DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Sep 3, 2012 at 12:16 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
  2. Sep 3, 2012 at 1:01 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
  3. Sep 3, 2012 at 1:10 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
  4. Sep 3, 2012 at 1:17 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
  5. Sep 3, 2012 at 1:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Bushings look like they're shot and is your CV boot torn?
  6. Sep 3, 2012 at 1:31 PM
    XXXX
    sKiP
    05 Prius
    looks normal to me :notsure:
    your bolt isn't moving with the LCA so it appears to not be seized.
    CV boot is fubar though.
  7. Sep 3, 2012 at 1:33 PM
    Pugga
    Massachusetts
    But should the bushing allow for that much movement? Seems the rubber should keep the LCA a little more centered. I guess I'd have to see a new one for comparison.
  8. Sep 3, 2012 at 1:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    CV boot is toast
  9. Sep 3, 2012 at 3:30 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Yes I know the cv boot is torn and I will be doing that this week that's why I want to know if i need to do the lca bushing at the same time
  10. Sep 3, 2012 at 3:37 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    jack up the truck and take tire off and jam a crowbar in there and try to wiggle the bushing
    does appear your bushing has an excessive amount of play
    and how are you mounting the go pro there?
  11. Sep 3, 2012 at 3:42 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Like at 6:45 that is alot of movement from the lca and it looks like that's what's causing my rattle is it supper to move that much ???
  12. Sep 3, 2012 at 3:44 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    I will try that when i get home thanks. I stuck one of the adhesife mounts to the frame right above the lca
  13. Sep 3, 2012 at 3:55 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    a rattle is going to most likely be your steering shaft
  14. Sep 3, 2012 at 3:57 PM
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Is that what the tsb is for ?
  15. Sep 3, 2012 at 4:02 PM
    #35
    brutalguyracing
    F.U> GUYZ
    broken mods
    yes the intermediate shaft
    you will fell it in your wheel "steering" that is
  16. Sep 3, 2012 at 4:08 PM
    #36
    precoma
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Is there any way if checking to see if it needs to be replaced ?
  17. Sep 3, 2012 at 4:18 PM
    #37
    brutalguyracing
    F.U> GUYZ
    broken mods
    driveover bumps you would feel it
    if you dont feel it now then id say your good
  18. Sep 27, 2012 at 1:11 PM
    #38
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Anyone know what that clunk sound at 7:25 is?
  19. Sep 27, 2012 at 1:31 PM
    #39
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    At 7:47, when you begin to stop, the LCA shift away from the frame. Then as you stop, is move back towards the frame. A lot more than I would think should be normal. Considering how you have a '09 with a CV Boot already torn (mine is an '06 with 100k+ and both are still good), then it is highly likely that your bushing is bad as well.
  20. Feb 18, 2013 at 1:15 PM
    #40
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Has anyone tried to get grease zerks fitted onto the stock LCAs like the TC UCAs?
