DIY - 2.4L / 2.7L fuel filter relocation mod
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 25, 2014.
  1. Mar 22, 2016 at 6:18 AM
    FIRTH4X4
    FIRTH4X4 Well-Known Member
    Eric
    Wyoming
    98 Taco 2.7L 5spd
    Thanks for the write up - worked great. Did mine while the intake was off.
    keakar[OP] likes this.
  2. May 10, 2016 at 2:14 PM
    irhunter
    irhunter Well-Known Member
    Maine
    '96 2WD 5-sp 2.4 Tacoma and '03 4WD AT 4.7 Tundra
    Got a link for that?
    Roy
  3. May 13, 2016 at 10:35 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Excellent write-up, @keakar! I used 1/4" fuel injection line and fuel injection clamps just to be safe. I also got 2 new washers for the fuel rail banjo nut. Anyone who does this, get 2 or 3 spare fuel rail banjo nut washers, the bottom one is a bitch when you're trying to reassemble and you WILL drop one into the engine bay netherworld. The OEM fuel filter comes with 4 new washers for the banjo fittings on the fuel filter. There is no scheduled replacement interval for the fuel filter, which is stupid. My truck only has 90,000 miles and the gas I dumped out of the old filter was dark brown with visible sediment. Once I got everything put back together, the idle was noticeably smoother, the engine cranks less before starting and the butt-dyno is measuring a 5 HP improvement. It's also a huge relief that fuel filter changes will be fast and easy now.
  4. May 22, 2016 at 12:07 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    glad it helped you and sounds like you really needed it changed :cheers:
    PS - that's where Toyota should have put the damn fuel filter on both the 4 & 6 engine trucks
    now that I own a v6 taco I figured changing the fuel filter on it sounds easy and its right there under the drivers seat on the frame rail, but its not that easy to do even if it is easy to get to, the gas keeps draining out all over you and you have to literally pull the fuel lines loose to release them from the fuel line brackets that are cheap plastic and I was scared as hell they would break off but I managed to do it without breaking anything but I was covered in gas even after releasing all fuel pressure in advance of doing it. no need for a write up on the v6 filter change except to say wear a frickin rain coat and old clothes you don't mind throwing away after being soaked in gas
  5. May 30, 2016 at 3:24 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    Nice write-up and some great info from everyone. Thank you.
    Looks like I will be doing this very soon.
  6. Jun 2, 2016 at 12:49 AM
    Chris D.
    Chris D. Well-Known Member
    Eagan, Minnesota
    2002 Tacoma RZN150 turbo
    2RZ-FE Turbo Intercooled, standalone........... Exactly 150% more power to the wheels than stock at the wheels. Supra transmission, 4 linked rear, QA1 coilovers all around, S-Runner rear sway bar, Corbeau bucket seats, forged 5 spoke 17x9 wheels, Wilwood 12.19" 4 piston brakes, Ford 9" rear end (early bronco) 31 spline, full floater, big bearing, 3.50 gears, trac-lock. fully functioning air conditioning and cruise control....
    I just ended up remounting mine in the factory location because it'll be good for another 175k..
  7. Jun 5, 2016 at 7:46 PM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    I thought about just going back to the factory mount because its really not that hard, after second thought I did the re-locate ,
    I also found the fitting size for the hose extension to be 1/4" , NOT 5/16" hose like the OP suggested
    I got everything ready to go and the 5/16 hose was loosey goosey and could cause catastrophic failure
    I had to make another run to the auto parts store
    critical safety item to avoid injury or death:
    use only 1/4" fuel injection hose and special fuel injection hose clamps, insure routing is not rubbing anything sharp
    and because I have a 4x4 and travel gravel roads I found a relaxed position on the fender and drilled holes and bolted it through at both clamp locations with fender washers and nylock nuts
    I also carry a round point shovel for firefighting. As long as there is a good supply of soft mineral dirt it makes an excellent fire extinguisher. ( also comes in handy for snuffing abandoned campfires)
    I have put out underhood car fires before they consume the entire vehicle with a shovel and dirt long after a fire extiguisher is spent
  8. Jun 12, 2016 at 8:08 AM
    keakar
    karl
    louisiana
    don't know what to tell you, but the 5/16" hose fit very snug on my reused stock fittings but just for the sake of safety I will edit the first post accordingly
    Dustrider[QUOTED] likes this.
  9. Jun 13, 2016 at 11:09 PM
    Dustrider
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    oh yeah thanks
    sometimes factory parts can vary slightly sorry for all the drama just want to be sure no one has a fuel leak
    thanks for the mod idea
  10. Sep 1, 2016 at 9:47 PM
    Stepside01
    Stepside01 Well-Known Member
    Ohio
    01 Taco 2.7 SR5 4x4 Stepside
    I was going to attempt this but let a local shop change mine. I bought the oem filter for 31$ from camelback and he installed it for 45$. He said it was the original so I'm glad I changed it.
  11. Mar 4, 2017 at 10:30 AM
    rolandvz71
    rolandvz71 New Member
    RVz71
    1998 Tacoma 5 LUG and 2005 Tundra DC 2 wheel drive
    seems like the hose closer to the fire wall is to short to make this happen......this filter is somewhat of a PITA to rerplace.....
  12. Apr 2, 2017 at 12:15 AM
    OldBoysToys
    OldBoysToys Active Member
    Jim
    1997 Black extracab tacoma - 2002 Imperila jade extracab TRD Tacoma
    Bilstien shocks toy tec lift Brush guard / Helwig 1250 Helpers
    I can relate when I first got my 97 I couldn't find the fuel filter ,when I traced it down ,i called Toyota shop and asked how they attack changing it. Believe it or not they told me they drop the starter for access. I thought ,no way got to be a better way , then i found the inner fender irremovable plate for lack of a better word . I could go straight into the filter and using Braille change it with out dropping the starter.Not too bad ,but is a poor location ~~OBT~~
  13. Nov 4, 2017 at 3:43 PM
    chiago
    chiago Well-Known Member
    Chad
    NJ
    2001 Reg Cab Stepside 4x4
    Well Ive had the truck for bout 40k mikes and never changed the fuel filter so i thought it was about time to get'er done... Wasnt nearly as bad as i was expecting thanks to this thread... I just put her back where i found her this time but next time i will doing the relocation mod.... them mounting screws were a bit of a bitch to get into but once i found the path for my right arm it was clear sailing, no need to take off the tire as suggested in the video...Hardest and most frustrating part was locating the dropped banjo screw i knocked into the engine like an idiot... Lots of brown nasty came out so im glad i did, the truck is purring much smoother now...
    Thank you keakar and to all those who contributed...
    DJB1 likes this.
  14. Dec 6, 2017 at 1:25 PM
    irhunter
    Maine
    I am doing mine now. '96 2.4 I4. The bottom mount bolt is easy from below with the tire off, and a long extension; no u-joint required on mine. The upper bolt is a PIA; I did mine from above and from the front. Broke it loose with a 3/8" ratchet and 2" extension. Then, switched to a stubby 3/8" ratchet with the same extension to get it the rest of the way out.
    Roy
  15. Jan 20, 2018 at 7:40 AM
    #35
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    Done! With same loosening method as Roy. I'll never go back.
  16. Jan 20, 2018 at 8:16 AM
    #36
    irhunter
    Maine
    One just needs to understand you will never see that top bolt. Just reach in, and feel for it.P_20171213_135704_HDR.jpg
  17. Jan 22, 2018 at 7:14 PM
    #37
    irhunter
    Maine
    And, the bottom bolt.
  18. Jun 8, 2018 at 8:25 AM
    #38
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    @tcBob please un-sticky. Too many stickies in the first gen section.
  19. Aug 5, 2018 at 3:35 PM
    #39
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I have a 2.7L with the filter also "buried" under the throttle body. I am not relocating mine.
    That location was likely chosen to protect the filter in the event of a side impact collision. Locating it on the inner fender panel makes it much more likely it will be crushed between the UCA or strut and the TB.
    I know the fuel lines run through that area, but if you think about what would happen to a fuel line in a crash, it is likely to be bent and mostly pinched shut. Even if not, it will only output a small stream of fuel. The filter, on the other hand, is like a tiny tank and will be ruptured and instantly spread fuel.
    Don't kill the messenger. Just something to consider.
    Qball808 likes this.
  20. Aug 10, 2018 at 11:40 PM
    #40
    DJB1
    Dave
    SLC, UT
    Damn you, @Wsidr1, you are so right. At first I just glanced over your post, but the more I thought about it over the last few days, the more paranoid I got. So I put my fuel filter back in the original location. It's a whore but doesn't have to be done that often. The top bolt on the fuel filter bracket is no big deal, but the bottom bolt is a S.O.B. I used every 3/8" extension on hand to reach it without taking off the tire. I used a couple drops of superglue to hold the bolt in the socket so it didn't fall into a black hole. The bond breaks easy once the bolt is started in it's threads.
    The lower fuel filter bracket bolt is reachable like so:
    ...aaand the fuel filter is back in its OG location so hopefully I won't perish in an excruciating inferno if I'm ever hit in the front left fender:
