DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Mar 6, 2014 at 2:44 AM
    #421
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I had a Toyota dealership take mine out and press the new ones in. They told me they usually torch them out so I assume it's a similar process to the one in the video.
    Where do you mean as the bushing seat? Like the metal ring that comes in contact with the LCA? If so do you hit it with a flathead or something?
  2. Mar 6, 2014 at 4:51 AM
    #422
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Bushing seat meaning where the bushing is pressed into the control arm.
  3. Mar 6, 2014 at 8:19 AM
    #423
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    that's interesting, because the dealerships here consider it a throw away part and you have to replace the whole arm.
  4. Mar 6, 2014 at 9:48 AM
    #424
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    some dealers do not have the equipment needed to do so or their staff is not well trained enough to do it...as I found out when researching this when I first did it years ago.
  5. Mar 7, 2014 at 4:48 PM
    #425
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I just did this job over the last two days. A couple of things that I found to be helpful. Diablo Steel Demon sawzall blades seemed to work pretty good. You can get them at Home Depot, make sure you get the ones that cut between 1/8" to 1/2" steel (markings are on the blade). I picked up the 6" version and 9" version to vary my angle of attack without hitting the steering rack or frame.
    I tried cutting with no lubricant, the blade lasted about a half thickness of a bolt. I then used 80-90 gear oil as a lube and I was getting a bolt width and starting on the other side of the bushing with one blade. I still chewed up alot of blades, I don't recall how many. I will say that it took 2 1/2 hours per side to get through those miserable bitch bolts.
    When you use the Moog bolts, double check that the grease fittings are tight. All of mine were loose, to include one that actually fell out.
  6. Mar 7, 2014 at 6:49 PM
    #426
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    so a member has his bushings and bolts installed and he is happy.....
    its a 4runner but still
  7. Mar 7, 2014 at 6:49 PM
    #427
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Go ahead and order yours to ensure I get new stock ;-)
  8. Mar 8, 2014 at 8:21 AM
    #428
    XXXX
    sKiP
    05 Prius
    After cutting one bolt and needed two blades I put down the sawzall and grabbed my grinder w/cut off wheel. Cut like butter.
    I was using Lennox blades with tooling/cutting wax as a lubricant. The bolts are hardened. The blades I have cut 3/8" mild steel like butter - LCA bolts not so much.
    where? on your 4runner forum?
    X2.... :D Spring thaw is coming and you guys need to flush out the crap kits.
  9. Mar 8, 2014 at 4:20 PM
    #429
    nj636
    Kev
    Jersey
    I have ONE good kit and returned the other kit. Called around to part stores and they do not stock them. Would love to find a local place that has them so I can look in the box before buying, I am 1 for 4 with these kits :-/
  10. Mar 8, 2014 at 5:23 PM
    #430
    brutalguyracing
    F.U> GUYZ
    broken mods
    Got mines
    Other dude on t4r
    Got his few days ago
    Bolts correct
    Had different #'s on cams 8's
    And 2+4 i think
    I got sizes for u guys
  11. Mar 8, 2014 at 8:46 PM
    #431
    nj636
    Kev
    Jersey
    get one new kit for me thanks
  12. Mar 9, 2014 at 3:33 PM
    #432
    brutalguyracing
    F.U> GUYZ
    broken mods
    Ok update
    I measured all my stock cams
    Most #'s i post have been rounded off to keep it simpler
    Driver side front 52mm
    Driver side back 54mm
    Driver side rear - front 46mm
    Driver side rear - rear 46mm
    Pass front 52mm
    Pass back 54mm
    Pass rear - front 47mm
    Pass rear - rear 47mm
    Ok moog cams
    826-3 = 46.75mm
    826-8 = 45.75m
    826-4 = 53.75mm
    826-2 = 51.50mm
    Moog bolt diameter
    13.85mm " bolt without sleeve"
    15.80mm larger bolt with sleeve
    19.10mm is the sleeve
    Hope that helps some of you
  13. Mar 9, 2014 at 3:51 PM
    #433
    brutalguyracing
    F.U> GUYZ
    broken mods
    Kev are these the polys u tries
    Guy on other site installed his he says there good to go
  14. Mar 9, 2014 at 5:13 PM
    #434
    nj636
    Kev
    Jersey
    I tried the Whitelines, no way they were fitting
  15. Mar 14, 2014 at 7:39 PM
    #435
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    1 week till the front end comes apart to install a bunch of new front end parts...But I still don't have the correct moog bolts. Has anyone else received the correct kit? I'm going to make my last effort order tomorrow to have them by weeks end.
    I have OEM bolts here if needed, But...
  16. Mar 20, 2014 at 7:38 PM
    #436
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I just received 2 correct kits from Moog!
  17. Mar 20, 2014 at 7:42 PM
    #437
    nj636
    Kev
    Jersey
    who'd you order from?
  18. Mar 20, 2014 at 8:19 PM
    #438
    ndcmack
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    Rock Auto
  19. Mar 20, 2014 at 9:23 PM
    #439
    nj636
    Kev
    Jersey
    +1 thanks
  20. Mar 21, 2014 at 9:35 AM
    #440
    XXXX
    sKiP
    05 Prius
    Woot! I know what I'm ordering this weekend.
