Distance to empty Glitch?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Aug 18, 2019.
  1. Aug 19, 2019 at 1:13 PM
    Shellshock
    Iowa
    it changes based off your average fuel economy.. so yes
  2. Aug 19, 2019 at 1:21 PM
    djgynee
    djgynee [OP] Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    Wow. Really. 340 miles right not kilometers. With 35’s and 6”. The fuel gods have show you love
  3. Aug 19, 2019 at 1:29 PM
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    Miles, although I know that's not accurate. The tire/speed calibrator is new and could adjust to a more accurate number soon... possibly?
  4. Aug 19, 2019 at 1:31 PM
    djgynee
    Southern California
    Ya bro let me know in a PM. So I don’t miss the update. Thanks for the feedback
  5. Aug 19, 2019 at 2:03 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Keep in mind it could say 295 left, but if you're cruising on a highway at optimal fuel mileage speed, and you drive 15 miles, it could still say 295 miles left even though it "should say 280", but in reality, you just got 310 because of your driving...make sense?
    Big tall dave likes this.
  6. Aug 19, 2019 at 2:08 PM
    djgynee
    Southern California
    Ya I’m at a “307 right now even though it said 295. Cause it says 267 but I just drove 40miles on trip.
    So it might not be as bad. I was tripping I didn’t know the computer forecasted based on previous readings so it threw me off.
    I guy said to a brand new Tacoma owner here to becareful not to get Tacoma hypochondria here. But I find out it’s a big family of brothers just like to swap pics, stories , info and life. It’s cool
    And thanks for the feedback
  7. Aug 19, 2019 at 2:59 PM
    N2DesignsInc
    Los Angeles, CA
    No worries. If you ever change your mind, you could be the first to do a Prius engine transplant...then it'll say you have 4,000 miles left after a fill up! :D Welcome to TW (even though you've been around, you're starting to understand the funky loving dynamics of this great family). Lots of good info, lots of jack-asses, and lots of jack-asses with good info. I fall somewhere in there...I think :oops:
  8. Aug 19, 2019 at 4:35 PM
    Grangis904
    Grangis904 Well-Known Member
    Jacksonville, FL
    2018 White TRD Pro
    I recently unhooked my negative battery terminal to do some work, when I hooked it back up my miles till empty went from 329 to 405 because of the ecu resetting... If it was only that easy...lol
    Big tall dave and djgynee[OP] like this.
  9. Mar 17, 2020 at 12:59 PM
    tacochep
    tacochep Well-Known Member
    Phoenix AZ
    2019 S White Taco DCSB TRD 4x4
    scs ray 10's, demello sliders, meso stuff
    Mine wont reset after I fill up... went from 313 to 285 after fill up. But even after I add more gas it doesn't reset
  10. Mar 16, 2021 at 4:05 PM
    zo66
    zo66 New Member
    2020 Tacoma TRD
    I was wondering the same thing about my Tacoma. When I first got in it said 305 to empty and then 296 and now 256! I do drive over 70 on the thruways everyday to work and back. I did call my buddy who is a sales Manager at Toyota and he explained this but I thought it was him joking around! Guess not hahaha Thanks guys for helping out.
  11. Mar 16, 2021 at 6:55 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    When it also knows the terrain and traffic ahead as well as the speed I’ll be going then I’d believe it.
  12. May 14, 2021 at 6:05 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Reviving for a maybe new issue.
    Always have 310+ Distance to empty when full. I topped off recently at 280 miles to empty and it never went up. Keeps counting down like I never topped off. Gas dial is full AF. Is there a way to make it reset without disconnecting the battery?
  13. May 14, 2021 at 6:12 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Maybe it’s learning where you stop to fill it. That would make your new range 280. To relearn go farther.
  14. May 14, 2021 at 6:20 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Explain please? I’ve never topped off. I don’t understand how adding gas can make the distance to empty not go up at all.
    EDIT: This is the first time I’ve topped off. I have never filled up when I had more than half a tank. The computer doesn’t take that into consideration. It only takes MPG history into account.
  15. May 14, 2021 at 6:28 PM
    #35
    bagleboy
    Scott
    Norcal, Santa Rosa
    You drove x miles and filled up so it thinks you can go x miles again before the next fill up. Each tank is a distinct number. Like the difference between odo and trip meter. If you don’t stop at 280 to refuel but instead go on to 320 then that might become the new number. Just guessing anyway, I’d have to drive one for awhile to get a feel for it but it sure seems like a crude system that’s not terribly accurate.
  16. May 14, 2021 at 6:29 PM
    #36
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    That makes no sense at all. And you have a 2nd gen so?
    there is a sensor that can tell how full your tank is. That’s how the gas gauge works. Then it uses past mpgs to calculate distance to empty.
    Lucky Lefty likes this.
  17. May 14, 2021 at 6:34 PM
    #37
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    And yes it’s not accurate. I could goose it all over town and the 320 it said I have would last 250. Just looking for a way to manually force it to recalculate it’s estimate. Every time I have filled up it’s gone from 100 miles or whatever to 3xx
  18. May 14, 2021 at 6:38 PM
    #38
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s attempting to cater to your habits. Some people always refuel at 1/4 tank, others at 1/2 tank. Your range is how far you go before refueling regardless of how much is actually left in the tank. I agree, makes no sense at all and why I’ll keep mine another 10 years or so.
    It may not work that way but from what I’ve read it’s not worth bothering about and certainly not worth counting on.
    barf[QUOTED] likes this.
  19. May 14, 2021 at 6:39 PM
    #39
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Fuckkkkkk. That’s so annoying that one refuel can mess up my distance to empty. I mean I still have a gauge so there’s that. Thanks for schooling me.
  20. May 14, 2021 at 6:44 PM
    #40
    bagleboy
    Scott
    Norcal, Santa Rosa
    You had it right from the start. Mines a 2nd gen so don’t quote me on this stuff. It just seems to work that way is all I can figure from reading 3rd gen posts. There may be a reset from the HU, that would be much preferable to losing the transmission driving data with a hard reset
