Disable DRL's
Discussion in '1st Gen. Tacomas (1995-2004)' started by dka, Jan 19, 2010.
  1. Jan 19, 2010 at 12:30 AM
    dka
    dka [OP] Well-Known Member
    ok so i searched about 3 diff forums on how to disable my DRL's on my 04 tacoma everywhere i look its always cut the second wire but i heard that wire is the ground which sounds like i dont wanna mess with that haha also it leads to the highbeam lite to turn on
    and the second way i heard is to cut the first wire can someone lead me in the right direction i really want to get rid of these drls so i can get some hids! and i dont want to go do my last option which is go to the dealer and get ripped off lol anyone have experience with the drl's?
  2. Jan 19, 2010 at 12:32 AM
    dka
    here is a pic ohh and i tried pulling the fuse it jus turned my headlights off all togther
  3. Jan 19, 2010 at 10:39 PM
    dka
    bump no one knows?
  4. Jan 20, 2010 at 10:48 PM
    dka
    ok well i went thru with it and cut the wire every thing works great no illuminated hi beam light its all good
  5. Aug 4, 2010 at 12:09 PM
    shelton1092
    shelton1092 Member
    02 PreRunner SR5
    grillcraft black mesh grille, black headlights, black hunter super bull bar, custom tail lights
    just got hids installed.. how did yall locate this wire.. all my harnesses are in the hardest places to reach?!
  6. Aug 4, 2010 at 6:04 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
    Shelton, that harness is driver's side under the dash. Just did that about a month ago.....just like the picture says.
  7. Aug 4, 2010 at 6:22 PM
    veg hed
    veg hed Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    What are DRL's?
  8. Aug 4, 2010 at 6:23 PM
    david7268
    Tucson, AZ
    NONE.....yet!
    Daytime Running Lights!
  9. Aug 9, 2010 at 1:11 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    do the US trucks come with DRL's?
    Just wondering how to add them if i buy a US truck and bring it back to canada since we have to have DRL's (I'd then remove them after inspection)
  10. Aug 13, 2010 at 7:46 PM
    david7268
    Tucson, AZ
    NONE.....yet!
    I believe most of them do. That's why the DRL mod is so popular.
  11. Aug 13, 2010 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    My '02 does not have daylight Running lights.........and I am very grateful for that.:eek:
    JudoJohn likes this.
  12. May 8, 2012 at 8:11 PM
    Rdy2offrd88
    Rdy2offrd88 Well-Known Member
    Nick
    St. Louis, MO
    02 DC TRD
    Deckplate, CB w/ 4ft Firestick, Bedrug
    Did the same thing the other day and I can't seem to find anything that looks identical. More pics please!
  13. May 8, 2012 at 9:20 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    It's been a while since I did mine but, as I recall, I followed the instructions here and here. (Both of them refer to the attached DRL TSB.)
  14. May 8, 2012 at 11:39 PM
    htuong95
    htuong95 Have a nice day
    Sacramento
    2001 Tacoma 4x4
    Full OME suspension, Level 8 Tracker 16" wheels, BFG T/A KO 285/75/16, etc., work in progress...
    I disabled my drl last year because I didn't want my HID's on all the time. I am pretty sure I cut the first wire just like in the picture. I can always reconnect that wire back if I want my drl back :)
  15. May 9, 2012 at 5:03 AM
    htuong95
    Sacramento
    2001 Tacoma 4x4
    Behind the OBDII connector. Right of the steering wheel and left of the radio.
  16. May 9, 2012 at 6:08 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    So did you cut the first wire and it worked?
  17. May 9, 2012 at 6:15 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
  18. May 9, 2012 at 6:25 PM
    Norton
    Glad you figured it out! (That was why I posted those links, that included pictures... ;))
  19. May 9, 2012 at 6:34 PM
    fletch aka
    Gary
    Left Coast
    :facepalm:
  20. May 9, 2012 at 6:39 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    Sweet I know what I am going to try to do tomorrow!!
