DIY - How to Install a ToyTec Diff Drop (Pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neubs, Sep 26, 2009.
  1. Feb 16, 2015 at 9:04 AM
    #41
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    Well... have a look at the skid plate that guy made. There were two cube-like protrusions that likely caught the rock and pushed everything into the engine casing. Skids should be nice and smooth to glide over rocks, not catch on them.
    That's the only bad thing I've ever read about the drop. I put one in, can't hurt really. My kit from Toytec came with spacers to drop the factory skids anyway.
  2. Aug 1, 2015 at 7:23 AM
    #42
    Tacomalover303
    Tacomalover303 Well-Known Member
    Colorado
    08 TRD Sport
    What's the round spacer with three holes for that I got in my diff drop kit?
  3. Aug 11, 2015 at 5:30 PM
    #43
    ascaccianoce
    ascaccianoce TheScatch
    Austin
    Salt Lake City, UT
    2012 Tacoma DCSB TRD Off-Road
    3" spacer lift, AAL's, 17" Method Roost Bronze, General Grabber at2 33", Pioneer Double Din, 12" JL TW3 truck box, rear bumper led lights
    Just installed mine today :)
  4. Oct 18, 2015 at 3:56 PM
    #44
    tdbabajan
    tdbabajan New Member
    Trevor
    09 RC 2.7 Manual
    None as of yet!
    You're the man!
  5. Feb 28, 2016 at 6:38 AM
    #45
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    How in the world did you get the diff support bolts loose? I couldn't get them off for the life of me. Even tried using a breaker bar. Feels like I'm about to break the bolt in half.
  6. Mar 5, 2016 at 7:29 AM
    #46
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    this won't work with aftermarket skids huh?
  7. Mar 6, 2016 at 7:34 PM
    #47
    Ultrarunner7
    Ultrarunner7 Well-Known Member
    Northern Virginia
    2016 White Toyota Tacoma Sport 4 door
    Bilstein 5160s in rear with Toltec Progressive 3 leaf spring, Bilstein 6112s in the front
    My Rigid impact wrench had to work at them a few seconds but they came right off.
    I just lifted my 2016 Tacoma and had the shuttering from 0-15 mph. I dropped the differential and no change at all. Any more thoughts?
  8. Apr 5, 2016 at 5:29 PM
    #48
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do some research on a carrier bearing drop and axle shims.
  9. May 19, 2016 at 7:36 AM
    #49
    garyregcab14
    garyregcab14 Well-Known Member
    Garrett
    cincinnati ohio
    2014 Tacoma reg cab 4x4
    light bar, king 2.5 w/remote resi, wheel spacers, magna flow exhaust, wheelers progressive add a leaf, fox 2.0 rear shocks
    I just did this install today took me about an hour, many people say it doesn't help but I measured the angle on my cvs before and after, and the kit knocked 3 degrees out of angle so for me it helps and very limited ground clearance loss
    OG_Tacoma likes this.
  10. May 19, 2016 at 7:43 AM
    #50
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    They say it's not worth it bc the diff now looses lubrication on the back side and it can damage it. CV boots like 50 bucks a new front diff 2k?
  11. May 22, 2016 at 9:34 AM
    #51
    Bush75
    Bush75 Well-Known Member
    I find that a bit hard to believe, the inside of that diff when that ring spins turn into basically a dishwasher inside there. Can't imagine a lubrication issue at all in there.
    PEAKIT likes this.
  12. May 23, 2016 at 8:13 PM
    #52
    garyregcab14
    Garrett
    cincinnati ohio
    well after a couple of days with diff drop my cv noise came back, and I went ahead and installed eastcoast gear supply clamshell bushing and the was the proper fix took away all noise and vibration. I think ill leave diff drop on to keep cv angle better
  13. May 4, 2017 at 7:18 PM
    #53
    Kwik
    Kwik Well-Known Member
    Kyle
    Seattle
    2011 Tacoma 4x4 2.7L
    Since lifting my truck I have been experiencing not only vibrations from the front but also coming from the rear diff as well as a noise. Will this diff drop kit help with the rear noise and vibrations?
    Thanks.
  14. May 4, 2017 at 8:47 PM
    #54
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
  15. May 4, 2017 at 8:48 PM
    #55
    lynlan1819
    Tacoma
    Lifted
    Too mine off,a total waste of time and money,as the drop does nothing at all for the truck and it only tilts the diff,it does not drop anything.
  16. May 4, 2017 at 8:49 PM
    #56
    lynlan1819
    Tacoma
    Lifted
    NO,do not waste your money.
  17. May 5, 2017 at 5:59 AM
    #57
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What's your deal? I've seen you in three different diff drop threads in the past 24 hours. Care to share your personal experience on why they're so bad?
  18. May 5, 2017 at 6:19 AM
    #58
    Justinlhc
    Justinlhc Not looking for a relationship
    EatSleepTacos[QUOTED] likes this.
  19. May 5, 2017 at 6:39 AM
    #59
    lynlan1819
    Tacoma
    Lifted
    Who said they were bad,I said they do little too nothing too help the cv axle angles,so why waste your money.
  20. May 5, 2017 at 6:46 AM
    #60
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Fair enough. I just assumed that you had a poor experience with them. It costs $31+shipping from wheelers offroad, so the cost is low. If it helps a little bit, $31 is worth it.
