DIY Hi-Lift and Tool Mounts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Benson X, Jan 26, 2013.
  1. Aug 30, 2017 at 9:59 AM
    #481
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    One I kinda just threw together for less than $150 for everything.
    BandanaBerg and BrianPVan like this.
  2. Oct 14, 2017 at 3:55 PM
    #482
    Grindstone
    Grindstone Requires Adult Supervision
    Took a couple runs back and forth to Lowes to suss out the right hardware, but I finally got it mounted. I might have to get a longer bolt for the rear mount as there wasn't enough to leave the base plate on. Which is fine, because I need to get a new pin for the base plate anyway. The rusty bolt it came with does not instill trust. The jack was $30 at a local pawn shop. The mounts are 1.5" wide by 1/8" thick alum. Painting to occur later. Used t-nuts from here. Near perfect fit, thought the bolts listed in this thread were too short to seriously engage. I got 1.25" bolts to secure the mount to the t-nuts. Probably could've even gone to 1.5". The real challenge was to mount it low enough the arms of my tonneau could fit. I have very little lee-way, but it all fits.
    BandanaBerg and Grey 2015 like this.
  3. Oct 14, 2017 at 5:59 PM
    #483
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Not really a tool mount per say, but close...
  4. Oct 15, 2017 at 8:33 PM
    #484
    BrianPVan
    BrianPVan Well-Known Member
    Brian
    BC
    2017 DCSB OffRoad
    Initial planning stages for something similar for an antenna mount...
    BandanaBerg and Bastek like this.
  5. Dec 10, 2017 at 4:34 PM
    #485
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I can't be the only one to use a single T-nut to mount the hi lift vertically right? (Disregard the shovel quickfist mount, it's getting redone.)
    BandanaBerg and mountainmonkey like this.
  6. Dec 13, 2017 at 9:57 PM
    #486
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    Four years later and IMHO this is still by far the most intelligently designed Hi-lift mount. Like the bed rail system, this concept ought to be adopted natively by manufacturers, or at least mass-produced by aftermarket manufacturers until then. Space-saving, secure, low-profile. I would love to do this on my 3rd gen.
    Rabbidllamas, Bastek and BandanaBerg like this.
  7. Dec 16, 2017 at 11:23 PM
    #487
    hughes500pilot
    hughes500pilot New Member
    2006 Tacoma Access Cab
    Subscribed!
    BandanaBerg likes this.
  8. Feb 19, 2018 at 5:56 PM
    #488
    xsHelix
    xsHelix Member
    austin
    2006 RED Tacoma double cab 4x4
    Tires radio
    Im a noob here but where does everyone get the bolt/wing nut combo with the hole at the end of the bolt to stick a lock through? Thanks!
  9. Mar 7, 2018 at 12:42 PM
    #489
    Jazz1one
    Jazz1one It is what it is
    Calgary AB
    2015 MGM DCLB sport premium
    SCS ray 10s. 315/75/16 Yokohama G003. Elka 2.5 dc w/remote resi. SPC uppers. Dobinson heavy leafs. Timbren bumps. Spindle gussets. Cab mount relocate. TRD catback. Toyota trifold tonneau. Full spare in bed. Hood deflector, side visors. Danger Customs Front/rear high clearance bumpers and full skids. 2 way remote start. Safari snorkel. Front 30% tint. Bed step. Anzo LED head lights. Weather tech mats. AllPro HD sliders linexed. 10k smitty x20 synthetic. Factor55 flatlink. Linexed bushwhackers. Rigid industries bumper pods. Ridged industries DSS ditch lights. Diode Dynamics amber pods. Prinsu roof rack. 42” Caliraised Amber single row. Switch Pros in sunglass holder. Custom Bed rail mounts for recovery gear.Northstar AGM battery. 4.88 nitro gears. Front and rear ARB lockers. ARB air compressor in bed cubby using expedition essentials mount.
    Is there a reason why you can’t use the quick fist for the hi lift as well?
  10. Mar 7, 2018 at 2:20 PM
    #490
    jafrisi
    jafrisi Well-Known Member
    Tucson, AZ
    14 Superwhite DCSB TRD OR
    Toytec bilstein 5100 lift w AAL. 2.5 front and 1.5 rear. KMC turbine wheels 4.5 bs, BFG KM3s 285/75/16
    You just need something a little heavier duty since the hi lift is so heavy. In a big accident I don't think the quickfists would do well.
    Bastek likes this.
  11. Mar 11, 2018 at 5:58 PM
    #491
    Jazz1one
    Calgary AB
    @Benson X hey thanks for all the details. Not sure if this came up in the 26 pages of this thread but the measurements in the OP won’t work with tonneau covers . In my case I have a Toyota tri fold and that drops my bed rails 1” from their original position. So the flat steel bars needed to be cut 1” shorter all around.
    In my case I cut them before checking (genius I know), but when I saw they were too long I just gave them an extra bend on the bottom.
    Just figured the tonneau cover crowd would appreciate it if this was noted in the OP.
    Thanks again for the great write up!
    Dryfly24 and Bastek like this.
  12. Mar 11, 2018 at 6:13 PM
    #492
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    That's a great observation! Something to take under consideration. I cut bent painted and installed my brackets, not thikthing about the cover at all...
    I have a Truxedo which is raised approx 1½" over bedsides, so my shovel fits perfectly.
  13. Mar 11, 2018 at 8:09 PM
    #493
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    Id think you could. I dont know why they wouldnt hold on any different than another.
  14. Mar 30, 2018 at 11:29 AM
    #494
    jkowal20
    jkowal20 Well-Known Member
    Joey
    2015 White Tacoma TRD Sport
    Nice set up, gave me some good ideas for mine!
  15. Apr 8, 2018 at 4:23 PM
    #495
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
    was able to make mounts for escaper buddies using this thread
    3/8 6 inch bolt
    hex nut
    1/4 pvc drilled out 3/8 in the middle
    lowes turn knobs
    Slashaar, MECtacoOR and Jorgy1 like this.
  16. Apr 8, 2018 at 5:30 PM
    #496
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    That's pretty slick. My boards were too long so I had to mount them along the rails and put the high lift across the front.
    RUSSELLTACO[QUOTED] likes this.
  17. May 21, 2018 at 2:34 PM
    #497
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  18. Jun 9, 2018 at 4:29 PM
    #498
    yote
    yote Washington State University
    Mark
    Tacoma, WA
    2002 Ext Cab TRD Off-Road
    Resurrecting this thread because of how sweet this was, and it was my first time bending steel & fabricating (even though I roughly followed this thread) so it's cool to make something and mount it knowing you made it from scratch!
    The tool mounts:
    Then the fire extinguisher mount:
  19. Jun 15, 2018 at 6:30 AM
    #499
    MECtacoOR
    MECtacoOR Well-Known Member
    Michigan
    2017 Magnetic Gray OR DCSB
    Are your boards mounted to a front bed rail using the T nut or did you come up with another way of attaching these to the bed of the truck? I also have the escaper buddies and am trying to figure out how to attach them.
  20. Jun 15, 2018 at 7:15 AM
    #500
    blefferd
    blefferd Well-Known Member
    Brian
    2012 Tacoma SR5 4x4
    Glad you got rid of that splitting maul and bought an actual axe, you would have a helluva time chopping anything with that! lol
    Slashaar and yote[QUOTED] like this.
