Disable Seat Belt Alarm 2013 - Factory method DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by poppeye, Jan 4, 2013.
  1. Jun 15, 2014 at 7:25 PM
    #41
    toyo8696
    toyo8696 Well-Known Member
    Cumming,GA
    4X4 Sport DCSB, 2008 4R V8 AWD
  2. Jun 15, 2014 at 7:27 PM
    #42
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    eh its ok, no harm no foul.
    I do wonder if there is something similar you can do like the OP to disable the key in ignition beep.
  3. Jun 15, 2014 at 8:54 PM
    #43
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It works on some of the Tacomas before 2012, though it does not work on my '08 RC.
    Funny thing it, mine warns about the passenger seat, but I've never even seen the warning light on the driver seat.
    Going to have to try it again.
  4. Jun 15, 2014 at 9:00 PM
    #44
    Rich91710
    Rich
    Los Angeles
    08 Base
    So now that XP is a goner (and my notebook that still runs XP can't run without being plugged into AC), is there an alternative available yet that can be run on a smartphone and communicate via bluetooth with the adapters used for Torque?
  5. Jun 26, 2014 at 7:54 PM
    #45
    nd4spdbh
    SoCal
    Just did this with putty on my windows 7 laptop. and worked like a charm.
    just an FYI you could NOT see the commands being entered into the terminal in putty but upon pressing enter you would get the responses back from the BT adaptor.
  6. Jun 27, 2014 at 11:26 AM
    #46
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I figured out a sure fire way to shut off my seat belt alarm, I wear my seat belt. It may actually even save my life, win win in my book.
    I don't get the off roading reason either. I have had no issues leaning out the window with my seat belt on, I just pull some slack.
  7. Jun 27, 2014 at 11:42 AM
    #47
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    Subd. Trying this when I get home
  8. Jun 27, 2014 at 11:56 AM
    #48
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    #48
  9. Jun 27, 2014 at 6:36 PM
    #49
    tbturner47
    So I'm trying this in putty and I'm not getting any response with anything I type in
  10. Jun 27, 2014 at 7:22 PM
    #50
    tbturner47
    Nvm I got it. Worked
  11. Jun 27, 2014 at 8:39 PM
    #51
    Rich91710
    Rich
    Los Angeles
    08 Base
    #51
  12. Jun 28, 2014 at 4:24 AM
    #52
    koditten
    Kirk
    Central Michigan
    I forward the link because you were looking for a cable that works with a 64 bit machine. The newest software can be found lots of places for free.
    These Chinese cables advertise that the software is included, but every time I try to use the included mini disc, it ends up being corrupted. I end up finding the program on the internet and just downloading it.
  13. Jun 28, 2014 at 5:37 PM
    #53
    Rich91710
    Rich
    Los Angeles
    08 Base
    So the cable is different?
    I thought it was just the software that didn't get along with Win7/8
    It's actually a 64 bit issue? If so, I hear that... we've got a box of USB-RS232 convertors at the traffic management center that are worthless on even XP64.
  14. Jun 28, 2014 at 9:22 PM
    #54
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    does it kill the seatbelt dash light to? i figured out howto physically kill that to, but most would not like it, if there is a software fix i'm in!
  15. Jun 29, 2014 at 4:56 AM
    #55
    koditten
    Kirk
    Central Michigan
    No, the dash light stays lit if you do not put on the belt. Just kills the alarm/chime. This dash light is tied into the air bags. If you do not wear the belt and the seatbelt light is on, the air bag will not go off in the event of a crash. The air bag is designed to SUPLIMENT restraint and the prevention of injury during a crash...hence the abreviation SRS.
    Rich: There was never an issue with the software, just the cable drivers. They were designed to work with the Tuff Books that all the Toyota dealers use and they were all 32 bit machines. I've been watching pretty close for the last 3 years and was pretty sure we were gonna see a 64 bit program eventually. Looks like it is finally here.
    Like you said, the old XP machines are pretty much done for. It was getting to be a pain using my old XP netbook that wouldn't hold a charge.
    I have no issue spending $40 bucks for the same diagnostic tools that the dealers use.
  16. Jun 29, 2014 at 1:42 PM
    #56
    poppeye
    poppeye [OP] Member
    13 Taco TRD
    I've been monitoring this thread since I created it. I have 2 comments
    This thread is about the proper way to disable the seatbelt chime. It's not about seatbelt extenders or sensor removal. They work but probably have unforeseen consequences, such as altering airbag deployment characteristics (possibly)
    Please use other established threads for non software methods
    2nd. Disabling seatbelt alarms does not mean not wearing the seatbelt. So if your only contribution is to say just wear your seatbelt, keep it to yourself. It's not original, Nd it's not what this thread is about.
  17. Jul 2, 2014 at 6:38 AM
    #57
    cjoker
    cjoker Active Member
    brent
    Ontario, Canada
    2014 Tacoma TRD Sport
    Salex console & glove box organizer, front window tint, steelie phone mount, G-Tek Sill Protectors - carbide black & diamond plate, WeatherTek digital fit mats, LED Map and Dome lights
    I have a few questions, hopefully poppeye or someone else can answer them.
    I am going to disable the driver's seat belt chime per the instructions as I prefer starting the truck and buckling up before I put the truck into drive.
    Using the same method (obviously different memory locations) can I:
    • disable the passenger seatbelt warning chime?
    • disable the door open with key in the ignition chime? (or at least lower the volume...)
    Thanks!
  18. Jul 2, 2014 at 10:48 AM
    #58
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Just bought one myself as well...
    We'll see how it goes!
    Cheers,
    Jay
    #58
  19. Jul 2, 2014 at 9:31 PM
    #59
    Rich91710
    Rich
    Los Angeles
    08 Base
    For the key-in alarm, just split the clamshell behind the wheel and unplug the 2-wire connector on the bottom of the lock cylinder.
    5 minute job.
  20. Jul 4, 2014 at 3:15 PM
    #60
    khx73
    khx73 Well-Known Member
    Saint John NB, CAN
    11 MGM DCLB TRD Sport +leather
    Rear camera anytime switch, 4x4 Illuminated Switch (from rcbs204) , rear view mirror lift bracket (from ImMrYo), 75 cent tailgate anti-theft. Technically not mods but give me a break I'm trying to fill space here... OEM Leather pkg, keyless unlock & ACC chime silence, BakFlip G2, Ultra Gauge EM, WeatherTech floor mats, OEM roof rack
