DIY LCA Bushing Removal and Replacement 2005+ Tacoma (4x4) The Easy Way!
Discussion in 'Suspension' started by Crom, Jun 20, 2016.
  1. Apr 24, 2017 at 2:01 PM
    #101
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Correct. Whiteline bushings come from Amazon. This list is just for the alignment hardware.
    SR-71A, lo2hi and scottalot like this.
  2. Apr 24, 2017 at 2:05 PM
    #102
    Oowen
    Oowen Goes through trucks faster then underwear
    Owen
    Reno, NV
    15 DCSB
    Garage Queen
    Cool thanks, the white line kit comes with everything else needed?
    scottalot likes this.
  3. Apr 24, 2017 at 2:11 PM
    #103
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Yes. As shown:
    MTopp and scottalot like this.
  4. Apr 25, 2017 at 7:59 AM
    #104
    Beauty or Beast
    Beauty or Beast Well-Known Member
    Jarred
    SWVA
    Magnaflow Off-road exhaust K&N Cold Air Intake CaliRaised Ditch lights/w Rigid D2's Soon to add Pelfreybilt bumper, Headstrong lift, AllPro Sliders
    double check your inventory on the Bushing Equipment. I ordered this kit ant it was missing the two larger diameter sleeves for the front cams. I took it up with Whiteline and they warrantied it out in 2 days. Great people to work with.
    Been running this for 4 days now, it's touchy, drives a helluva lot different than stock but it's a major upgrade in quality.
    MTopp, EDDO[QUOTED] and scottalot like this.
  5. Apr 25, 2017 at 10:10 AM
    #105
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    I've had mine on a week now... truck wanders all over the freeway... pretty sure just bc everything except the rack bushings and uca's are brand new, that the truck wanders due to the rack bushings being toast...
    MTopp likes this.
  6. Apr 25, 2017 at 10:11 AM
    #106
    09BlueBeast
    Cody
    Denver
    Also has your vst been going off since u put the white lines on?
  7. Apr 25, 2017 at 10:32 AM
    #107
    Beauty or Beast
    Jarred
    SWVA
    haven't had an issue one yet. Mine wanders but everything save the lower ball joint is new. She got jacked 2" in front so geometrics are little squirrely now. Main issue I've had is involuntary steer, she wants to compensate for every bump instead of riding straight. If I loose the wheel she'll track fine but you feel every reflector and if the road has a crown to it, she wants to follow.
    I'm attributing that to the bushing being a lot more sensitive to input than the OEM ones.
    P.S. I'm also running w/o swaybar.
  8. Apr 25, 2017 at 10:34 AM
    #108
    09BlueBeast
    Cody
    Denver
    Got ya... have u replaced your rack bushings yet?
  9. Apr 25, 2017 at 10:40 AM
    #109
    Beauty or Beast
    Jarred
    SWVA
    not yet...wasn't planning on replacing the Lower arm bushings but the other ones were fried. I twisted the front cam to adjust and it sheered right off so...had no choice in that matter. It may be a project later on down the road, right now I'm recovering from a front bumper, lift, lights, and hood lift purchase.
    MTopp likes this.
  10. Apr 25, 2017 at 10:41 AM
    #110
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
  11. Apr 25, 2017 at 10:50 AM
    #111
    09BlueBeast
    Cody
    Denver
    Right on and yeah I feel that... just did everything on the front except rack and uca's so that got a bit pricey... now gotta pay out for a rack and some energy rack bushings
  12. Apr 26, 2017 at 10:25 AM
    #112
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Got me a pr of used LCAs to clean up, beef up and dress up with all new hardware, ball joints & the whiteline kit. Gonna swap LCAs, UCAs, tie-rod ends, hubs with new bearings, adj hardware & probably the rack bushings all at same time. Have everything except the whiteline kit, tie-rod ends & new LBJs on hand already..............
    Crom[OP], MTopp and TireFire like this.
  13. Apr 28, 2017 at 12:53 PM
    #113
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    If you do tie rod ends, you might as well do the inners also, getting just the outer off is very hard depending on how much rust you have. Also if one or both of the inners go bad, it'll ruin the outer attached to it.
    Just look up some DIYs here on it, it's pretty easy, just need new clamps/hose clamps for the steering rack boots.
    I used this "barbaric" tool to get the inners off and install the new ones:
    https://www.amazon.com/Cal-Van-Tool...rd_wg=nzUWI&psc=1&refRID=XQZG5R19TKH75GG943T7
  14. Apr 30, 2017 at 10:19 PM
    #114
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Am I reading this wrong? The bushing kit from white line is $152 per side.
  15. May 1, 2017 at 2:34 AM
    #115
    09BlueBeast
    Cody
    Denver
  16. May 1, 2017 at 11:51 AM
    #116
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    That's for both sides
    MTopp, DukesTaco[QUOTED] and EDDO like this.
  17. May 1, 2017 at 12:31 PM
    #117
    DukesTaco
    AZ
    :thumbsup:. The Amazon picture and discription left me wondering
    MTopp likes this.
  18. May 11, 2017 at 4:55 PM
    #118
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    Guys with some miles on these, any input?
  19. May 11, 2017 at 6:06 PM
    #119
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    5 months, say 5,000 miles. No clunks or squeaks. Pleased with it.
    09BlueBeast likes this.
  20. May 11, 2017 at 6:25 PM
    #120
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Great. And you can confirm the set on Amazon contains enough to do both arms?
