DIY: Fog Lights on with High Beams (Brights) FREE!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ostrichsak, Apr 11, 2012.
  1. Feb 8, 2013 at 10:22 PM
    #81
    Ostrichsak
    Ostrichsak [OP] Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Scotch Locks... Booyah! I use those when I'm only going to have the car for a few more months. :D
  2. Feb 8, 2013 at 10:33 PM
    #82
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    LOL!
    I prefer adhesive-lined shrink tubing, but to use that requires the ability to slip the tubing over the wire and get it far enough away so the soldering heat doesn't shrink it.
    That can be a problem under the dash where not only is the harness stuffed and wrapped, but there is also not enough slack to actually cut the wire, strip, then pull an inch out of the harness to get enough overlap to twist and solder without stressing the connection.
    So the back up is to strip an inch, wrap and solder, then tape with 3M 33, and I'll then secure the tape with a small zip-tie just to ensure it doesn't unwrap from the heat in the summer.
  3. May 28, 2013 at 6:25 PM
    #83
    mxdude91
    mxdude91 Member
    Richmond,VA
    2008 Base SR5 4.0L 4x4
    Debadged,Shorten up the front mudflaps 4in,Plastidiped the front emblem,Weathertech Mats/Seatcovers,Tinted front windows
    Why didnt i do this when i bought the truck.Works Perfect,ill let you know if issues arise.thanks op
  4. May 28, 2013 at 6:43 PM
    #84
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    Did you do this or a write up of this.. this is what i would like...
  5. Jun 14, 2013 at 10:35 AM
    #85
    tyaker
    tyaker Well-Known Member
    Southern Oregon
    '11 4x4 DCLB TRD Sport
    Leveled, Dakar HD rear leafs, Ride-Rites
    Thanks for the killer easy mod. Didn't even finish my beer. New way to piss off oncoming drivers (when I forget to flick 'em off)!! :cheers: Will be testing this out extensively to see if there are any fails...
  6. Nov 11, 2013 at 12:49 PM
    #86
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    I'm about to do it on a 2013 as soon as I get home (I realize your post is a month old almost).
    I'm used to HID's and the lows + fogs aren't bad... the highs throw but I can't see right in front of me. Thanks for the post!
  7. Nov 11, 2013 at 4:00 PM
    #87
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Copied from http://www.tacomaworld.com/forum/2nd-gen-tacomas/296340-2013-fog-light-anytime-mod.html
  8. Nov 11, 2013 at 7:28 PM
    #88
    justchil
    Andy
    WV
    13 AC TRD OR
    I was under the assumption these were two different mods. This thread being fogs stay on with highbeams... the other (the link you posted) being "fogs always on".
    I'm looking to keep the fog lights on with high beams and if the lows beams are on as well that's even better as long as it's safe.
    I don't have any need to have the fogs on by themselves or with the parking lights... I just need to be able to see up close when my high beams are on lol. I may be a bit confused and will re-read both threads. It sounds like this can be achieved either method if I'm not mistaken.
  9. Nov 12, 2013 at 10:31 AM
    #89
    Ostrichsak
    Jer
    The best way to describe this mod is that your fogs will come on with the lights the way the normally with (when your fog switch is left on) and when your brights are activated your fogs do NOT turn off. The fogs will NOT come on w/o your headlights and therefore you don't have to remember to turn them off like the other version of this mod that uses a jumper wire. So the difference is that mod will allow you to run your fog lights at ANY time but you also need to remember to turn it off when you don't want them on.
  10. Nov 12, 2013 at 3:45 PM
    #90
    justchil
    Andy
    WV
    13 AC TRD OR
    That's what I thought. Mod is done and works perfect. Now I have highs + lows + fogs :) Cheers!
    Dirtwolf likes this.
  11. Nov 12, 2013 at 4:24 PM
    #91
    J0HN_R1
    Calgary, Alberta
    That is absolutely correct... I can run my fogs with low or high beam.
    My fog-light switch still works too, I can turn them off anytime.
    :cool:
  12. Nov 12, 2013 at 5:01 PM
    #92
    Ostrichsak
    Jer
    With the caveat that with the other method you MUST turn the off with the fog light switch since they work independently of the headlights. I basically want my fogs on anytime my headlights are on so I leave my fog light switch on and haven't had to touch it since I did this mod. One less thing to worry about.
  13. Nov 13, 2013 at 1:23 AM
    #93
    J0HN_R1
    Calgary, Alberta
    I just prefer to have the ability to switch them on or off.
  14. Nov 13, 2013 at 3:37 AM
    #94
    justchil
    Andy
    WV
    13 AC TRD OR
    Mine switch on and off just fine... at least with the headlights which is the only time I need them anyways. It just depends on what you want vs which mod you should do.
  15. Nov 13, 2013 at 8:00 AM
    #95
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Man, so many posts about fog lights. I haz much confused. Going to leave my fogs stock I think!
    DJ IslandBoy likes this.
  16. Nov 13, 2013 at 9:09 AM
    #96
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    ummm there is a concern of this mod.. Some state have laws stating cant have fog lights on while high beam on. NY state law stated that. So good luck with tickets and court fees..
  17. Nov 13, 2013 at 10:37 AM
    #97
    Ostrichsak
    Jer
    As with ALL mods it's important to know your laws at the local, state & federal level and modify according to what the law allows. Neither I nor this site are responsible for someone's decision to break the law. It's called personal responsibility and I think we're all mature enough to make such decisions by ourselves so that's why it was never spelled out since it should just be common sense. In today's climate where zero personal responsibility is taught though I have to wonder....
  18. Nov 13, 2013 at 11:47 AM
    #98
    InSight Retrofits
    InSight Retrofits Closed
    Yes that is the law, but it's stupid.
    Alright so I'm driving alone on the highway and I have my foglights AND highbeams on right?
    I see a car coming and flick them back to low beam, with my fogs still on (which is the stock "legal" way) What's the problem here?
    As long as you aren't high beaming and fog lighting people at the same time there is no issue.
  19. Nov 13, 2013 at 3:52 PM
    #99
    western88
    western88 Chris b.
    ny countryside
    I agreed that its everyone understands that doing the mods must take risks but use common sense.
    A7.... far as concern longs no other in coming drivers its fine.. but going on the highway.. the cops can sure spot you away.. depends where they are hiding/.
  20. Nov 13, 2013 at 5:00 PM
    #100
    Ostrichsak
    Jer
    Let's not turn this how to thread into a political discussion. All that needs to be said regarding checking your local laws has been stated.
    Back to the topic at hand.
