Discrete way of weighing down bed?
Discussion in 'Suspension' started by FLtaco, Nov 22, 2011.
  1. Nov 22, 2011 at 10:21 AM
    #41
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    Looks level to me....
  2. Nov 22, 2011 at 10:21 AM
    #42
    FLtaco
    FLtaco [OP] Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    Thanks for input my friend. Maybe its all in my mind then.
  3. Nov 22, 2011 at 10:21 AM
    #43
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
  4. Nov 22, 2011 at 10:26 AM
    #44
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Just took that photo. Looks rear high but I guess it's just me. Thanks for the input tw. And sorry for the earlier rants.
  5. Nov 22, 2011 at 10:28 AM
    #45
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You've got a little rake but it looks good in my opinion. Maybe this will make you feel better... LOTS of rake (when unloaded).
  6. Nov 22, 2011 at 10:29 AM
    #46
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Cheap but involves getting under truck more than once alone with jacks and trying to re position rear axle alone. Which is all doable don't get me wrong but if I can do it once id prefer that. I hate paying someone else to work on my truck unless it's out of my league. But things like this I try to save a couple hundred in labor and do myself.
  7. Nov 22, 2011 at 10:34 AM
    #47
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  8. Nov 22, 2011 at 10:36 AM
    #48
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
  9. Nov 22, 2011 at 10:37 AM
    #49
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Makes me feel alot better lol thanks
  10. Nov 22, 2011 at 10:39 AM
    #50
    OZ-T
    Peter North
    British Columbia
    :thumbsup:
  11. Nov 22, 2011 at 10:53 AM
    #51
    neoflex
    neoflex Well-Known Member
    After seeing pics of your truck I would say your splitting **** hairs unless of course your looking for what is referred here as a bro lean. Truck looks good as is and as others mentioned if your really looking to get it done cheap just swap the 3" block for a 2". Yes, you will have to get under the truck and do it but it's not like hiding weight is going to be a simple task. You also mentioned having to save money due to a kid coming. I am there and know what you mean but adding weight to the truck is also going to negatively effect your mpg in the long run so why not just suck it up and go with the smaller block. It will probably take you 2 hours tops and your done and it will be done correctly rather than have a bunch of bags in your bed sliding around.
    Personally I think your truck look good as is and suggest just going down the block and grabbing a 6 pack. Put six pack in fridge when you get home and proceed to wash your truck. When done washing grab said six pack and a lawn chair and just sit and stare at your truck because she's a beaut.
  12. Nov 22, 2011 at 10:58 AM
    #52
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Thanks man. Yea kids already here. So saving has started. I appreciate all options expressed gentleman. But I think your right about block just I'll save for leaf pack. Thanks for compliments on truck though gentleman and all the help. I see what everyone means by as much work to hide weight for lower Mpgs compaired to lowering rear with block and cost for block probably aren't far off. Thanks everyone.
  13. Nov 22, 2011 at 11:05 AM
    #53
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
  14. Nov 22, 2011 at 11:08 AM
    #54
    OZ-T
    Peter North
    British Columbia
    I couldn't remember the brand name either , so I Googled " traction weights "
  15. Nov 22, 2011 at 12:15 PM
    #55
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    3/16 diamond plate in the bed. 100$ and you ought to have enough to way the truck down a bit.
  16. Nov 22, 2011 at 12:18 PM
    #56
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Agreed, Pugga had a good suggestion. That or some patio stones laid end to end so they won't slide around. 1 inch thick and 32" by 24" weighs around 90lbs >< . 2 or 3 of those should drop you an inch or so.
    If weight causes excess wear on the suspension I guess my 200 lb cap from leer should have broke something by now??? 5 years its been on the truck. It is a truck which is meant to carry stuff.
    My work truck has had several hundred pounds in it for 8 years now and nothing has "wore out " yet.
  17. Nov 22, 2011 at 12:30 PM
    #57
    FLtaco
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Good suggestion and agree on weight
  18. Nov 22, 2011 at 12:31 PM
    #58
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    Just mount a brass stripper pole in the middle of the bed with 2 smokin hot stippers on it all all times. It will be discrete and give you the ride hieght your looking for. :D
  19. Nov 22, 2011 at 1:17 PM
    #59
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Some modifications are just permanently unavailable to us married guys.
  20. Nov 22, 2011 at 1:19 PM
    #60
    OZ-T
    Peter North
    British Columbia
    Unfortunately :(
