DIY: Full Flush for Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mountain lion, Jan 5, 2010.
  1. May 3, 2016 at 5:56 PM
    #561
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ImpulseRed008[QUOTED] likes this.
  2. May 6, 2016 at 6:03 PM
    #562
    RTFab
    RTFab Active Member
    Loved it great post. It might be a tad too much for me to handle, perhaps i should just lie to the dealership when i hit 60k and tell them i towed a lot and have them change it? I wonder how much they would charge also... this is something i REALLY do want to have done so i have to think of something. (2011 taco here)
  3. May 6, 2016 at 6:47 PM
    #563
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Gonna do this tomorrow and add an extra aux cooler so I'll have a total of 3. Ehh never mind just decided to replace the tow package cooler with a bigger cooler.
  4. May 6, 2016 at 8:19 PM
    #564
    hecsys_
    hecsys_ Member
    Hector
    '08 Tacoma 2WD
    1.5" front lift 0" on back (Baja style)
    I did get a quote from my toyota dealership before and it would cost you around 279.99 + tax.
    RTFab[QUOTED] likes this.
  5. May 9, 2016 at 2:59 PM
    #565
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I was scared to do this... but followed fla_sun's use of the drill pump and Crom's location and it was fairly easy. SO happy I did it!!! Truck shifts so much smoother now. Give it a shot!!
  6. May 9, 2016 at 4:19 PM
    #566
    M192
    Dan
    Cambria county PA
    Alot
    Yeah I had no problems at all.
  7. May 19, 2016 at 9:36 AM
    #567
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    That is a good pump, I use the same one. I can pump a gallon rally quickly with this.
  8. May 27, 2016 at 11:49 PM
    #568
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    While looking at the fill and drain thread https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/page-36 today I ran across this. Just thought I'd post it on this thread.
    The fluid adjustment is correct EXCEPT for 1 step, & the probably the most important. After correctly entering fluid temp detection mode, you need to remove the jumper wire from DLC3. If you don't the ECU will stay in base timing & not maintain the correct idle speed & ATF cooler flow to adjust the ATF level properly. The idle will fluctuate & cause the fluid level in the pan to go up & down incorrectly while you have the check plug out, you'll let out of much. You also must have all accessories off to reduce alternator load & to maintain exactly 800 rpm
    http://www.moranbahweather.com/toyota/lc_trj12/rm/rm1151e/m_40_0002.pdf
  9. May 28, 2016 at 12:20 AM
    #569
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Just use an IR gun. It's been shown to be just as accurate as techstream or sticking wires in OBDII socket. Just get a good quality IR gun. I have a Raytek MT6 and it has not let me down.
    Post #146
    http://www.toyotanation.com/forum/1...o-transmission-flush-pics-10.html#post9686129
  10. May 29, 2016 at 9:13 PM
    #570
    Pabloeeto
    Paul
    San Diego
    I flushed my trans fluid today
    Drained the pan
    Added 4 quarts
    emptied 4 quarts through the trans cooler
    Added 4 more quarts
    emptied 4 (At this point it started to run clear)
    added 2 more quarts
    emptied 2 quarts
    Added 4
    Entered trans temp check mode and emptied 1/2 quart through the overflow plug.
    Shifting is so much smoother, the 1 - 2 upshift was really harsh now it's like butter.
    I highly recommend this pump from , don't buy the little bottle pumps, buy this, you can pump a gallon of fluid in under 2 minutes.
    Here is a video of the first 4 quarts being drained from the trans cooler lines.
    https://youtu.be/AY97_4MBIwU
  11. May 30, 2016 at 7:05 AM
    #571
    M192
    Dan
    Cambria county PA
    Alot
    Oops. O well it can stay a little low. I can't see it being "too" low. My trans skid is a bitch getting on and off so it can stay like that till I get around to getting the skid off.
  12. Jun 3, 2016 at 1:58 PM
    #572
    Backt
    Oregon
    Alright I have finally acquired everything I need to do the flush. If the trucks been sitting for 3 hours has the coolant cooled off enough to do the flush. Mountain lion posted below 86°.
  13. Jun 3, 2016 at 2:04 PM
    #573
    styner1989
    styner1989 Active Member
    Waco, Texas
    2018 DCSB Off-Road 4x4
    Stock for now
    Did this last weekend with drill pump and it only took about an hour to complete with a test drive. I used Amsoil ATF and my transmission shifts so smooth now it was a night and day difference. My truck has 58,000 miles now and was probably the original oil.
  14. Jun 3, 2016 at 3:30 PM
    #574
    ImpulseRed008
    Susan
    SC
    Took mine longer than that and it wasn't anywhere near 86* :notsure:
  15. Jun 3, 2016 at 3:53 PM
    #575
    Backt
    Oregon
    Alright I'm putting everything back together now and missed one step. On the transmission cooler there is a line on the far right that I believe is the hot line into the cooler. The other line is 2" to the left which I believe is the line back to the trasmission. Am I right 2012 off road
  16. Jun 24, 2016 at 9:23 AM
    #576
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
  17. Jun 28, 2016 at 1:10 PM
    #577
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    coming back to this today.. awesome job!
  18. Jul 2, 2016 at 6:47 PM
    #578
    Pabloeeto
    Paul
    San Diego
    Yes
  19. Jul 4, 2016 at 4:34 PM
    #579
    storktaylor
    storktaylor Well-Known Member
    California, MD
    09 Pre-Runner TRD Off-Road
    Bak FLip G2 ScanGauge2 Black Labrador Retriever
    Did this today and it went without a hitch....except I ended up putting in about a quart more than I took out. This is the first time I have changed the fluid, doing it at 90,000 (I know, I know, but I took those Toyota guys at their word), and now I am concerned that I have been driving aroud a quart low for the last 90K. The fluid was dark red, but still see-through, I am going to send a sample to Blackstone to see what their thoughts are. The truck seems to shift much smoother now, not sure if that is just what I am looking for or if it is a real result of the flush. Thanks to @mountain lion for the post and tutorial!
  20. Jul 11, 2016 at 5:38 PM
    #580
    Pabloeeto
    Paul
    San Diego
    Nice! Welcome to the Flush Club haha,
    Yes smoother shifts are to be expected.
