DIY - Build and install a Bussmann RTMR Fuse/Relay Block
Discussion in 'Technical Chat' started by tacozord, Nov 4, 2015.
  1. Aug 1, 2020 at 7:58 PM
    #961
    Zsaenz1
    Zsaenz1 Member
    2017 Silver Tacoma TRD Off road 4x4
    Weathertech floor mats, ridgid fog light kit
    This is the best post I've ever seen on TW!
    tacozord[OP] likes this.
  2. Aug 9, 2020 at 11:59 AM
    #962
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    these parts are quite expensive, i'm pricing it out and i'm already over 100$ and haven't even gotten to the connectors yet that are 11.99 a piece on Amazon not including the components to build them, and i need probably about ten sets minimum.
    looks like i found a 10 pack with all the bits for 18-20 AWG, all ill have to do is get the pins for 14-16 gauge and i should be good. also the kit comes with cable seals for 3 sizes of cable and includes the 2 sizes outlined here
    https://www.amazon.com/CNKF-Metri-p...dp/B01FALNXNE/ref=psdc_15727641_t1_B01FALOMOS.
    haven't even gotten to pricing out multiple colors,sizes of cables yet....i may have to not get multiple colors and instead just label the cables really good
    EDIT
    OK i'm realizing now that those are 2 different connectors i spoke about above. so my question now is
    why use Metri-pack connectors for the accessory connections? if weather-pack connectors are used for the switch harness? or vice versa...is it about the continuous amperage rating? i noticed the Metri-packs can handle more at 30 amps rather than the 20 for the weather pack.
    the weather pack connectors are much cheaper in the fact that i can find them in a set already at the AWG i need for accessories and dont have to buy extra pins and seals. and just buy the metri pack pins for the RTMR.
    yodataco likes this.
  3. Aug 9, 2020 at 4:02 PM
    #963
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Because the accessory harness doesn’t have matching 6-pin male and female connectors from Metripack, only Weatherpak.
    Try customconnectorkits https://www.customconnectorkits.com/#
    Also delcity https://m.delcity.net/
    but it’s true, it adds up.
  4. Aug 9, 2020 at 4:33 PM
    #964
    Stout890
    Palmdale ca
    99 prerunner sr5
    so is it acceptable to use the weather pack connectors for everything than at 20 amps continuous?
  5. Aug 9, 2020 at 10:26 PM
    #965
    yodataco
    yodataco Well-Known Member
    Alex
    Orange County, CA
    2000 4Runner
    MCM fab 3.5" LT front, OME 861 rear
    I was going to post it up here but i have some left over 18 ga wire from my build last year that I was thinking of selling. I might add some terminals if I find some.
  6. Aug 10, 2020 at 6:22 AM
    #966
    bagleboy
    Scott
    Norcal, Santa Rosa
    You can use any connectors you want if they meet the requirements for your accessories. If you know your circuits will draw less current you can use less capable connectors. Part of the op’s design philosophy was to maximize each circuit up to those connectors for the sake of flexibility but it was a choice not a requirement. Using 20A connectors limits the circuits to 20A fuses just as using a smaller wire gauge would.
  7. Aug 10, 2020 at 6:46 PM
    #967
    wally11
    wally11 Well-Known Member
    Mark
    2017 Black DCSB
  8. Aug 10, 2020 at 8:34 PM
    #968
    bagleboy
    Scott
    Norcal, Santa Rosa
    It doesn’t have relays. The bussman accommodates 5 sealed relays and 10 fuses in a waterproof enclosure with sealed wire terminals that has a smaller footprint. It’s not the only choice but if it fits the bill it’s a good choice. With the Blue Seas boxes you’ll need more space available to fit any separate relays. They both have benefits since the Blue Seas tops out at 100A total output vs the 80A of the Bussman and if you need more than 5 relays you’ll have to go outside the box anyway. But you might need to do that with either one if you need a 35A or more circuit. I needed two but have the room for the separate 40A fuses and sealed/skirted relays.
    SR-71A likes this.
  9. Aug 30, 2020 at 4:59 PM
    #969
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    So this is a great write up and all but I'm suffering from paralysis by analysis right now. I plan to add some accessories to my truck in the near future.
    • Always powered 12v power in the bed controlled by a locally mounted switch, (to power a fridge, led lights under the db cover, and accessories like charging a phone for running a small compressor)
    • Always powered Under hood lighting
    • A ignition switched circuit(s) for the aftermarket seat heaters
    • auxillary lighting later on down the road
    Is something like this appropriate for what i need, or is there a better option. Cost is not the issue, i just want to make sure i get the right thing the first time.
    Although i would love to spend the money on new tools and build this myself, i would like to buy something that is already setup or close to it in order to save the time and put it towards other projects.
  10. Aug 30, 2020 at 7:43 PM
    #970
    bagleboy
    Scott
    Norcal, Santa Rosa
    Don’t think of it as paralysis, just due diligence researching the possibilities before committing to a set of options.
    Basically if you need to switch high power circuits on/off then you need relays but if you only need a single switch to heat up an auxiliary fuse box so those circuits become active then all you need is a breaker or battery switch.
    The Bussman is one option and combines both fuses and relays but if you don’t need the relays you may be better off with one or more remote fuse panels. Simple led illumination is low enough power that it doesn’t require a relay so those aren’t needed for the engine bay and rear lighting unless you opt for high power spots for auxiliary driving lights. Likewise simple power outlets don’t need relays so you may choose to go with a few small remote fuse panels. This other thread shows a lot of the alternative choices people have gone with. https://www.tacomaworld.com/threads/show-off-your-aux-fuse-panels.308677/
    I added one Bussman in the engine bay, another in the bed, and a small fuse only panel in the cab under the cup holder of the center console for seat heaters and switch power to minimize fuse taps on the stock panels. What types of accessories you want and where you want them will help you decide where it makes the most sense to put your power source(s).
    BDSKJChris[QUOTED] likes this.
  11. Sep 3, 2020 at 7:47 AM
    #971
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  12. Sep 3, 2020 at 10:23 AM
    #972
    bagleboy
    Scott
    Norcal, Santa Rosa
    From the OP
    Take it as far as it needs to go.
    BDSKJChris and PzTank[QUOTED] like this.
  13. Sep 4, 2020 at 5:31 PM
    #973
    bagleboy
    Scott
    Norcal, Santa Rosa
    Del City is having a 25% off sale. They carry most of the stuff you need for this project from Bussman to wire. Crap, sale seems to be on cable ties.
    BDSKJChris likes this.
  14. Sep 4, 2020 at 6:49 PM
    #974
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    I have some left over parts from build. Let me know what you need and I’ll see what I can do.
  15. Sep 4, 2020 at 8:42 PM
    #975
    bagleboy
    Scott
    Norcal, Santa Rosa
    Building a second unit for the bed and short a few tangless 280 #12/10’s since I used 2 5-pin relays to reverse the current on my rear cab/cap sliders in the one up front. The op build uses 20(10 for jumpers and 5 ea for relay and fuse output)and I used 22. The extra 2 provide a ground connection for the 87a pins.
  16. Sep 4, 2020 at 9:31 PM
    #976
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    I'd be interested in spare parts. I'm not ready to build mine yet so if anyone who is can benefit from your spares, please give preference to them.
  17. Sep 4, 2020 at 9:41 PM
    #977
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Wow, just discovered this thread. I was wondering why more people didn't build a system like this! I am using GEP with micro relays as opposed to the bussman, but same concept. Good to see it's catching on. I will have to sit down and read through this thread to get up to speed.
    Are you sure you need tangless? Like I said, I haven't read through this thread, so I'm not sure what all it is calling for, but tangless isn't that common. I know I have some lying around. Do they have to be 10/12 or would 12/14 be okay? I'll see what I have.
    EDIT: The tangless ones I have are 12/14. If you need a few, DM me your address. I'll send you a few if those will work for you.
    saundern and daveeasa like this.
  18. Sep 4, 2020 at 10:41 PM
    #978
    bagleboy
    Scott
    Norcal, Santa Rosa
    The Bussman uses female tangless to receive fuses and relays. The Metripack 280 connectors use m/f tanged terminals. I’ll send a message since 12/14 us what I’m using on the second unit, thanks.
  19. Sep 4, 2020 at 10:55 PM
    #979
    Puppypunter
    Johnny
    2019 Black SR
    I didn’t realize bussman used tangless. Good to know. Not many things use those that I’ve dealt with ( that’s why I have a crap load extra lying around all these years)
  20. Sep 11, 2020 at 4:44 PM
    #980
    BDSKJChris
    Albany, NY
    Decided to build this instead of buying one. Anyone have a current source for txl 10 awg by the foot or in a spool 100' or less?
