DIY: Differential Breather Extension
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toy4Life, Sep 25, 2008.
  1. Jan 31, 2009 at 6:29 PM
    firesniffer2001
    firesniffer2001 New Member
    Spotsylvania,Va
    1999 TRD Tacoma
    3" toytec coils in front add a leaf in rear shocks on all corners 32x11.50 BFG on american racing 8x15
    what is the uion size and were did you get it?
  2. Jan 31, 2009 at 6:35 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    1 "union" (Toyota part# 9040451026)
    Reread the post,he has all the ingredients there for you. Doesn't get any easier. Unless you get Chris to do it and then all you have to do is hold the camera and the eyewash.
  3. Feb 1, 2009 at 6:32 AM
    firesniffer2001
    Spotsylvania,Va
    1999 TRD Tacoma
    Thanks I missed it.
  4. Mar 4, 2009 at 12:30 AM
    miked
    miked New Member
    oregon
    2007 access cab 4x4 trd sport stock
    stock
    Is it necessary to put teflon tape on the camary union?Also should it have any threads showing or should it tighten all the way down?Thanks!
  5. Apr 22, 2009 at 1:04 PM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    That looks like a lawn mower fuel filter. Look in the lawn and garden section of any hardware store, not in the automotive section.
  6. Jun 15, 2009 at 2:37 PM
    Slick Nick
    Slick Nick Taco-addicted
    Vista, Ca
    99 SR5
    Lots
    good writeup :thumbsup:
  7. Jul 22, 2009 at 9:44 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    done. the only thing that was a PITA were the little 8mm bolts holding the splash guard at the top of the filler neck. On a 96, my guess is that theyve never been touched so they were rusted up pretty well. I broke 3 of 4 and had to drill them out, then i just replaced them with 10mm screws. Whatever works.
  8. Nov 16, 2009 at 9:30 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    What is the advantage to locating the filter/hose vent in the gas filler area?
  9. Nov 16, 2009 at 10:07 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    the very first post had the answer,which was this:
    "As air expands and contracts from temperature changes within the rear differential, the breather allows the differential to "breathe". However, with the stock location of the breather, it is possible for the differential to "inhale" water in certain situations. By relocating the breather to a higher position on the vehicle, this can be prevented."
    Welcome to Tacoma World!!:)
  10. Nov 16, 2009 at 11:29 AM
    BTO
    California
    Hey Rob1,
    Yes, that location does make it high and out of any water but I was thinking it may be in the way? I could see myself banging it with a gas pump nozzle. Maybe the use of something smaller than the fuel filter like a tiny orifice or the original diff breather?
  11. Jan 28, 2010 at 8:56 PM
    trdkamuri51o
    trdkamuri51o Active Member
    going to do this in about 2 weeks.. toyota stock the part regularly?? and what did it cost you guys??
  12. Feb 20, 2010 at 11:30 PM
    vicstacoma
    vicstacoma Guest
    yes you can use the original diff breather at the top end of the fuel line... that is what most people do... no need to be searching for any filters!
  13. Feb 20, 2010 at 11:32 PM
    vicstacoma
    vicstacoma Guest
    at the dealership around they didn't have it in stock, but they were able to get it the next day.. it was about $7.
  14. Mar 16, 2010 at 2:45 PM
    TKGN1
    TKGN1 Well-Known Member
    Todd
    College Station, TX
    '01 DC TRD 4wd
    SAS on links, SC, flat bed
    I did this mod last week and went with a simular set-up, but used these parts:
    1/8" BSPP male to 1/8" NPT female from McMaster-Carr, example: http://www.mcmaster.com/#4936k117/=76nzfv
    Remove your stock breather and screw this piece in place.
    Then get a 1/8" NPT male to 3/8" hose barb, example: http://www.mcmaster.com/#5350k35/=76o237
    screw this piece into the 1/8" NPT female fitting
    using a couple feet of 3/8" fuel line I ran it up to the fuel tank door as mentioned and slipped the hose onto the stock breather and clamped it on
    Just a side note, the fitting in the rearend is 1/8 BSPP (1/8-28) not to be confused with 1/8 NPT (1/8-27). They are very simular but you can't screw a 1/8 NPT into the breather hole in the axle.
    HTH
    rybern likes this.
  15. May 10, 2010 at 2:55 PM
    #35
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Here is a link to info on the breathers I found on the top of the transmission on a 04 Tacoma 5 speed 4X4 and how to raise them higher.
    This was posted over in Technical Chat but it should be here so we can have info on the transmission breathers here for 1st gens. As far as I know the transmission is the only breathers that will still will need to be raised after you do the rear diff breather.:D
    http://www.tacomaworld.com/forum/technical-chat/89283-breathers-diff-transfer-transmission.html
  16. Jun 20, 2010 at 11:27 AM
    #36
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
  17. Jul 15, 2010 at 6:22 PM
    #37
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    anyone order the inline fuel filter from autoparts2020? cant seem to find it here in hawaii
  18. Jul 15, 2010 at 6:32 PM
    #38
    supremetaco2
    04inacoma
    where did you guys get your 1/4" fuel line from??? cant seem to find it anywhere lol
  19. Jul 15, 2010 at 6:33 PM
    #39
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    any auto parts store close to you should have plenty of it.
  20. Jul 15, 2010 at 6:39 PM
    #40
    supremetaco2
    04inacoma
    ok maybe i am trying the wrong department... hmmm
