Disable that damn door buzzer!
Discussion in '1st Gen. Tacomas (1995-2004)' started by rendog, Oct 2, 2009.
  1. Jul 1, 2011 at 3:42 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  2. Sep 10, 2011 at 12:59 PM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    Sweet! No more damn door chime!! BTW, this is super simple and pretty quick. THANKS!!
  3. Sep 10, 2011 at 7:14 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    that thing's annoying! thanks
  4. Jan 9, 2012 at 3:07 PM
    garrettnb
    garrettnb Canadian Ambassador
    Garrett
    Vancouver
    00 TRD w/33s on a 4" lift
    Based on what sirsaechao said, you could assuming just snip one lead incase you want to put it back one day incase of a resale perhaps?
  5. Apr 26, 2012 at 3:35 PM
    T gunz
    T gunz Member
    Portland, OR
    03 Tacoma 4x4
    Piezo beep, daytime running lights, deck plate, door chime
    So I just did this mod and the buzzing is gone, the dome light still illuminates when the door is open but I did notice the "safety unlock power door locks when keys are in the ignition" function does not work anymore. No big deal for me.
    What I did notice (and I bought my 03 Dbl cab a year ago) is that the previous owner cut the red and the red/black wires under the steering column and electrical taped it all up.
    Does anyone know what this mod might be?
  6. Apr 26, 2012 at 6:58 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    I messed mine up one day and even when I closed the door it dinged so I put a rock in the little rubber thing over it. It quit but needless to say i left my lights on because it didn't remind me. Haha
  7. Aug 14, 2013 at 5:29 PM
    jahulgan
    jahulgan There and Back...
    James
    Central Georgia
    '09 SBDC Green TRD Off-Road 4x4
    Old Man Emu 886 Springs, 255-85-16, ARB Front Bumper w/ Warn 8K Winch, SOS Sliders, Custom Skid Plates
    I just did this mod the other day and realized there were a few thing that did not work right afterwords.
    1. The auto lock/unlock did not work anymore, no big deal (this was previously mentioned by T gunz)
    2. The auto unlock if the key is in the ignition and the doors are open no longer works, just remember to take the key with you when you get out, again no big deal.
    3. ****This applies to you guys that have an automatic transmission****
    If you do not put it in PARK you can still remove the key and walk away. THE ELECTRONIC SAFETY LOCK FOR THE TRANSMISSION TO BE IN PARK IS DISABLED. Which means YOU CAN TAKE THE KEY OUT WHILE IN GEAR and your truck will go for a drive without you in it.
    **This could be especially bad if you have a small child in the vehicle.
    I almost found this out the hard way pulled up in a parking spot and my phone stated ringing I answered it and hoped out of the truck and it rolled about 2 feet. I was lucky I was not on a hill.
    Before you unplug something know what it does and the risk you are taking.
    btu44 likes this.
  8. Sep 25, 2013 at 5:16 PM
    spoooner
    spoooner New Member
    You don't need to remove dash!!!
    Lie on your back with Needle Nose pliers, don't wear a hat. It will be tight and uncomfortable, but I just removed mine in 5 seconds. It's close to the plastic dash part, near e break lever.
    NEEDLE KNOWS!
  9. Oct 15, 2015 at 7:53 PM
    Jackthegiantkiller
    Jackthegiantkiller New Member
    95 Tacoma 3.4l
    AWESOME! I have a 95 Tacoma sr5 and unplugging the clip stopped the door buzzer, but still does the headlight buzzer. Which is great cause I always forget to turn the lights off on rainy days.
  10. Oct 16, 2015 at 7:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    or just turn the key to ACC, problem solved :notsure:
  11. Oct 16, 2015 at 11:19 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Mine dings as long as the key is in, no matter the position...(unless its running)
    cruxofthebisquit likes this.
  12. Oct 17, 2015 at 7:12 AM
    veg hed
    veg hed Well-Known Member
    Utah
    04 Toyota TRD SR5 V6 Access Cab
    Bilstein 5100s, Toytec 620 springs, OME Dakar Leafs, ARB Bumper, Warn 8000 Winch, Grey Wire Mod.
    So I've been reading through this and I need a little clarification because it seems like people are discussing two different ways to do this.
    If you disable the buzzer at the fuse panel, like the picture below shows, will the following still work?
    1)Auto unlock if you lock the doors with the keys in the ignition.
    2)Alarm if someone tries to unlock a door, say through a wing window (it happened to me one time).
    3)Dome light still comes on when door is open.
  13. Oct 17, 2015 at 8:54 AM
    ThunderOne
    ThunderOne Banned
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    everything still functions normally, just the physical buzzer will no longer be there
  14. Oct 17, 2015 at 10:24 AM
    bry838
    oregon
    Is that door buzzer also the same buzzer for the headlights, or is the headlight buzzer a separate one? Id like to not loose the "left your lights on dumb ass feature..."
    Glider08 and veg hed like this.
  15. Oct 18, 2015 at 4:18 PM
    #35
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    My light shuts off when I turn key off and open door while the headlight is on the on position.
  16. Oct 18, 2015 at 5:39 PM
    #36
    bry838
    oregon
    Not my trucks, if the headlights are on they are on and will stay on till manually turned off via the switch...
  17. Oct 19, 2015 at 5:17 AM
    #37
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I think that was a new feature for 01-04. My lights also turn off when I pull out the key and open the door. Pretty sure the "headlight" buzzer is not present either. Now, I can turn my headlights back on once I have opened the door but have to rotate the switch off then on.
  18. Oct 19, 2015 at 7:26 AM
    #38
    keakar
    keakar Well-Known Member
    karl
    louisiana
    just be aware you are "breaking" this buzzer off of the circuit board and doing so "may" break something in the circuit board which is very expensive so its a risky way to do it.
    if you really want to remove the buzzer from the circuit board rather then just unplug it :notsure: well the only "proper" way to do it is to remove the circuit board and flip it over then unsolder the two pins holding it as you gently (and safely) lift it off the board. this has no risk of damaging the board itself.
    the best way to disable the buzzer is to unplug it or cut the green wire and you can reconnect it later on at any time if you need to sell the truck.
  19. Oct 19, 2015 at 7:51 AM
    #39
    veg hed
    Utah
    I understand. But by unplugging or cutting the green wire I just want to make sure all the stuff I mentioned still works.
  20. Oct 19, 2015 at 9:44 AM
    #40
    keakar
    karl
    louisiana
    well breaking of or removing the buzzer from the circuit board means you have no buzzer for anything.
    as far as I understand it, unplugging the plug "may" disable all the buzzers just like removing the buzzer will, but just cutting the green wire only disables the door buzzer while the headlights on with door open buzzer still works. at least that's how I understood what they said.
