Disc brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bikerz, Jul 15, 2010.
  1. Jul 15, 2010 at 4:57 AM
    bikerz
    bikerz [OP] Member
    TRD Offroad
    Noticed that a person where I work that drives a 2009 Tundra has disc brakes on the back. Why has Toyota chosen to not put them on the Tacomas?
  2. Jul 15, 2010 at 5:00 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Most likely cost. The proportion of braking from to rear on a truck, operated a lower speeds and less dramatic maneuvers, works just fine with the drums...
  3. Jul 15, 2010 at 6:17 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've wondered the same thing. My last truck had 4 wheel discs and seemed to stop quicker than the Tacoma. I'm surprised it wasn't even offered as an option on the sport or TRD packages.
  4. Jul 15, 2010 at 6:41 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Drums actually provide the same braking power as discs they just don't dissapate heat as well as discs. Under normal driving conditions...especially with rear brakes you never really NEED disc brakes. They look cool but they're cheaper which is probably why toyota put them on the tacoma.
  5. Jul 15, 2010 at 7:01 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    You know...I always thought that would be the reason even though I just can't understand why cost for drums would be less.
    Just look at the number of parts on a drum setup...and how much more complicated (difficult) assembly is with all those springs and clips and special tools needed. I just couldn't figure it...
    Also, to add to benefits for disks is that they are much better when swamped in water.
  6. Jul 15, 2010 at 7:13 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    ah man another 1 of these threads...lol
    honestly i highly doubt its a money issue seeing as the toyota sells way more tacomas than fj cruisers and rav4's combined....and both the fj cruiser and rav4 have rear disc brakes...
    the fj cruiser uses the same lug pattern and dana as the tacoma...hasn't been around for 20+ years and when toyota released the fj gave the fj more versatile setup then the tacomas have...manual transfer case, rear disc brakes, and rubber matting throughout the entire vehicle...just to name a few...
    so while toyota has stepped up to the plate in some areas on other vehicles they let the tacoma stay mediocre...end of rant i could go on and on and on about toyotas flaws with the tacoma...
  7. Jul 15, 2010 at 7:18 AM
    macgyver
    Brad
    Canton, GA
    I haven't researched this..but that being said, has anyone swapped the FJ rear discs to the tacoma?
  8. Jul 15, 2010 at 7:25 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    well if you think about it, the FJ only has one basic suspension type, while the tacoma has two, with two different rear axles. and im pretty sure toyota would want all the tacomas to share the same basic features, regarding brakes and such.
  9. Jul 15, 2010 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You could do it, but you would also need to swap the brake booster, and master cyl.
    FWIW, The Tacoma has the shortest stopping distance in its class.
  10. Jul 15, 2010 at 8:00 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    but that class also consists of crap like the ranger and the colorado lol...
  11. Jul 15, 2010 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. And the Nissan, and the Dakota. Both of which have (had for the Dakota, as the new ones have drum brakes) disk brakes.
  12. Jul 15, 2010 at 8:11 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    both of which are heavier than the taco too...wtf was dodge thinking? when did they get rid of the rear discs?
    anyway a rear disc conversion, besides looks, would really only help with the brake fade...it's been done before with negligible effects on the actual stopping distance
  13. Jul 15, 2010 at 8:15 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    $$$$$$ Is the only legitimate reason IMO. However, drum brakes in the rear do the job and they usually don't need to be replaced as often. I've had several cars with 4 wheel disc brakes and the front pads seem to always outlast the rear.
  14. Jul 15, 2010 at 3:33 PM
    bigcoffinhunter
    bigcoffinhunter Well-Known Member
    The front brakes do most of the work. When I traded in my '02 I was still on the original rear drums and shoes. My mechanic checked and said I had plenty of life left in them. The front brakes I had done a couple years back.
  15. Jul 16, 2010 at 1:50 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    full drums in the rear make for better parking brake.
  16. Jul 16, 2010 at 4:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Give it time..... probably the same reason why tacomas don't have a lot of things. I mean... really? They don't even have power seats!!
  17. Jul 16, 2010 at 4:39 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    The cost is not the difference between drum and disk. Drums are usually more expensive. The cost is re-engineering the truck to use the disks. Tundra was already going through that process.
    Remember, Toyota can't just make a swap of parts like you and me in our garages, they have to prove through rigorous testing that proves everything works properly or they have to spend millions in recalls! ;)
    I would expect to see rear disks on the next generation.
  18. Jul 16, 2010 at 4:54 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    Drums are cheaper to manufacturer and the rears only do about 35% of the braking anyhow.
    Be happy you have rear drums, trust me.
    If you ever worked on vehicle with rear discs, you will be happy you have drums.
    Not all, but many vehicles with rear discs have problems with rust because the brakes are not used as much in the rear. I've had to replace rotors on trucks with 15,000 miles in the rear because of rust. On a Silverado, the price of the job is usually around $500 or so for the customer; and that's if they don't need calipers.
    If the rear drums are duo-servo type, then they actually have close to the same braking power as front discs because of the self-energized design. Usually foreign cars use leading/trailing designs, which do not offer this benifit. I havn't taken my rear drums off yet, but I plan on doing so next week, so I am not sure what the Tacoma is equipped with.
    Anyhow, in the long run, I am happy with my rear drum brakes. If they are adjusted every 7500 miles, they should work well.
  19. Jul 16, 2010 at 9:18 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I haveta disagree...haveing worked on both drums and disks I'll pick disk anytime. Best-to-best disks are so easy it's a crime that shops charge for anything more than the pads and wheel rotation.
    Even at their worst disks are easier: I far prefer loosening and torquing bolts to wrestling with all those da*n springs. I'm very happy to hear how much service life people get from the rear drums on the Tacoma.
    Also: looking at the manual for an '06 Tacoma it looks like these aren't duo-servo drums.
