DIY Disable door ajar chime permanently
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lukem80, May 13, 2017.
  1. May 13, 2017 at 12:49 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I think I just came up with a much easier fix.
    The switch that tells the 'puter the driver's door is open is located after of the door opening. It's held in place by a large-headed torx screw. There's one hot wire that goes to the switch and the torx screw provides the ground.
    I made a rubber washer out of a bicycle tube and put it between the screw and switch.
    Bingo.
    SB
    Edit: You're dome light doesn't turn on and your headlights won't turn off on auto when you exit the truck.
  2. May 13, 2017 at 2:02 PM
    sleekride
    sleekride Well-Known Member
    Tampa, FL
    '17 TRD OR access long bed
    Black Rhino 18” wheels
    ^ care to share a pic of the location you are referring to?
    9TRDTCO likes this.
  3. May 13, 2017 at 2:14 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Right by your VIN.
    SB
    Edit (again).... don't do this if you want your dome light to turn on and your headlights to turn off...
    SlizzyMcSlizFace and riz_atx like this.
  4. May 13, 2017 at 2:36 PM
    AustinNative
    AustinNative Swollen Member
    ATX
    2017 MGM TRD Sport DCSB
    Maxtrac spindles OME 885s Bilstein 5100s all around (adjustable front/extended length rears) Maxtrac rear blocks Headstrong Taco lean spacer OME CBD SS brake lines InsaneFab CMC 18x12 Fuel Hostage 35x12.50 Maxxis AT 1.25" Spidertrax spacers in the rear Llumar Ceramic Tint (5% Rears & Back / 18% Fronts / 50% Windshield) Toyota Tri-Fold bed cover and OEM bed mat Triple Black Clazzio seat covers WeatherTech laser fit or whatever the fuck they call em Probably other stuff...
    You sir, are a frikkin champion.
    File IFR likes this.
  5. May 13, 2017 at 2:38 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Could you edit your post? Maybe something like, You sir, are a frikkin STUD." Or maybe, "stud of all studs."
    I always wanted to be a stud.
    SB
  6. May 13, 2017 at 2:43 PM
    sleekride
    Tampa, FL
    Well done Sage.
    riz_atx likes this.
  7. May 13, 2017 at 3:11 PM
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
    But does that disable the door open / interior lights on feature?
    I just want zero beeps. Gonna get that annoying assed little speaker out and stomp it into bits. Only had the truck 2 weeks, and have had my fill of that annoying shit already.
  8. May 13, 2017 at 3:32 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Good Point ! Also alarm maybe ?
  9. May 13, 2017 at 4:08 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Damn good question. Ask me later tonight.
    SB
  10. May 13, 2017 at 4:11 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    didn't think of that, good idea.
    riz_atx[QUOTED] likes this.
  11. May 13, 2017 at 4:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    SlizzyMcSlizFace likes this.
  12. May 13, 2017 at 6:10 PM
    Joe23
    Have to test that button thing tomorrow. Cause my main issue with the ding is that when you shut off the truck after opening the door. Really do not understand why it dings with that.
    Really drove me crazy when I was doing some electrical stuff and kept turning the truck on and off to test it, and the thing would ding but I couldn't close the door because the stuff I was working on was in the sill portion so couldn't close the door
  13. May 13, 2017 at 6:24 PM
    climbhigher23
    climbhigher23 Well-Known Member
    SoCal
    2017 QS TRD Off-Road 4x4
    2.5" King w/Adj 285/70/17 Wildpeaks Ray 10's
    This is the simplest way of making it stop. Just press it once and done. No breaking or cutting things.
    Remember if you disable your door pin you may be disabling your alarm.
    riz_atx[QUOTED] and Joe23 like this.
  14. May 13, 2017 at 6:41 PM
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    What else can the techstream do in regards to "custom options" on the 2nd gen? I never bothered to hook it up at work before and check
  15. May 13, 2017 at 7:30 PM
    #35
    Hiluxski
    Ventura California
    I tried the press it once thing and soon as I let my finger off. it dings
  16. May 13, 2017 at 7:32 PM
    #36
    climbhigher23
    SoCal
    Are your lights on? That would make it chime. Otherwise it should shut off.
  17. May 13, 2017 at 7:47 PM
    #37
    Hiluxski
    Ventura California
    Thanks I'll try , I have a Access cab if that matters
  18. May 13, 2017 at 9:08 PM
    #38
    Sagebrush
    Gens 1, 2, 3, and 4
    Hold you're horses.
    I just checked it. The dome light doesn't come on and after I turn the truck on (with the headlight switch set on auto), one I open and step out... the lights don't turn off automatically.
    SCRATCH MY BRILLIANT IDEA.
    Sage
  19. May 13, 2017 at 9:27 PM
    #39
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Umm yeah.
    That's what tells the puter the doors open...
    Herniator likes this.
  20. May 14, 2017 at 7:01 AM
    #40
    lukem80
    lukem80 [OP] Member
    Montgomery Alabama
    2017 Tacoma OR 4x4
    My solution works everytime you open the door and requires no tape and no thought process. Have you ever opened the door while in gear? The buzzer goes crazy (I only open the door in gear during some trail riding to see where the lines were). You still get the warnings via the screen in the cluster just not the sound.
    I've never disconnected a buzzer before.. in any car I've had. Had a 86, 04, 11 Toyota truck before this one and I don't require all this electronic shit to get me from point a to b, but I'm starting to enjoy the radio (except for the slick volume knob)!!
    Just found this! https://priuschat.com/threads/fix-those-little-slick-radio-knobs-cheap.178397/
    Sagebrush likes this.
