Dipstick is impossible to read accurately
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NightRideSr5, Oct 7, 2019.
  1. Dec 26, 2019 at 10:58 PM
    #61
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just don't forget to carry the 2.
    StayinStock and hiPSI[QUOTED] like this.
  2. Dec 27, 2019 at 2:22 AM
    #62
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Pull the stick out, let the oil in the tube drain for 5 min, reinsert the dipstick and check again. Look at the stick from an angle and you'll be able to see the oil. Or you can take the stick and lay it flat on a piece of paper and check the level that way.
  3. Dec 27, 2019 at 5:53 AM
    #63
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Rubber band a piece of paper towel around the end of the dip stick. Problem solved.
  4. Nov 10, 2023 at 11:23 AM
    #64
    blairrad
    blairrad Yoter
    Missouri
    based
  5. Nov 10, 2023 at 11:31 AM
    #65
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Operator error.
  6. Nov 10, 2023 at 11:38 AM
    #66
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Yikes, nearly 4 years between posts.
    Zombie thread!
    wilcam47, JmsWms and Pablo8 like this.
  7. Nov 10, 2023 at 12:09 PM
    #67
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    Don't overthink it man, even I could not feck this one up.
  8. Nov 10, 2023 at 12:34 PM
    #68
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Were is this random dipstick you talk of???
  9. Nov 10, 2023 at 1:41 PM
    #69
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    This ain’t rocket science……..
    wilcam47 likes this.
  10. Nov 10, 2023 at 1:43 PM
    #70
    PNW AV8R
    PNW AV8R Active Member
    Eugene, OR
    23' TRD SPORT
    pretty stock
    does anyone know where I can get a longer dipstick? mines not reaching the oil anymore...
    Tacosha, wilcam47, Cushmaat and 2 others like this.
  11. Nov 10, 2023 at 4:13 PM
    #71
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    It’s not the length it’s the flopping around of the Gen 3 dipstick
  12. Nov 10, 2023 at 6:45 PM
    #72
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    I hear the Honda Ridgeline dipstick is a perfect fit for your usage.
  13. Nov 10, 2023 at 6:50 PM
    #73
    Ffej
    Ffej Well-Known Member
    Evergreen, Colorado
    '22 TRD OR DCSB
    Bed mat
    Ridged for your pleasure
    Cushmaat[QUOTED] likes this.
  14. Nov 10, 2023 at 6:59 PM
    #74
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    If you have premium JBL audio, you also get a premium dipstick
  15. Nov 10, 2023 at 7:06 PM
    #75
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Ridgeline is a receiver
  16. Nov 10, 2023 at 7:08 PM
    #76
    Cushmaat
    SE AZ
    Yup...that is why it likes a longer dipstick to reach the good stuff.
    Pablo8[QUOTED] likes this.
  17. Nov 10, 2023 at 7:18 PM
    #77
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    4th Gen will have a glass engine block so the mechanically challenged can see the oil level in Fluid ounces
  18. Nov 10, 2023 at 7:26 PM
    #78
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    MGMDesertTaco and arthur106 like this.
  19. Nov 10, 2023 at 7:38 PM
    #79
    arthur106
    arthur106 Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    I haven't read through all four pages, so not sure if someone else has said it... remove and clean the dipstic, wait about 10 minutes, THEN INSERT the dipstick for a better reading. I had the same issue as you and this worked for me. I also remove the oil filler cap while waiting.
    The idea is that you're venting the oil system to atmosphere allowing for better free movement of oil.
  20. Aug 25, 2024 at 3:22 PM
    #80
    JoeCa
    JoeCa New Member
    I was struggling with this for days...I think the key is "I also remove the oil filler cap while waiting." After waiting 10 minutes without the filler cap, the dipstick was easy to read and the reading was the same on both sides of the dipstick....I've had over 10 vehicles in my lifetime and this is the first time I needed to wait 10 minutes and remove the filler cap....My truck is a 2020 Tacoma.
