Dipstick is impossible to read accurately
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NightRideSr5, Oct 7, 2019.
  1. Dec 11, 2019 at 8:07 PM
    #41
    Tacomike18
    Tacomike18 Well-Known Member
    J
    After every oil change, it is very difficult to read the oil level. I just put 6 qts and close it and done. I use Mobil 1 0-20 full syn and its so clear like water on the dipstick.
  2. Dec 11, 2019 at 8:15 PM
    #42
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Mine is a bear to slide back in. I've had engines that are a bit difficult to read with new oil, but none as stupid as this wet noodle.
    Junkhead likes this.
  3. Dec 11, 2019 at 8:21 PM
    #43
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Mid 80's v-8 Van transmission dipstick, like 5 feet long, goes around like 3 bends, total BITCH to put back in.....
  4. Dec 11, 2019 at 8:29 PM
    #44
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    At least the Tacoma has a dipstick. My wife's BMW X1 doesn't. Everything is digital. The really bad part is that the computer only tells you when you are low on oil and need to add more. It will not show overfill, it just reads full once the oil capacity reaches the required level.
  5. Dec 11, 2019 at 8:34 PM
    #45
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I will be sanding my dipstick in the morning...
    shakerhood and GreyBaldTaco like this.
  6. Dec 26, 2019 at 6:40 PM
    #46
    Ike H-mope
    Ike H-mope Well-Known Member
    Good tips in this thread for an oil-changing novice. Thanks.
    Scuffed my dipstick with a scotchbright sponge for an oil change today. Made a difference in readability, though the transparent oil was still difficult. Only one side of the stick made sense, I assume because of rubbing on the way out (I waited between dips). I oriented "bumps facing the engine" as someone here put it, and only read the indented side.
    I then watched a quart or so of oil gush out my filter housing when starting the truck because I put the O-ring in the wrong notch, but that's a different story. I knew better.
    Skydvrr, GreyBaldTaco and Junkhead like this.
  7. Dec 26, 2019 at 8:18 PM
    #47
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I run used diesel engine oil in my engine. High contrast, easy to read.
    Bleep100, Skydvrr and Pb12in like this.
  8. Dec 26, 2019 at 8:24 PM
    #48
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    They make diesel 0w20?
  9. Dec 26, 2019 at 8:38 PM
    #49
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    Even the wind shield washer fluid can has no level indicator. Or if it did, after 3.5 years of use, that really wore off. Today I was trying to fill mine up and I had no idea where to stop at. I looked really hard and could find nothing.
  10. Dec 26, 2019 at 8:47 PM
    #50
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    On my truck the container is opaque. I can clearly see the level just by looking at the side. At the very least I would put a flashlight on the side of it and the fluid level will cast a shadow and show the level.
    Skydvrr likes this.
  11. Dec 26, 2019 at 8:53 PM
    #51
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    If u get 15w-40 and run it for 11,111 miles, when you drain it, it is EXACTLY 0W-20
  12. Dec 26, 2019 at 8:53 PM
    #52
    Skydvrr
    Nick
    YMH
    Black '17 OR
    From empty, she'll take almost exactly a gallon of fluid.
    Speedfreak[QUOTED] likes this.
  13. Dec 26, 2019 at 8:54 PM
    #53
    bacon_st
    San Diego
    16' Taco TRD sport
    @Speedfreak !!, omg you replied :eek:. I was actually thinking of you earlier today and thought of messaging you and driving over to see you about my truck. This is a total surprise. We haven't met, but I wanted your help and advice. I want to go under my truck and bang somethings to place and put my spare tire back down there. Do you have a brass hammer? I was thinking who can I ask for help for such a type of work and thought only you could do that. I wouldn't mind driving up to Vista.
  14. Dec 26, 2019 at 8:57 PM
    #54
    bacon_st
    San Diego
    16' Taco TRD sport
    The problem on mine is, my once opaque container is now all white. I was in the engine bay shining my cellphone light trying to find a marker or a line and I couldn't see anything. I don't know why won't toyota design these things properly.
  15. Dec 26, 2019 at 9:00 PM
    #55
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Mad math skills man...
  16. Dec 26, 2019 at 9:04 PM
    #56
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    You might have the wrong person. I live a little bit north of Vista.
    GreyBaldTaco likes this.
  17. Dec 26, 2019 at 9:04 PM
    #57
    Tripod1404
    Tripod1404 Annihilator tripod
    I read mine after the truck sits overnight. It is not an accurate way of measuring the oil since 0W-20 oil expands when hot, but you dont need extreme precision with oil level anyway. It just needs to be within a certain range. if the oil level is between the range when cold, it will be between the range when hot as well (unless it shows max when cold). In my case cold oil fills 7/8 of the range while hot oil fills 8/8.
  18. Dec 26, 2019 at 9:07 PM
    #58
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    They try .
    Skydvrr likes this.
  19. Dec 26, 2019 at 9:13 PM
    #59
    bacon_st
    San Diego
    16' Taco TRD sport
    Maybe I did :confused:. Are you the guy who does welding and some machining work for folks in about SD and North county? Somebody mentioned your username to me.
  20. Dec 26, 2019 at 9:31 PM
    #60
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    No, not me there are 2 others with similar names in the forum.
    bacon_st[QUOTED] likes this.
