Disabling The Key in Ignition Alarm
Discussion in '1st Gen. Tacomas (1995-2004)' started by S-Runner '01, Aug 15, 2008.
  1. Aug 15, 2008 at 2:22 AM
    S-Runner '01
    S-Runner '01 [OP] Elderly Gentleman - Junior Member
    Jerry
    Yakima "the Palm Springs of Central Washington"
    BSP '01 S-Runner
    Garmin 260W - GPS Scanguage II K&N FIPK Kit Delta Low Profile Toolbox Fumoto Oil Drain Valve New Toyota Front Mats B&M Short Throw shifter New Tokico Gas Shocks Compustar Anti Theft Alarm System Redline Elite Hood Struts Phase Linear DVD/MP3/CD Player Professionally Detailed
    Can anyone tell me how to disable the alarm that sounds when I leave the key in the ignition and open the drivers door?
    My truck is an '01 Tacoma S-Runner.
    I don't want to disable the seat belt alarm and I do want the over head light to come on when I open the door but I like to leave my key in the ignition occassionally and the alarm is driving me crazy. (And it is a very short drive.)
    Jerry
  2. Aug 18, 2008 at 1:12 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    This should work for you. I have an '03, so I think it might be the same as your truck.....
    Pull off the lower part of the dash under the ignition. You should see a little white connector going to the switch with only two wires on it. This connector is attached to the ignition switch. Disconnect that thing and you should be good. Just don't forget to take your keys out before locking!
    Also if you have to sell it, all you have to do is reconnect the plug....
    :thumbsup:
  3. Aug 21, 2008 at 8:43 AM
    S-Runner '01
    Jerry
    BSP '01 S-Runner
    Thanks a million. My '01 was exactly as you described your '03 to be.
    I am once again back on the road to sanity.
    Thanks again.
    jerry
  4. Aug 21, 2008 at 11:19 AM
    monoman
    Dave
    No problem dude, glad it worked for ya! Those things drive you nuts.:eek:
  5. Oct 12, 2008 at 7:29 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    anyone know if this is for 2nd gen too?
