DIY: Differential Breather Extension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toy4Life, Sep 25, 2008.
  1. Sep 25, 2008 at 9:35 PM
    Toy4Life
    Toy4Life [OP] 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Relocating the rear differential breather is an easy and inexpensive way to help prevent costly damage to the rear differential. As air expands and contracts from temperature changes within the rear differential, the breather allows the differential to "breathe". However, with the stock location of the breather, it is possible for the differential to "inhale" water in certain situations. By relocating the breather to a higher position on the vehicle, this can be prevented.
    *Perform at your own Risk*
    Materials:
    8ft 1/4" rubber fuel line
    1 "union" (Toyota part# 9040451026)
    2 small hose clamps
    1 small in-line fuel filter
    2-3 plastic zip ties
    Tools:
    14mm box/open wrench
    10mm box/open wrench
    1/4" socket/ratchet
    8mm socket/ratchet
    cordless drill w/ 1/4" drill bit
    wire cutters
    Loosen the breather with the 14mm wrench. Before completely removing the breather, clean the area around it to prevent any debris from entering the differential.
    With the 10mm wrench, install the "union" in place of the breather. Note that the "union" will not tighten down flush with the surface of the differential housing.
    With one of the hose clamps on the end of the hose, slide one end of the hose over the nipple on the "union" and tighten the clamp. (I used the 1/4" ratchet for the clamps because I tend to stab myself with screwdrivers:eek:)
    Run the hose along the e-locker cable(anchor with zip ties) over the frame rail to the fuel filler neck. Leave adequate slack in the hose above the differential to allow for suspension flex.
    Using the 8mm ratchet, remove the 4 bolts that secure the plastic shield around the fuel cap. Remove the fuel cap so you can slide the shield off of the filler neck. Pull the hose up and out through the fuel cap access door. Drill a 1/4" hole in the plastic shield where you want to attach the fuel filter and the other end of the hose. I chose the right side of the shield, below the fuel door catch.
    Poke one end of the fuel filter through the drilled hole. Cut off any excess hose. Attach the hose with the clamp to the fuel filter at the back of the shield. Re-attach shield. Enjoy a little peace of mind!
    Note: I trimmed off about 1/2" of nipple from the fuel filter so it would not interfere with removing the fuel cap.
    GQ7227, chrslefty, MattMan01 and 4 others like this.
  2. Sep 25, 2008 at 9:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    awesome job buddy!!! im doing mine this weekend!!:)
  3. Sep 26, 2008 at 6:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey Chad....did you use any teflon tape when you installed the union to the rear diff housing?? just wondering,cause if so, i gotta get a roll of it.
  4. Sep 26, 2008 at 7:00 PM
    Shadow-Warrior
    Shadow-Warrior Well-Known Member
    Arkansas
    07 TRD FJ Crusier
    To Many to list here
    Jimmyrace and ClevSix like this.
  5. Sep 26, 2008 at 7:39 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Thanks Mike. I only did the rear diff. for now because I need to replace some leaking seals back there. After checking out your write up, I went out and climbed under my truck to look for the e-locker breather and can't seem to find one. Do the 1st gen e-lockers have a breather?
  6. Sep 27, 2008 at 2:45 AM
    Shadow-Warrior
    Arkansas
    07 TRD FJ Crusier
    I'm not sure...do you have a Schematic on your vehicle?
  7. Sep 27, 2008 at 5:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The rear diff breather is the only one. The E-locker doesnt have its own breather.
  8. Sep 27, 2008 at 8:21 AM
    Shadow-Warrior
    Arkansas
    07 TRD FJ Crusier
    besides the tranny, front diff and transfer case. ;)
  9. Sep 29, 2008 at 10:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did mine just a little while ago......took about 20 minutes. i gotta get another filter for the end of the fuel line though....the one i got was the smallest i could find last night, but closing the fuel door/opening it is a bitch. gonna get a different filter this afternoon.
    good mod.......quick and easy.
  10. Sep 29, 2008 at 10:50 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    If you look at the last pic in my write-up, you can see an xtra hole. That was the first place I wanted to put the filter, but it got in the way of the prongs on the fuel door when I tried to close it. Fortunately, I left a couple inches xtra of hose just in case.....good thing:rolleyes:
  11. Sep 29, 2008 at 10:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Chad...where did you get that small filter you used?? we have lots of them at the shop i work at, but since i am here till after my surgery...cant go get one. thats about the size i need, plus its tapered a bit. mine is a drum type fuel filter, it works, but a bit too big.
  12. Sep 29, 2008 at 11:07 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    I got that at the local family owned parts store. The brand is "Prime Line", 1/4" in-line clear plastic fuel filter (part# 7-02357-1). It is for Briggs/Stratton, John Deere. Kohler, Snapper, and Troy Bilt. I imagine anyone that carries lawnmower stuff would have something similar.
  13. Sep 29, 2008 at 11:17 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ok, cool. i'll go look at walmart or pepboys in a little bit!! we use them at our shop on the old yamaha g1 carts!!
  14. Nov 1, 2008 at 7:34 PM
    Tacoma02TRD
    Tacoma02TRD Well-Known Member
    Walla Walla WA/ Klamath Falls OR
    02 Tacoma TRD
    3inch Revtech lift,Flowmaster Muffler, K&N cold air intake, 33x12.5 Maxxis Bighorns, TRD stock locker, Hella 500 Fog lights, Scanguage II, 6k HIDs, Painted Black Rims
    I think I'm gonna have to do this with my Tacoma some weekend. Thanks for all the information.
  15. Nov 1, 2008 at 7:37 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Its cheap and easy. So simple its a wonder they don't come like that factory.
  16. Dec 2, 2008 at 7:55 AM
    closha63
    closha63 QuickShift
    York Springs, PA
    04 SR5 TRD
    3'' Though Country Suspension lift, Grey Wire Mod, Cold Air Intake, Tundra TRD Exhaust Tail pipe ( all custom pipe) Sounds real mean!! Huculiner bed protectant, Rear diff. Breather Mod.
    Hey can someone put up some pictures
  17. Dec 2, 2008 at 11:38 AM
    Toy4Life
    Chad
    Slippery Rock, PA
    :eek:Oops! I deleted a bunch of pictures from photobucket a while back, didn't think about where else those pictures were being displayed. I can take some new ones, but won't be able to duplicate all the pictures I had up originally.
  18. Dec 3, 2008 at 11:12 AM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    Got some extra time this week, gonna order the parts for the extension. Im wanting to go ahead and get everything that needs to be done though, so do I need to do the tranny, front diff and transfer case? I remember reading a while back that some already have an extension from the factory. Also, do I need the union from toyota for each of them, and is it the same part # for each?
    Thanks
  19. Dec 4, 2008 at 8:20 AM
    311offroad
    Milledgeville, GA
    ^^^ bump. wanna order these parts today
  20. Dec 4, 2008 at 8:11 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I couldn't tell you for sure. For now, I only did the rear differential. Also, I have a first gen not a second gen. The rear diff breather parts should be the same as the ones I have listed.
