Disabling key in ignition warning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CtryBoyInMT, Jan 23, 2008.
  1. Jan 23, 2008 at 1:53 PM
    CtryBoyInMT
    CtryBoyInMT [OP] Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I have been looking for days (searching the forum and on the vehicle) to find a way to disable to key in ignition ding. If I leave the key in and get out I don't like to announce the rest of the world that I did so. Not only that if I'm hunting it tends to scare away the game. Enough of the justification. I was hoping some of the electrical guro's can look at the schematic or know where the wire lead is. I did this on my old 97 tacoma, but it's different on my 08.
  2. Jan 23, 2008 at 7:28 PM
    dbbd1
    dbbd1 Well-Known Member
    D@mn, there is a thread somewhere. Basically, you remove the buzzer from the backside of the gauge cluster. I will keep looking, you look too.
  3. Jan 23, 2008 at 7:33 PM
    dbbd1
  4. Jan 24, 2008 at 9:37 AM
    CtryBoyInMT
    Thats the redneck way of dodging/fixinging the issue. I, too, located the buzzer. It's on a printed board and there must be a wire that triggers it. I found the connector for all the door functions behind the cubby hole, I just don't want to start cutting away. I am trying to find the schematic for the connector to determine which one it is. That way (you/I) can have the reverse tone and other useful tones.
  5. Jan 25, 2008 at 6:45 PM
    dbbd1
    I suppose you could always disable the door switch (that turns on your dome light) and/or put a switch inline with it.
  6. Oct 12, 2008 at 6:54 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    I'd love to do this but don't want to tear apart the cluster and break the bell. Anyone know a code or something?
