Disable DRL's on a 2012 - it works!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Dec 9, 2011.
  1. Aug 7, 2013 at 12:26 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I can shut my DTRLs off and on with the stalk in my 2013 I thought the 12s were the same?
  2. Aug 7, 2013 at 12:41 PM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Nope. On 2012 you either have DRL on when truck in is Drive or you don't have them at all, one or the other.
    2013's you can turn them on or off with the stalk. No option on 2012 stalk.
  3. Aug 7, 2013 at 12:47 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
  4. Oct 11, 2019 at 8:33 PM
    2d Dragoon
    2d Dragoon Member
    PreRunner
    Thank God for this Thread. I'll start a new thread with my comments to my experience using this thread including the one referenced reverse engineering a DRL install.
    I bought the Toyota jumper and an improved flasher relay from Diode Dynamics for tap flashing and programmable hazard strobe lights before unbolting the fuse block.
    This thread allowed me to upgrade to LED turn signals without adding resistors to prevent hyper-blinking. Nine years ago when this thread was originated I don't think there were LED turn signals. I really like the tap trailing turn signal for lane changes and the Hazard Strobe Lights are cool. Thanks again.
  5. Apr 21, 2023 at 10:32 AM
    BustinJass17
    BustinJass17 Well-Known Member
    Justin
    Maryland
    2010 Tacoma TRD off road, DCSB, silver streak mica.
    Work in progress.
    I just did mine today ! Thanks for passing it along.
  6. Apr 21, 2023 at 4:06 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Not sure what the GM part number is, but the Toyota part number from my 2014 owners manual is: 4157NAK. (front turn signal/parking/DRL natural amber) Same PN for the Sylvania lamp. Note: the "K" is not on the Sylvania package, but it is printed on the wedge base of the bulb. I heard it stands for "Krypton" (gas), supposedly to extend the life of the bulb and or run cooler. When I had to replace mine: these were the bulbs that were in the truck. (not sure if they were OEM) I don't see any heat issues with the plastic on my truck.
    There is a discrepancy between the wattage shown in the owner's and the bulb package: 27/8 watts in the manual, 28.5/12.8 watts on the package.
  7. Apr 21, 2023 at 4:32 PM
    Williston
    New England
    Same as above on my 2014. I think they also have some other logic where they only come on when you shift into drive, and then don't go out again regardless of
    the shift position until you turn the truck off.
    [Edit] DRL switch on, parking brake off: Lights come on as soon as truck is started.
    parking brake on: Lights come on when brake released. DRL's stay on if parking brake re-applied, and stay on until truck is shut off.
  8. Apr 21, 2023 at 5:11 PM
    caribe makaira
    Caribbean, Puerto Rico
    It's when you release the parking brake...:burp:
    Williston[QUOTED] likes this.
  9. Apr 24, 2023 at 4:45 PM
    iiggii
    iiggii Well-Known Member
    jeff
    2010 tacoma access
    lift n radio
    thanks good to know.
  10. Jun 29, 2024 at 11:15 PM
    Codeka
    Codeka Well-Known Member
    Pasadena, CA
    2012 TRD Sport
    Anybody have their abs lights turn on a bit after install? Not sure if it's the defeat, or if I plugged something in where it shouldn't be hmmm
