Dirty Trans Fluid- Am I screwed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jking3002, Sep 3, 2011.
  1. Sep 3, 2011 at 6:40 AM
    jking3002
    jking3002 [OP] Well-Known Member
    Jonathan
    Kentucky
    Scion tC
    Ricer muffler, window tent, trd shift knob.
    Check the trans fluid today it was a medium brown color with almost no hint of red in it... Vehicle is a 00 3.4 with 110K on the clock. I have noticed some rough shifting into certain gears...
    What is the best course of action to take-
    1.) Taking it to have a trans flush or,
    2.) a DIY fluid/filter change by a drain, pan drop, clean and refill?
    Is it too late and the tranny is gone?
  2. Sep 3, 2011 at 6:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'd do a flush. The filter is actually just a strainer (wire mesh). A drain and fill will not replace all of the fluid. The flush will help get the older fluid out.
  3. Sep 3, 2011 at 6:48 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    take it to the dealer have it flushed the drop the pan and add is a waste of money and time, ( why pour clean fluid into a dirty transmission ) I'de bet it smooths out after a flush, I had mine flushed for $ 149.00 look and see if your dealer has a service discount coupon on line.
    OEM fluid is the best, why chance mixing fluilds, I never use after market anti freeze or tranny fluid.
  4. Sep 3, 2011 at 6:17 PM
    jking3002
    Jonathan
    Kentucky
    Scion tC
    Took it to my local dealer and had a flush. Afterwards, it still shifted a bit rough and the fluid was still kind of dark, but after a few hours of driving (was on a road trip today) the shifting was much smoother and the fluid looked pretty pink. I think in another 10k miles or so I might do another flush and see if it helps even more. Things are still a bit rougher then I'd like...
  5. Sep 3, 2011 at 7:34 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Wait, you still had dirty fluid after they flushed it? I'd be asking how much fluid they replaced.
  6. Sep 4, 2011 at 6:04 AM
    jking3002
    Jonathan
    Kentucky
    Scion tC
    It was odd- still had a slight brownish color after the flush, but after about 200 miles (when I next checked it) it looked pretty pink. Still looking pink today. I see what you're saying though, a flush should be a full replace so it *should* look pink right after...
