DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. Nov 16, 2015 at 11:39 AM
    #441
    MPOW33R
    MPOW33R Well-Known Member
    MoMo
    East Bay, California
    A Few Air Cooled Porsche, A Few Water Cooled Porsche, 2018 Mag Gray Limited 4x4 (TRD Pro Rep 6/2023) 17 Mag Gray DC SB TRD Sport Premium JBL NAV Tech | 10 Mag Gray DC SB TRD Off Road JLB Audio
    10' TRD Beadlocks, LTX MS/2s , Skid Plate, Roof Rack , Tonneau, Full Stereo System w.DVD 17' TRD Pro 17s, TRD PRO Grill, TRD Pro Rigid Fog Lights, TRD Pro Tails, TRD Pro Knob, TRD Pro Bugle and Hood Decal, 265/70/17 BFG KO2s (C), TRD Skid Plate, OEM Tri Fold Tonneau, OEM Roof Racks, TRD Exhaust Tip, All LED Lighting, Tacoma Matte Tailgate Lettering, OEM Rear Bed Step, Remote Start, Locking Tailgate
    Thank you, ill await your update -
    ps - you mean synthetic in the trans or diff?
    [QUOTE="07 sport 4x4, post: 11164776, member: 48165" Also, with the 05-09 limited slip differentials DO NOT use synthetic fluid or they will chatter worse than ever.[/QUOTE]
  2. Nov 16, 2015 at 11:40 AM
    #442
    MPOW33R
    MoMo
    Thank you, Im referring to an 06 Sport 2WD not my 2010 Off Road
  3. Nov 16, 2015 at 11:41 AM
    #443
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Ok, then yes, you need the additive in the rear diff
  4. Nov 16, 2015 at 11:47 AM
    #444
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
  5. Nov 16, 2015 at 1:16 PM
    #445
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I'm doing this service in 1k and am practicing temp check right now. I followed the steps and my AT light illuminated for 2 seconds after the 6 shifts. It is supposed to illuminate again for 2 seconds when I shift back to park. Ive gotten the initial 2 sec light to come on over a dozen tries but cannot get the second 2 sec light once in park.
  6. Nov 16, 2015 at 2:26 PM
    #446
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    Great write up. Subd for future reference
  7. Nov 16, 2015 at 3:20 PM
    #447
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    http://youtu.be/vpGIBJPnJX4
    Backt[QUOTED] likes this.
  8. Nov 16, 2015 at 3:32 PM
    #448
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    [/QUOTE]
    In the diff
  9. Nov 22, 2015 at 4:37 PM
    #449
    fla taco
    Central Florida
    05 Dblcab TRD OR
    Completed the AT fluid flush today. I used the garden sprayer method and went with the valvoline max life ATF along with a bottle of the Lucas ATF conditioner. I did a pan drop. Got just shy of 4 quarts out of the pan after draining then dropping the pan. Ended up adding 17.5 quarts. No problems getting it to temp mode but did have to add additional fluid a quart at a time before getting the fluid to trickle out of the check plug. All in all not a bad DIY job. It appears my trans. Was low on fluid from the factory. Fluid that drained out was still reddish. Drained out 15 and put in 17.5. My 05 just turned 43k and I tow a travel trailer. Great write up. Thanks!!!
    billybob50, Crom and 07 sport 4x4 like this.
  10. Dec 10, 2015 at 1:32 PM
    #450
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    I have an 05' with 91K - flush done at 45K as part of the original owners extended service plan. Contacted dealer for pricing and was quoted $119 for drain/fill - $159 for flush. My only concern is the theory that a full flush dislodges debris and is actually worse...thoughts?
  11. Dec 10, 2015 at 2:09 PM
    #451
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    So many people don't do anything and that's where it gets them in trouble, when you go over 100,000. The transmission fluid has already started to break down, along with a lot of very fine medal particles. What's has happened is some of the internal areas/pockets and the torque converter of the transmission has a build up quite bit of sludge & medal shavings. When you do a drastic flush with all new fluids. It causes this cake up material to start to break loose over time, thus jamming some of the internal moving parts. You on the other hand have all ready have done a drain and fill. Suggest not to do a flush, but just a drain, which is about 5 quarts. If you want to go an extra step, have them drop the pan and install a new filter. Another suggestion, do the drain & fill yourself and save some $$$! https://www.youtube.com/watch?v=q-nhSpJjYyE
  12. Dec 10, 2015 at 2:59 PM
    #452
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    Do a flush, you'll be fine, we have members here that have flushed theirs with 150k or more miles with no ill effects. Provided that it doesn't have any problems beforehand, a flush shouldn't hurt anything. I disagree with the previous poster on the filter change, it is actually just a strainer, or a screen. If you've accumulated enough debris that the strainer needs changing, your transmission is on its last leg, imo. I believe it is possible to clean the strainer, but I doubt the dealership would be willing to do that. If it makes you feel better to change it, it's your truck and your money. Your mileage may vary. :mudding:
  13. Dec 10, 2015 at 3:22 PM
    #453
    tacoholic05
    05' 4x4
    The $40 difference is not an issue between flush and drain/fill, just try'n to stay ahead of future problems and increased longevity by doing a little PM whe $$ permits - but I also want to do the most beneficial PM. I think if the flush wasn't done at 45K I may be more inclined to do the drain/fill.
  14. Dec 10, 2015 at 3:40 PM
    #454
    billybob50
    Bob
    Everyone's has their own ideas. Just check the internet for people who had their transmission flushed. Filter is just a fine screen, but their's a lot of slug and debris in the bottom of the pan. Doing a flush on an old transmission you're asking for problems.
  15. Dec 11, 2015 at 12:53 AM
    #455
    Backt
    Oregon
    I've read every post on this thread once, and have looked it over a couple times in preparation for when I do my first flush which will be 50k-55k. I've also read the other threads pertaining to the auto transmission on here. From what I've read if the dealer uses a high pressure flush machine it may dislodge debris you may have. If the flush is completed like on this thread there is no added pressure that will dislodge any debris.
    In my opinion your transmission is probably in fantastic shape because it was flushed early on. You only have 46k miles on the fluid which is advised to be changed every 60k.
  16. Dec 11, 2015 at 2:15 PM
    #456
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Is 3/8 the same size as the OE line if you were looking to replace it?
  17. Dec 18, 2015 at 11:37 AM
    #457
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    I stopped at Autozone to look for T-IV fluid for my '13 4 banger. The Valvoline in the pic below says it can be used in place of both T-IV and WS. I know We're not supposed to put WS in the 4. Should I not use this? Thanks all. image.jpg
  18. Dec 18, 2015 at 11:59 AM
    #458
    billybob50
    Bob
    I used the Walmart Brand, same stuff only cheaper!
  19. Dec 23, 2015 at 3:19 PM
    #459
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    OP, many thanks for this write up. Did the flush today on my '08 Off-Road Pre-runner DC w/ tow package without incident (ok, I did get dirty and slathered with ATF- ssdd :p ). Truck is driving great so far with much smoother idling and shifting. My guess is the trans was factory under-filled by at least a quart. I put in 17 of Valvoline Max Life and it only fed out 15 1/2. I'm giving 1/2 qt margin of error for spillage :rofl: .
  20. Jan 13, 2016 at 12:05 PM
    #460
    rogotoko
    rogotoko Well-Known Member
    R D
    Maryland
    2007 TRD Off Road 4x4
    Bluetooth Stereo, Backup Camera, Viper Remote Start, Heated Seat Kit, Extang Solid Fold Tonneau Cover.
    I've purchased everything i need to do a flush. I'm at 75,000 miles. It's 28 degrees out right now, though. Will a couple of drain and fills essentially do the same thing? I mean, if I drain and fill today, then again in like 500 miles, then again 500 miles later, will I achieve like results, as long as I get around 16 quarts through it over time?
