal on here! :boink:
    tcjacado likes this.
  3. Aug 1, 2020 at 11:44 AM
    mech160
    50th
    1995.5 Tacoma
    Haha, good point!!!
  4. Aug 1, 2020 at 9:06 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The timing cover (and therefore the dipstick tube bore size on the timing cover) is the same for 1995-2004. I suspect you probably just don't have the union installed that fits between the dipstick tube and the timing cover.
    Dipstick Tube Union:
    90405-10016 - 1995 - 02/1999
    11459-70010 - 02/1999 - 2004
    Jeff
    Langing and Black DOG Lila like this.
  5. Aug 2, 2020 at 12:45 AM
    mech160
    50th
    1995.5 Tacoma
    Thank you Jeff!
  6. Sep 18, 2023 at 5:37 PM
    Langing
    Langing Well-Known Member
    Bill
    Durham, NC
    2000 Blue Tacoma Regular Cab 2.4L 2RZ-FE 2WD MT
    Camper on back
    Hey Jeff, I just read a comment you made on
    I am replacing the timing chain cover on my 2000 Tacoma 2.4L 2WD with a nice aftermarket one I bought on PartSouq.com (Mfr. YSK) for less than $200. It came with an oil pump and oil pressure relief valve already installed, and seems to be a very well made cast aluminum part, looking almost identical to the original. Have been transferring studs and water fittings, adding new thermostat, etc. Then I ran into a problem.
    There is a round steel fitting pressed into a bore on the front of the aluminum timing cover, and that steel fitting accepts the dipstick tube. I am having difficulty removing it to move it over to the new cover. I believe you were likely talking about this particular part in the quoted comment.
    My question is how do I remove that "union" and press it into the new timing cover, or do I need to purchase a new union, and if I need to do that, how do I press it into the bore on the cover? Do I just hammer it home? Since you knew the part numbers and dates of production of that part, I figured that you would be the best person to ask.
    Thank you ahead for any help you might provide.
    Bill
