DIY DTL MOD under $20 bucks write Up How too..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter7, Dec 25, 2016.
  1. Dec 25, 2016 at 5:30 PM
    Hunter7
    Hunter7 [OP] Well-Known Member
    Paul
    2015 tacoma double cab long bed
    Step 1:
    Remove the plastic Trim piece under the headlights. You can do this by carefully prying out the side closest to the grill, then carefully wiggle the far side towards the center of the truck. and it will Pop off.
    Step 2: If you look at the back side of the trim piece you will see a grid type section' I use a dremel tool to cut these out flush, To make Room for the led's.Fig 1&2
    Step:3 I drew a line right over where the pieces I cut out were and directly in the center of each piece. see fig :3
    Fig 3:027.jpg Drill a tiny pilot hole where as seen in fig :3
    Step:4 carefully drill the pilot holes
    then drill the correct size to accept the led threaded shank: NOTE:
    DRILL FROM THE FINISHED SIDE OF TRIM PLATE:
    Step :4 Trim each led light wire leaving about 4" , Insert all led's and tighten the supplied Nuts on the unfinished side of trim plate. as seen in Fig: 4.&5
    Fig:4
    Fig: 5035.jpg
    Step: 6 carefully strip the black outer insulation about 2" be careful the red and black wires under this insulation are extremely thin. see fig:6
    FIG: 6036.jpg
    Step: 7 very very carefully strip about 1/2" of each red and each black led wire. also refer to step FIG 6:
    Step :8 take two pieces of wire . like 14 ga supple insulation is easier to work with. Cut approximately 3ft of each one will be + POS the other will be - Neg.
    Step:9 strip the end of the wire and I soldered the pos + to all the red wires coning from the leds, then do the same with the other wire solder all the - neg from the led's See Fig 7
    fig: 7 038.jpg
    FIG: 7: B 040.jpg
    Step :9 After all wires are soldered or taped , I wire tied each one for strength. as seen in FIG:7B
    Then simply bench test, By connecting the + pos wire to 12 V pos supply and the - Neg wire to the neg Ground , All your leds should light. as seen in Fig: 8
    FIG: 8045.jpg
    FIG 8:B044.jpg
    Step 10: carefully reinstall the Plastic trim on your vehicle.. I connected my power source to my fogs , I may run a seperate switch in the future. I simply removed the fog bulb undid the clips and connected POS+ to Pos fog then Neg from new drl to Neg fog. See Fig :9
    Fig: 9070.jpg , then snake wires back down install fog bulb back in socket and install socket back in fog, Or run to a separate switch. If you do run to a separate switch make sure you add a fuse in -line.
    Step 11: time to secure all wires and light them up ..... see pix below
    here is the link for the Led lights ,http://www.ebay.com/itm/281987848429
  2. Dec 25, 2016 at 5:36 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Awesome! Would love to do this on my rig.
    ChadsPride likes this.
  3. Dec 25, 2016 at 5:42 PM
    Hunter7
    Paul
    simple cheap Mod and very easy just a bit time consuming because I always solder everything I can... I was looking at the kits on line they want like $180.00 dollars NOT!
  4. Dec 25, 2016 at 8:20 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Great write up! Ill most likely be doing this in the future. This should definitely be in the cheap/free mods thread! Ill put a link in there for this write up, good job.
    https://www.tacomaworld.com/threads/cheap-free-mods.4838/
    stbear and Hunter7[QUOTED][OP] like this.
  5. Dec 25, 2016 at 8:51 PM
    Hunter7
    Paul
    Thanks I did not know If a Mod had to put it there... Please feel free
  6. Dec 25, 2016 at 9:00 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
  7. Dec 25, 2016 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  8. Dec 26, 2016 at 2:35 PM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    Adding to my to-do list. Cool!!!
  9. Dec 29, 2016 at 12:33 PM
    steveoh
    steveoh Well-Known Member
    SLC
    08 ACLB SR5 4x4
    has anyone done this to say a 2008 that doesn't have DTRL? I suppose you could wire it up to the middle light setting or always on...
  10. Jan 12, 2018 at 2:19 PM
    TacoLou
    TacoLou Member
    Louie
    Ocala, FL
    '07 Silver TRD Prerunner SR5
    Tail lights and interior lights so far but I'm looking to go LEDs all the way around. I like the hood light strip and I'm considering it.
    Can't find those LEDs. I may not be looking in the right place.
  11. Jan 16, 2018 at 10:47 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
  12. Jan 18, 2018 at 10:43 AM
    TacoLou
    TacoLou Member
    Louie
    Ocala, FL
  13. Jun 18, 2020 at 7:40 AM
    LightedTaco4x4
    LightedTaco4x4 Active Member
    Andrew
    Eau Claire Wi.
    2005 TRD SR5 SPORT V6 Double cab.
    Map light mod, Fogs anytime, skid plate chrome painted, LED clearance lights, Hella Rallye 4000 Halogen Chrome off road lights, bed lights, interior LED cockpit lights, mud flaps, temp/compass repair. FJ cruiser alloy wheels, Air lift Air bags! and many more coming!
    Where can I find those LEDs ? I would like to add them but none of the links above work anymore.
