DIY - CHEAP BEEP on lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Johnson8537, Apr 25, 2009.
  1. Sep 12, 2009 at 8:58 AM
    #81
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have the factory alarm?
  2. Sep 12, 2009 at 8:59 AM
    #82
    Kappes03
    Kappes03 Legend of the UG
    Colorado
    2014 Tundra CM
    Yea, guess that's it eh... Is there way to get it not to honk? Haha
  3. Sep 13, 2009 at 3:42 PM
    #83
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Great! Been thinking about doing this mod. Im going to use this post for the steps. Thanks!!
  4. Sep 14, 2009 at 3:54 PM
    #84
    jsa
    jsa New Member
    jeff
    canada
    08 tacoma trd
    will this work on an 08? i took out the coin storage tray to get to the harnesses and the wiring was different. same harnesses but different wires in different locations and no blue-red to be found. has anyone figured out which wire on the 08?
    thanks, jeff
  5. Sep 14, 2009 at 4:21 PM
    #85
    dmb
    dmb Well-Known Member
    Boise, ID
    My 07 setup is pictured here. I did not have the blue/pink wire going to the fuse box. I found mine in the wire bundle behind the kick panel. It's probably where yours is.
  6. Sep 14, 2009 at 7:10 PM
    #86
    jsa
    jsa New Member
    jeff
    canada
    08 tacoma trd
    Unfortunately that wire didnt work for my 08 (access cab, manual trans, trd).
    thanks anyways!
  7. Oct 8, 2009 at 3:19 PM
    #87
    garbal
    garbal Member
    This is an awesome thread by the way... thank you for steering us in the right direction.
    Unfortunately my fuse box was different than the one in the pictures at the start of this tread ( I have an 07 TRD ) so I had to do some monkeying around to find the blue with Pink wire... I managed to tap into it on the right kick plate. It's very easy to find there... also there's a bare plug/grommet on the right side of the firewall which gives you access to the inside of the cab. Pull that plug, poke through the material with a pick or screwdriver then fish your wire through.
    Once you have your location for the buzzer, cut that length of wire... drill a hole in the rubber plug then fish our wire through from the inside out... grommet goes back in easily and off you go to hooking up your beeper.
    I used the beeper recommended at the start of the thread, grounded to the body and away you go.. beep beep on Lock... Awesome.
    I love this thing... I must have locked and unlocked it about 40 times... grinned every time.
    Now I know for sure the damn thing is locked!
    Garr.
  8. Dec 14, 2009 at 8:16 PM
    #88
    tacofan
    tacofan Well-Known Member
    Des Moines
    DR Coilovers
    Here is a diagram of a relay switch. It should work just fine to disable the beep when the ignition is on. You will just need to grab a 12v power source that turns on with your ignition. Make sure you connect it to the leg that opens the coil on the relay.
  9. Dec 14, 2009 at 8:41 PM
    #89
    braggman7
    braggman7 Well-Known Member
    GA
    '23 Trail Edition
    my 2010 beeps with no mod...did the dealer throw this on without telling me or do the 2010s come standard with the beep?
  10. Feb 17, 2010 at 4:53 PM
    #90
    Abe Froman
    Abe Froman The Sausage King of Chicago
    Fayetteville, NC
    2023 SR DCSB 4x4, White
    Here you go. This is the $10 jobber from radio shack.
    http://www.youtube.com/watch?v=CmM3_H4Jo3Y
    You can hear it's not exactly the same every time. it seems to pick up where ever it left off in the cycle last time. By the way, you can't tell from the vid, but this thing is insanely loud. I'd originally planned to mount it in/near the grill so it could project, but after hooking it up it was clear that there was no need for that. I'm now looking for a way to attenuate it a bit - maybe a trojan magnum? lol
    Thanks, OP for the write up! great job.
  11. Mar 10, 2010 at 11:02 PM
    #91
    krylon153
    krylon153 Active Member
    Vancouver, BC
    '10 comes standard
  12. Aug 11, 2010 at 5:34 PM
    #92
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    so when the alarm goes off, the horn doesnt honk it just beeps?
  13. Sep 27, 2010 at 10:14 AM
    #93
    AZ~Taco
    AZ~Taco crack rules!!
    J.R.
    Goodyear, AZ
    06 TRD OR DC PreRun
    TRD CAI & Magnaflow exhaust, 5100s f/r, ProComp AAL, MagLight storage on driver seat, 5th gen iPod adapter by Grom Audio & shitty Toyota roof rack
    will you send this to me by PM? The images have been deleted on the post.
  14. Nov 2, 2010 at 8:47 AM
    #94
    TacohaulicJ
    TacohaulicJ Outside outside the box
    Jake
    South Louisiana
    Fresh PreRunner SR5
    TRD CAI, Magnaflow muffler system w/ Black chrome tip, Black chrome accents, URD MAF Calibrator, Smoked out Taillights Mod, Fire engine red painted calipers
    realizing i am behind a lot of those who've done this mod already .. is there any post that has pics still posted? i'd like to complete this mod, but Im very visual and would like to see it before attempting... thanks in advance
  15. Nov 2, 2010 at 8:56 AM
    #95
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    Sub'd.
  16. Jan 24, 2011 at 5:52 AM
    #96
    Goez2FST
    Goez2FST Well-Known Member
    Andrew
    Mobile, AL
    06 Tacoma DC TRD sport
    3" Toytec Ultimate Lift 285/65/18 Nitto Trail Grapplers 18x9 XD Addicts N-Fab Step bars Window Tint all the way around TRD seat covers Rolling Big Power Grille (Black with chrome studs) Image Dynamics XS65 Component speakers Image Dynamics CTX65 Coaxial Speakers Alpine CDA-105 Head Unit Alpine PDX 4.100 amplifier OEM Roof Racks H.I.D. Headlights & Fogs 8K Window Visors Image Dynamics 10IDQv3 Subwoofer JL XD 600/1 Mr. Marv Custom Subwoofer Box w/ Amp rack
    Thinking about doing this but the pictures dont seem to be working?
  17. Apr 2, 2011 at 5:22 PM
    #97
    camit34
    camit34 Well-Known Member
    Aaron
    CO
    '08 Mostly Stock
    Worked like a charm... Thanks for the write up!!!
  18. Aug 15, 2011 at 2:43 PM
    #98
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Is there any chance we could re-up the photos,
  19. Sep 2, 2011 at 4:13 PM
    #99
    djmatt8787
    djmatt8787 New Member
    HOU TX
    08 TRD off-road stock (for now)
    oh NOOO all the pictures are gone! this is my first tacoma, and the missing lock beep is a little disappointing....
    this will be my first mod.
    any suggestions to get pictures on a (3 year old) thread?
  20. Jul 9, 2012 at 4:54 PM
    #100
    Johnson8537
    Johnson8537 [OP] Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Sorry I sold the trucks a few years ago and the photobucket pics got deleted. :( I forgot I had them posted.
    If someone wants to come to southern Oregon I can help and retake more pics!!
