Disappointing gas mileage?
Discussion in '4 Cylinder' started by paid4c4, Oct 31, 2012.
  1. Nov 1, 2012 at 4:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I would change out the diff oil to synthetic; it made a big difference in my truck. It used to feel like I was putting on the brakes every time I released the throttle; now, it ....rolls.
    Keep your tire pressures up and put on a high pressure gas shock (like Bilstein) and Pray.
    Alloy wheels have made a huge effect, too.
    My truck, so far..
  2. Nov 1, 2012 at 4:24 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That 'braking' feeling may be partially due to the fuel cutoff on decel feature, but better drivetrain lubrication definitely makes a difference.
    I knew it. Yes the fuel mileage will continue to improve as you get more familiar with the truck. Glad you are getting some good results! :bananadance:
  3. Nov 1, 2012 at 6:23 PM
    paid4c4
    paid4c4 [OP] Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    Thanks for all the great comments. I hadn't thought about changing the rear end to synthetic and the effect it might have on mileage. I use synthetic in everything we own including all three holes on the Harley. I bought the truck to use as a truck and haul stuff when needed. I particularly wanted the 2.7L for good mileage and to see what all the hype was about. Most folks who drive a Taco with a 2.7L swear by them, I'm beginning to see why.
  4. Nov 1, 2012 at 6:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    What's his current userID?
    OP, ya, the tires are over 7% larger than stock. That's going to reduce your miles traveled and make the calculated MPG appear low.
    OTOH, that pretty much corrected your speedometer error... maybe a bit overcorrected, but not enough to worry about.
    I'll be going 65 when my speedo is a tick under 70... The 235/75-15 tires will put you at about 67 or so when indicating 65.
    On the odometer... the error is only about half the speedo error, so honestly, if you look at reported MPG numbers including those in my Fuelly link, they are inflated by about 2-3%... 25mpg is really only about 24.
    Your tires will "deflate" that further to about 23... or... in your case, your actual from 18.1 would be closer to 20.
    That's not bad.
    It's not awesome, but it's not horrible for an extended cab with only 44k on it and a quarter tank of 6-month old fuel.
    Run it down... The low fuel light comes on when you still have 3-4 gallons left... so get that light on and run it another 40 miles or so, then top it off with a quality gas from Chevron/Mobil/Shell/Texaco and I think you'll see some improvements.
  5. Nov 2, 2012 at 12:43 AM
    Manwithoutaplan
    ID
    Who says whipper is back on here.
  6. Nov 2, 2012 at 12:48 AM
    Manwithoutaplan
    ID
    You ever think that theirs millions of threads covering this exact subject. Maybe use the search button next time :anonymous:
  7. Nov 2, 2012 at 6:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I figured that's what you were implying with "here in spirit"
    No?
  8. Nov 2, 2012 at 6:10 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
  9. Nov 5, 2012 at 1:17 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    About time. He's always come across as a snob.
  10. Nov 6, 2012 at 8:13 AM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    I think winter gas is in effect here. I noticed a 2mpg drop last fill up.
  11. Nov 6, 2012 at 8:50 AM
    Manwithoutaplan
    ID
    Did you get your wheel stub fixed ???
  12. Nov 6, 2012 at 9:39 AM
    paid4c4
    Northern KY
    I've ran out the old fuel completely. The last of the old fuel with mostly new fuel gave me 22.3 MPG. I ran the tank down to almost empty so the tank is now new winter blend fuel. I'm going to check tire pressure and see what this tank yields. I can tell that the truck is running better and sounding better in general with use, Mobil One and better/fresher fuel.
    Thanks for all the ideas and comments.
    Bill
  13. Nov 6, 2012 at 11:29 AM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    I noticed on my v6 if I keep the rpm below 2k or so it helps. Not sure how much gain you will get from a v4
  14. Nov 11, 2012 at 7:13 AM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    v4.. :frusty:
  15. Nov 11, 2012 at 10:11 AM
    #35
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Your mileage will probably improve with time. I bought my '09 last spring and was not impressed with the gas mileage--23 to 25 mpg. As I got accustomed to the truck (or it got accustomed to me) the mileage has improved to above the EPA ratings. FWIW I am using 5W30 oil with no apparent problems. I don't think the oil rating has a huge effect.
  16. Nov 11, 2012 at 7:49 PM
    #36
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    A 5w-20 oil will typically give you between a half and a full MPG better. And a 0w-20 oil for sure a full one MPG increase. Not a earth shattering difference. But if everyone would use 5% less fuel it would help lower pollution, and maybe make a few greenies happier, and off our asses.
    I typically buy the least expensive high quality oil. If it is available in a 20 weight, that is what I chose. And I actually have three changes worth of 5w-30 coming up, but will use my fill of 0w-20 this winter. Changing oil this week. If you are just do not feel confident using a 20 weight, I understand, as I used to feel this way. I even use 20w-50 in my motorcycle. It is what the manual calls for.
  17. Nov 12, 2012 at 7:14 AM
    #37
    rydaniels
    rydaniels Well-Known Member
    South Jersey
    4x4 4cyl manual
    bone stock except tool box in bed
    have never noticed the differences in mileage and oil-weight. When i had my astro van it got the same mpgs on 10W-30 as it did on 5W-30. I find myself switching to heavier weight oils on my parents and siblings older vehicles because they dont take care of them properly. Id rather have the protection. I had Toyota put in 5W-30 during my toyota care. Additionally its a lot easier (for me at least) to quickly find 6 qts of synthetic 5W-30.
