Disable Seat Belt Alarm 2013 - Factory method DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by poppeye, Jan 4, 2013.
  1. Mar 27, 2016 at 5:09 PM
    #101
    intoit247
    intoit247 Well-Known Member
    steve
    Broadview Heights
    dcsb trd off road
    Roof rack, Led headlights , Led fog lights, Led backup lamps, black tail lights, bed mat, trailer brake , turn signal mirrors, scoop hood, painted grill bezel, headlight bezel paint, 3rd brake led. Tape on vent visors, rear slider visor. Driver heated seat. Wireless video on entune. TRD shift knob, TRD plate brackets front and rear. Led front switchbacks and led rear turn bulbs. AAL. 1 inch rear block. 3 inch lift front strut spacer. FIA front seat covers. Lighted 4x4 switch from 4 runner. TRD sport 17 wheels w kumho mud terrain tires..
    You could buy a very inexpensive on. Must be windows xp. To run correctly. I bought an actual toughbook cf-19:like the original fits under my driver seat perfectly.
  2. Mar 27, 2016 at 5:13 PM
    #102
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Anyone in NE Ohio area want their buzzer off PM me. Takes like 5 min.
  3. Mar 27, 2016 at 6:44 PM
    #103
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    I got it to work after a while sitting in the truck not sure if the passenger dings still but the drivers side wont ding any. I used the elm327obd app
  4. Sep 17, 2016 at 6:34 AM
    #104
    dbaxRonin
    dbaxRonin Member
    2016 TRD Off-Road - Some orange/red metalic color lol
    So I am looking to do this as the dog in the front seat sets off the bongos. I see on Amazon that there is a WiFi version of the ELM327 (Link), opposed/in addition to the Bluetooth version. Has anyone tried the WiFi version with any success? I am thinking that if I go with the WiFi version, after hacking the beeper, I can connect my phone's bluetooth to my stereo as normal, and then use the wifi with the ELM to have some fancy monitoring apps running at the same time.
  5. Feb 4, 2017 at 6:18 AM
    #105
    dbaxRonin
    dbaxRonin Member
    Has anyone been able to disable the passenger ding on a 16 Taco? I ordered an elm327 BT and am having a heck of a time with it. On both my Windows 10 laptops, I cannot get any commands to go through using putty. The terminal comes up, but nothing displays in it and it isn't accepting any commands (i.e. as I type nothing appears on the screen). I tried it on a Ubuntu machine too and that had all together other issues (most of which are likely a setup issue as I am not real proficient with unix).
    I tried several apps on my phone and only got one of them to actually take commands. I get through most of the commands with exception to the last 3...when I try those it just throws an exception (error or denied or something like that, I can't remember exactly). At first I thought maybe I had a bad module, but it works with the Torque app so I don't think that is the problem.
    Any help is greatly appreciated!!
  6. Feb 4, 2017 at 10:07 PM
    #106
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
  7. Feb 4, 2017 at 10:49 PM
    #107
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I have that one. It is crap. It does not have the capability to turn off the alarms.
  8. Feb 7, 2017 at 6:28 AM
    #108
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    I built a techstream laptop like the dealsr uses. $20.00 cable from ebay. I bought a good used toughbook cf19 and installed software. The techstream software that i ussd only runs under windows xp. I had to google a patch so that i could get windows xp to update. It worked really great on my 2015. Im sure there are all kinds of settings that can be changed since 2016 went to a advanced bcm.
  9. Feb 7, 2017 at 6:32 AM
    #109
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
  10. Feb 11, 2017 at 6:22 AM
    #110
    dbaxRonin
    dbaxRonin Member
    Did this come with Techstream? It only mentions that it works with it, and that it comes with a CD that I would presume would be at the very least driver installs, but curious if it also has TS on it. They also talk about installing TS, but again, never really say if it comes with it. This is a recurring theme on a number of cables I looked at on ebay.
    Took my truck to the dealer yesterday for my 6mo service and asked if they could disable the passenger seat belt warning. Bottom line is they said they could not...not that they wouldn't, but they weren't able to. Not sure if they really even tried.
  11. Feb 18, 2017 at 5:12 PM
    #111
    dbaxRonin
    dbaxRonin Member
    Happy to report that I got my MVCI cable from ebay the other day. I built an XP virtual machine using Oracle VirtualBox on my Windows 10 laptop and after some hoop-jumping, got Techstream to work with my truck and was able to disable both the driver and passenger seat belt warning beeps. I didn't intend to disable the driver's warning message, but I did anyway just to see if it would take. I always wear a seat belt, but I don't need to be told to wear it in any off-chance I ride w/o it. Seat belts save lives...I know from experience and get it, now STFU big brother!@
    The version of Techstream that shipped with my cable is older, version 10.30.029, which the makers have deemed obsolete. I tried to obtain a newer version but all the resources I found were on some pretty sketchy looking sites. I did try a couple but couldn't get a key that worked, so I made do with what I have and was able to get it to work, thankfully.
    If you are running TS and get a message about this, you cannot use it...unless you disconnect from the internet first. TS then fails to do a version check, and gives you 30 uses of the app until it presumably locks you out. Luckily this obsolete version of the software was still recent enough that it was able to work on my relatively new truck...2016 was the last year listed in the connection setup screen, so not sure if this version will work on anything newer than that.
    I wrote up a pretty thorough document that walks through installing a virtual machine, loading XP SP3 on it, installing Techsteam on it and what to do if you get the obsolete version message, and finally, how to connect TS to your vehicle and disable the seat belt warning beeping.
    Fair warning in advance that this document was tailored around my particular circumstance of what was provided to me when I bought the cable. Your situation may differ depending on what apps they send you on the CD. The VM and XP install is independent of the actual TS install however, so if you need a resource to at least get you through that, this has that in pretty good detail.
    I have it uploaded to this post as a PDF document. Figured it could be useful for anyone looking to keep this on the cheap since VirtualBox is free, and for all intents and purposes, so is XP.
    Any questions, I'd be happy to help (to whatever extent I can)
    raskal and Norton like this.
  12. Feb 18, 2017 at 10:13 PM
    #112
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    nice job dbaxRonin! Using a VM will definitely help with the max 30 uses issue.
  13. Feb 20, 2017 at 12:59 PM
    #113
    intoit247
    steve
    Broadview Heights
    dcsb trd off road
    Mine came with a little disc. Im sure that also does. The software is downloadable from the net also. I have downloaded and installed an update.
  14. Mar 4, 2017 at 6:11 AM
    #114
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    I installed the techstream software on a old dell mini that I bought years ago, works great.
    A note of caution, you can only use it a certain number of times before it stops running.
    Also my scummy dealer (miller in abq) reset the damn seat belt alarm after I had it for work.
  15. Mar 15, 2018 at 6:58 AM
    #115
    Twentybucktruck
    Twentybucktruck Member
    2017 TRD off road
    Quiet seat belts
    Just confirming. This works on my late 2017 Taco. First stage - all steps produce correct data and read back correctly. Using iPhone X with OBD Terminal App, and ELM327 WiFi just purchased from Amazon. I’ll try to remember to post a second stage after a test drive...
  16. Mar 15, 2018 at 7:47 AM
    #116
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
  17. Mar 15, 2018 at 2:24 PM
    #117
    Twentybucktruck
    2017 TRD off road
    Quiet seat belts
    But I didn’t need an extender, and I wanted to be able to make this thing work my way. My 2006 Highlander let me make this setting from the dash buttons, and I didn’t want to bother my poor overworked dealer . I did road test, and sure enough it works exactly as advertised.
    Now I need a complete list of the Tacoma OBD data structures to find out what other interesting features might be available. Anybody?
  18. Mar 15, 2018 at 8:59 PM
    #118
    bluezzy
    Monty
    Eugene, Oregon
    yah, stupid idea... works for me though... ;)
  19. Mar 16, 2018 at 1:41 AM
    #119
    Twentybucktruck
    2017 TRD off road
    Quiet seat belts
    Sorry if my tone was too harsh. I’m new to the forum, so please bear with that while I get it dialed in. And I shoulda said thanks for the extender suggestion. Thanks.
    bluezzy likes this.
  20. Mar 16, 2018 at 4:08 AM
    #120
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    Unless you want to hear the beeping for some other reason, you can just desolder the buzzer from the cluster. It takes all of ten minutes to remove.
