Disable that damn door buzzer!
Discussion in '1st Gen. Tacomas (1995-2004)' started by rendog, Oct 2, 2009.
  1. Oct 16, 2019 at 4:50 PM
    #81
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    you should only hear the ding ding ding with door closed and key to ON.
    door open will cause the buzzer with key OFF or in without ON/RUN. however those with DRL may be different with the mod?
    also with 01+ it should not have the headlight noise at all, they get shut off when you open the door and key OFF (thanks to the courtesy light function)
    GQ7227 likes this.
  2. Oct 16, 2019 at 6:49 PM
    #82
    Dirty White
    Dirty White Well-Known Member
    02 DC Prerunner and 03 ext can prerunner
    2002: 2.5" ome lift springs, 2.5" lift bilstein 5100 front shocks on oe coils and 5100 rear shocks. Topper. 285 75 16 toyo at2s. K&N intake. 2003: super spring progressive aal. Slide master 1000lb bed slide. Custom utility bed with lumber rack. Diamond aluminum 6ft boxes.
    I referenced the " ding noise when lights are on" only because others had mentioned that as being a problem with doing the mod. There seems to be many variations between all the years of first gen. That issue whether real or not does not matter to me. Right now the ding from my door being open while key is in has been resolved by the mod in this thread. My issue now is that when the door is open or closed, when I put the key to ON ,it makes 5 dings. The same dings that were present for open door but just a different speed. I'm assuming it has to do with the ignition circuit because it did not go away when I disconnected the door circuit. I'm asking if anyone out there has figured out how to override the dings that my year of truck does when the key is put to ON.
  3. Oct 17, 2019 at 5:26 AM
    #83
    GQ7227
    GQ7227 mw survivor
    J A Y
    i was unaware of that feature, might be nice to have that! (i don't) it buzzes at me to shut lights off
    another reason i got me into a Tacoma instead of a Nissan ... I found the Nissan door chime a bit too unsettling compared to Toyota door chime
  4. Oct 17, 2019 at 7:13 AM
    #84
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yeah that's a different circuit (ignition vs door). not sure there is a way to disable that though unless there is some weird speaker/piezzo located under the dash :notsure:
  5. Oct 17, 2019 at 7:41 AM
    #85
    Dirty White
    Thanks man. The search continues.
  6. Oct 17, 2019 at 6:12 PM
    #86
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    HAHAH, no seriously, HAHAH
    I just had to try it when I left work.
    the dam thing IS the seat belt warning. Just clasp the seat belt and it will not sound when you turn the key
    I tried with door open and closed, and seat belt unhooked. unhooked, dinged 5 times. hooked, no ding at all !
    so @Dirty White next time you leave the kiddo in the truck, just buckle the seat belt and you'll be fine :)
    or get one of these: https://www.amazon.com/Pack-Seat-Be...at+belt+extender+toyota&qid=1571361071&sr=8-8
  7. Oct 17, 2019 at 7:09 PM
    #87
    Dirty White
    Well...let's find out if it works for mine....
  8. Oct 17, 2019 at 7:20 PM
    #88
    Dirty White
    Hallefreakinluja! Frizzman....you are my favorite person right now. I don't think I have ever put my seatbelt on before starting my trucks. Laughable for sure. Thanks a million!
    frizzman likes this.
  9. Oct 17, 2019 at 8:26 PM
    #89
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    ikr? I never put my belt on before starting :rofl:
  10. Oct 18, 2019 at 7:39 AM
    #90
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    koditten likes this.
