Dirt Designs 05+ Taco 4WD RACE kit
Discussion in 'Long Travel Suspension' started by dirt designs, Jun 28, 2013.
  1. Jul 2, 2013 at 9:09 PM
    dirt designs
    dirt designs [OP] Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Thanks everyone. It should work out well
    The spindles do not add any to the overall width like a 2wd lift spindle. So its a total 3.5" per side.
    The tabs? Or the uniballs? The uniballs are high strength 1in. Same as most kits out, even on some TTs. And Ive had similar tab layouts that ive built on other vehicles with other kits. Itll be all bueno
    Price will be around $4-4500 for upper arms, lower arms, spindles, heimed steering, and all necessary parts (minus shocks and glass)
  2. Jul 3, 2013 at 9:57 PM
    dirt designs
    slo
    Not as many pics as i hoped, but I will hopefully have shocks and steering clevis' friday
    Kit cycles 14.5 from inner fender to cv bind (will be bumped and strapped right around 14). The shock will be setup to cycle the suspenison up past the inner fender by 2-2.5in so if joel ever decides to remove them, he can run around 16" of travel
    There will be some sheetmetal massaging to fit a 35in tire at full bump and crank. We should be able to just roll over the weld seam and that should be the clearance we need.
  3. Jul 3, 2013 at 10:03 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    Badass...is your first gen linked?
    Looking forward to the test run videos. Way to put worth the effort and design that 4wd spindle.
  4. Jul 3, 2013 at 10:50 PM
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    Hmm I like.. Need to start saving :D
  5. Jul 5, 2013 at 10:55 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    This looks nice.
  6. Jul 6, 2013 at 12:11 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total chaos UCA's, icon coils, deaver leaf pack with icon resi's
    Subbd
  7. Jul 6, 2013 at 2:12 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I'm diggin the fact that there isn't too much camber change
  8. Jul 6, 2013 at 3:01 PM
    6spd
    6spd Well-Known Member
    san diego
    2012 4x4
    option for heimed uppers?
  9. Jul 6, 2013 at 10:40 PM
    dirt designs
    slo
    yessir and thank you
    Definitely should be
  10. Jul 8, 2013 at 1:23 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black, it has a Volat Cold air Intake, 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a gold rings! brush bar with 4 LightForce 170 strikers, Custom rear Bumper, Straight Pipe. HID 6000k Hi/Low, and HID 6000k fog lights, Tinted rear tail lights! Flat Black Interior! 2 12" subs with custom box made by me and a 1300 watt amp!
    subbed
  11. Jul 8, 2013 at 7:21 PM
    dirt designs
    slo
    Sure.
    Ive been welding up parts so its getting closer to better pics. Both uprights, ucas, and one lca are done. Tomorrow im going to be setting up the steering and shocks
  12. Jul 8, 2013 at 7:47 PM
    SoCalTacos
    socal
    Do those spindles add any sort of lift? Is that even possible with 4wd spindles?
  13. Jul 8, 2013 at 7:53 PM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    13 Taco Double Cab TRD
    Bilstein 5100's all around, front set at 2.5", Toytec AAL, 265/75/16 Duratracs, Pro Comp 5001, Weathertech's, AVS In Channel Visors, Nokya Hyper Yellow fogs, CB Set up, Color matched grill surround, ATC Camper Shell with Yakima Racks, SOS Concepts Regular Rear Bumper.
  14. Jul 8, 2013 at 8:09 PM
    6spd
    san diego
    2012 4x4
    looking thick, solid, tight. I wouldnt even want anymore lift with an LT kit. 2nd aftermarket 4x4 beefy spindle(to solo motosports) available.
  15. Jul 8, 2013 at 8:30 PM
    #35
    cummins6speed
    Not possible with 4wd
  16. Jul 8, 2013 at 8:32 PM
    #36
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    hahahahaha
  17. Jul 8, 2013 at 10:40 PM
    #37
    dirt designs
    slo
    Yep you are correct. This is the first spindle that uses stock hubs, brakes, speed sensors, and cv joints.
  18. Jul 9, 2013 at 9:08 PM
    #38
    dirt designs
    slo
    pass side
    driver side
    needs some steering
  19. Jul 9, 2013 at 9:21 PM
    #39
    6spd
    san diego
    2012 4x4
    good selling point. :cool:
    would def be interested once the money falls from the sky :eek:
  20. Jul 9, 2013 at 9:43 PM
    #40
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    this is some pretty impressive stuff. :popcorn:
