dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Sep 16, 2018 at 8:57 PM
    #7221
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Something isn't right. Need help now please!
    Almost like it's stuck in gear. When truck is off, I can select gears without the clutch pressed, or pressed. Have to press the clutch to start, but then won't get into a gear. When I try and get 2nd I feel the truck try and lurch forward, 1st won't go in at all, reverse tries but grinds.
    What isn't disengaging with the clutch? Followed directions to a T, too. Work tomorrow morning.
  2. Sep 16, 2018 at 9:18 PM
    #7222
    dirty deeds
    Nick
    Eastern KY
    BTW, I just replaced the clutch, pressure plate, TOB, and pilot bearing.
  3. Sep 16, 2018 at 9:28 PM
    #7223
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Have you tried to adjust the pedal throw? I dont think you're fully engaging the clutch. I'm just spit balling here
  4. Sep 16, 2018 at 9:28 PM
    #7224
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Interesting. I've not much experiendo with this, brochacho...
    dirty deeds[OP] likes this.
  5. Sep 16, 2018 at 9:30 PM
    #7225
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Did you bleed the clutch? Or does your pedal have an adjustment? Maybe it's not engaging the clutch fully when the pedal is all the way down.
    Just throwing out ideas, idk
  6. Sep 16, 2018 at 9:30 PM
    #7226
    beertimecontinuum
    Everett
    True, if it were adjusted to worn- ass clutch he may have to adjust it out.
    dirty deeds[OP] and Justinogo like this.
  7. Sep 16, 2018 at 9:34 PM
    #7227
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    What he said
  8. Sep 16, 2018 at 9:35 PM
    #7228
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  9. Sep 16, 2018 at 9:52 PM
    #7229
    dirty deeds
    Nick
    Eastern KY
    Thought that too. Adjusted what could be, then crawled under and let the girlfriend push the clutch, full travel.
  10. Sep 16, 2018 at 9:53 PM
    #7230
    dirty deeds
    Nick
    Eastern KY
    I did forget to bleed. I'll try in the AM.
    Already told work to eat one, I'm not coming in unless I fix it well before noon.
    Justinogo[QUOTED] likes this.
  11. Sep 16, 2018 at 9:55 PM
    #7231
    dirty deeds
    Nick
    Eastern KY
    beertimecontinuum likes this.
  12. Sep 16, 2018 at 9:55 PM
    #7232
    beertimecontinuum
    Everett
    Just bang em in there, you dont need a clutch. Or brakes. Seatbelts are good.
    rngr, Justinogo and dirty deeds[OP] like this.
  13. Sep 16, 2018 at 9:57 PM
    #7233
    dirty deeds
    Nick
    Eastern KY
    Not gonna lie, tried. Then saw myself going through the back wall of the garage. Reverse grinds like hell, can't even back out the garage.
  14. Sep 17, 2018 at 7:26 AM
    #7234
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Are you absolutely certain the clutch disc isn't in "backwards"? (Reversed) They will not disengage completely and will do exactly what you describe. Easy to do.... fixed a friends dorF stRanger a few years back following a new clutch. Did same EXACT thing you describe.
  15. Sep 17, 2018 at 7:32 AM
    #7235
    dirty deeds
    Nick
    Eastern KY
    100% certain it's on the right way, per LCEs directions and labels on the clutch disc
  16. Sep 17, 2018 at 7:36 AM
    #7236
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Good that they tag the disc now days. Didnt always happen that way.
    Also....new pilot bearing can sometime be a pain in the rectum....can drag and continue to "power" input shaft with clutch depressed/disengaged
  17. Sep 17, 2018 at 7:53 AM
    #7237
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    That was my initial gut reaction too.
  18. Sep 17, 2018 at 7:59 AM
    #7238
    dirty deeds
    Nick
    Eastern KY
    Working on bleeding the clutch now. Starting to look like it's all gonna have to come apart again...
  19. Sep 17, 2018 at 8:15 AM
    #7239
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Also....check orientation and install of throwout bearing.
  20. Sep 17, 2018 at 8:45 AM
    #7240
    dirty deeds
    Nick
    Eastern KY
    Gotta do the above to do that. But, I'll see if I can peek through the fork dust boot.
    Guess I might as well start removing driveshafts, bolts, and connectors. Fuck
