DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Oct 28, 2013 at 4:51 PM
    #201
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    Well hopefully my situation isn't the same as yours. I just ordered greasable bolts and bushings from Rockauto. I ordered the rear bolts from the dealer. All should be here by Wednesday.
  2. Oct 28, 2013 at 6:53 PM
    #202
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    St3ve let us know how it goes.
  3. Oct 29, 2013 at 5:26 AM
    #203
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    yes, with some part numbers and pictures so I can adjust the OP. The other guy has me so confused I have no idea whats going on :D
  4. Oct 29, 2013 at 7:04 AM
    #204
    BamaToy1997
    Bill
    Navarre, FL
    I sent an email to Moog corporate on Friday after reading this thread, since I was curious. I got a phone call this morning from Robert at Federal Mogul who said that his research shows that the Moog kit is SUPPOSED to be for a single control arm. (meaning the two bolts were supposed to be one front and one rear) When I told him what everyone was having trouble with he said he would have to check into it since he does not oversee R&D or product application. He told me give him until Friday to see if he can find an answer. That is what I have found out so far.
  5. Oct 29, 2013 at 7:07 AM
    #205
    XXXX
    sKiP
    05 Prius
    LOL so funny. Poor Scott.
    On another note there is always whitelines kit no one has tried
    Snicker
  6. Oct 29, 2013 at 10:07 AM
    #206
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Too funny, but I would like an exact explanation of these bolts application. In prepping my truck for sale I wanted to replace the seized front bushings so I could do a proper alignment. the vendor I get the hub parts from told me about the moog bolts (which I knew Scott was going to attempt installing). The vendor told me they were listed as "driver or passenger lower control arm "front bushing only" bolts. This is how they are listed in his system.
  7. Oct 29, 2013 at 2:38 PM
    #207
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Another thing to add to the to-do list. :(
  8. Oct 29, 2013 at 2:52 PM
    #208
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I just read this entire thread from start to finish. I want to grease the bolts before they seize (praying they're not already). Also curious about the greasable bolt and the whitelines.
  9. Oct 29, 2013 at 2:57 PM
    #209
    ST3VE
    MD --> SC
    Looks to be they give you front and rear bolts per box. I just took the bolts under the truck and they look to be the exact ones on the truck.
  10. Oct 29, 2013 at 2:58 PM
    #210
    ST3VE
    MD --> SC
    And BOTH bolts are greasable.
    And I am looking at the diagram. Looks like one bolt should have two 3's and the other should have a 2 and a 4??
  11. Oct 29, 2013 at 3:01 PM
    #211
    Sandman614
    Tim
    '06 SR5 Off Road
    I already like the way your laying this out. What pn's did you order?
  12. Oct 29, 2013 at 3:04 PM
    #212
    XXXX
    sKiP
    05 Prius
    Can't see great on my phone but looks like that's not what you got...?...
    Nothing to do with you but after a decade of production these aftermarket parts suppliers need to step it up. I gave up on yota fixing the issues. They just want to sell you brand New lca's every couple years.
  13. Oct 29, 2013 at 3:04 PM
    #213
    ST3VE
    MD --> SC
  14. Oct 29, 2013 at 3:07 PM
    #214
    ST3VE
    MD --> SC
    That's kinda what I got. Just not in that order. I think I should be able to switch the adjustment washers....??
  15. Oct 29, 2013 at 3:10 PM
    #215
    Crom
    Nick
    San Diego, CA
    Millions
    Steve, you're right! Either the printed illustration in the documentation is wrong or the part came assembled wrong.
  16. Oct 29, 2013 at 3:16 PM
    #216
    XXXX
    sKiP
    05 Prius
    This.
    I'd contact Rock auto and Moog. Send them the pics and ask them. What to do. I'd also ask them what way they should face. Part numbers in towards the lca or out so you can read them.
  17. Oct 29, 2013 at 4:01 PM
    #217
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    it shouldnt be that hard as they make the bushing as well
    the problem is not with the bushing as stated earlier
    the bushings work fine problem is the bolts for said rear are to wide...."dia"
    there is no difference in innner dia from moog to oem bushings
    as stated earlier problem is outer dia. of said bolts
    this....but you would need 2 sets of bolts to get one set to do the fronts....
    as the front n rear adjusters are of different size as stated earlier
    :cool:
    yes you can
    you will notice cam adjuster #3 are smaller dia then 2 and 4
  18. Oct 29, 2013 at 4:14 PM
    #218
    ST3VE
    MD --> SC
    That's what I was thinking. It was just tough to compare the size of the washers to the ones one the truck. Thank you!
  19. Oct 29, 2013 at 7:34 PM
    #219
    brutalguyracing
    F.U> GUYZ
    broken mods
    Yea i didn't realize that until i went to install them yesterday
  20. Oct 29, 2013 at 7:59 PM
    #220
    Sandman614
    Tim
    '06 SR5 Off Road
    So you switch the washers to match the diagram? Are they removable? Do they match up with the washers on the truck?
