Ditch/Hood Light Bracket - Ultimate Guide & Poll (Pictures)
Discussion in 'Lighting' started by Tac0maSteve, Apr 18, 2017.
What Ditch/Hood Light Bracket do you have?
  1. Relentless
    43 vote(s)
    8.2%
  2. CaliRaised
    218 vote(s)
    41.7%
  3. CBI
    91 vote(s)
    17.4%
  4. Rago
    99 vote(s)
    18.9%
  5. SOS Concepts
    26 vote(s)
    5.0%
  6. Tacoma Beast
    1 vote(s)
    0.2%
  7. SDHQ
    34 vote(s)
    6.5%
  8. T-Rex
    3 vote(s)
    0.6%
  9. Off Camber Fabrications
    5 vote(s)
    1.0%
  10. KC
    3 vote(s)
    0.6%
  1. May 17, 2017 at 6:02 AM
    #41
    T4RFTMFW
    T4RFTMFW Well-Known Member
    @RelentlessFab like a mo. :anonymous:
    ChadsPride[QUOTED] likes this.
  2. May 17, 2017 at 6:04 AM
    #42
    ChadsPride
    Sponsored by TacomaWorld.com
    Leaning towards the SOS Concepts - Good price, exactly what I want.
    I appreciate it bro!​
    SOS CONCEPTS and JimboAnz like this.
  3. May 17, 2017 at 6:19 AM
    #43
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Does anybody know if the CBI 2nd gen brackets interfere with a snorkel?
    ChadsPride likes this.
  4. May 17, 2017 at 10:46 AM
    #44
    Tac0maSteve
    Tac0maSteve [OP] Well-Known Member
    East Bay, CA
    '15 TRD Off Road Icon Ext. Travel
    DCSB... No mods here
    SOS is a hood hinge mounted system so these should suit your needs. If you want a lower profile you could also look at SDHQ.
  5. May 17, 2017 at 10:47 AM
    #45
    ChadsPride
    For sure!
    Ive been looking at those also
    Any issues with opening the hood with the lights installed?
    The are more pricey...
    PvilleJohn likes this.
  6. May 17, 2017 at 10:50 AM
    #46
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Sos makes straight bolt ons. No cutting or anything required. I got cbi ones before sos started making them or I would've went with them.
  7. May 17, 2017 at 10:51 AM
    #47
    Tac0maSteve
    East Bay, CA
    I don't run them, I just have knowledge from my research. From what I have learned none of these should have issues with LED 2x2 Pods attached.
  8. May 17, 2017 at 10:54 AM
    #48
    ChadsPride
    Thanks man!
  9. May 17, 2017 at 10:54 AM
    #49
    ChadsPride
    Leaning towards SOS very strongly at the moment
    Has to wait till Friday
    Acerwin[QUOTED] likes this.
  10. May 17, 2017 at 10:54 AM
    #50
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    Great write up!
  11. May 17, 2017 at 10:58 AM
    #51
    Tac0maSteve
    East Bay, CA
    Thanks, I appreciate it. Took me a couple days to properly write it up.
  12. May 17, 2017 at 10:59 AM
    #52
    Tac0maSteve
    East Bay, CA
    I feel like I need to invest in a "chadspride likes this sticker" now.
    SOS CONCEPTS and ChadsPride like this.
  13. May 17, 2017 at 11:01 AM
    #53
    ChadsPride
    Haha!!! They are available for purchase
    SOS CONCEPTS likes this.
  14. Jul 19, 2017 at 11:19 AM
    #54
    CamShaft033
    CamShaft033 Well-Known Member
    Cameron
    Chattanooga TN
    2012 DCSB TRD Sport
    OME 887s, JBA uca, Dakars, Fox Shocks, 285/70/17 Nittos, Dual Flowmaster, ARE Camper Shell w Yakima Rack, CVT Tent, AVID Rear Bumper Guard w LED Pods, 52" Lightbar, Sportsman Seat Covers, WeatherTech Floor mats
    Just ordered a set of CBI mounts on there garage sale for $25.00.
    :drunk:
    Tac0maSteve[OP] likes this.
  15. Aug 5, 2017 at 5:21 AM
    #55
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    I installed Cali Raised brackets, side projecting pods, and harness on my 08 Prerunner last week.
    On my brackets, the powder coat was flaking out of the bolt holes. On the driver side, the bracket mounted but was so tight it had no adjustment and was trying to deform the fender holes when bolted down. I drilled the bracket holes larger to fix the issue. On the passenger side, only two of the bracket holes would line up with the holes in the fender. I cut the third bracket bolt hole into a slot so all 3 bolts could be used and allow for adjustment. I painted the lower half of both brackets with self-etching primer and bed liner spray, and it blended seamlessly with the powder coat. I plan to take them off some weekend and make a slot to zip tie the light cable to.
    The harness that from Cali Raised was pretty poor quality as well. Both light connectors were the same length, so the driver side basically had an extra 4-6 feet of wire on it. I cut it down to get rid of the extra wire and found that the connections where the harness splits to each light isn't soldered. It's just a cheap, single crimp, so I soldered it up and fixed that. The wire going to the battery was too short by about a foot, so I soldered wire from what I cut off the driver side lead to extend it. Finally, there's no reason for them to run 3 wires through the firewall for the switch. With a little forethought and planning, only 1 wire needs to go through the firewall to the relay. When I get around to redoing my accessory wiring with a proper fuse panel, I'll be fixing this issue.
    One last thing to note is that the original post says the Cali Raised brackets come with a zip tie cutout. Also, pictures on Cali Raised website show 2nd gen brackets both with and without the zip tie cutout. The brackets that I received didn't have the zip tie cutout, so it's probably safe to say that they either never actually had it or stopped doing it.
  16. Aug 5, 2017 at 10:18 PM
    #56
    Tac0maSteve
    East Bay, CA
    Interesting. Definitely some good feedback. It sounds like you had to do some significant modification to get this to work on your truck. I know it's a little late, but were you able to contact caliraised to make them aware of the issues you were having? They can't correct the problem if they don't know about it.
  17. Aug 6, 2017 at 5:00 AM
    #57
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I contacted Cali Raised about the fitment issues. Their response was that they had never heard of anyone having issues, and they asked for pictures. It took me a few days to get pictures because I'd put the truck back together and rainy days. I never heard from them again after I emailed the photos.
    Talking with another forum member recently, they said they had similar issues with their Cali Raised brackets and only ran 2 bolts on the passenger side. They said they know of at least one other forum member doing the same, so it sounds like an existing issue. I don't think the other two members contacted Cali Raised.
  18. Aug 10, 2017 at 3:54 AM
    #58
    GJefe4x4
    GJefe4x4 Member
    South East LA
    2012 Tacoma TRD LB 4x4
    Need to buy brackets soon. Led Pods & Harness has been sitting in my garage for like 2 months...:anonymous:
  19. Aug 10, 2017 at 7:07 AM
    #59
    Tac0maSteve
    East Bay, CA
    Do it man! Do you already have the wiring ready to go for it?
  20. Aug 10, 2017 at 10:07 AM
    #60
    GJefe4x4
    GJefe4x4 Member
    South East LA
    I do. Just put it on the back burner once I started house hunting. But now that I'm getting my house keys soon. Once I settle in, im leaning towards Relentless Fab brackets. Great post by the way.
