DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Jun 4, 2014 at 5:09 PM
    #481
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Plus if possible, get ur caster as high as possible
  2. Jun 4, 2014 at 7:06 PM
    #482
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    that's just sad.
    they cranked on the tie rods and didn't touch the LCA cams AT ALL.
    Do you have stock UCA's?
    EDIT: I see you have Camburgs. go to a front end shop, eff the stealership!
  3. Jun 4, 2014 at 7:16 PM
    #483
    regtaco
    regtaco Well-Known Member
    Lee
    Knoxville/Franklin TN
    07 Reg cab 4x4
    Toytec 3 inch lift kit with: OME 884 coils, OME Nitro shocks, custom driveshaft, diff drop
    I have Camburg Ball Joint UCAs that I just installed. And yep, just a "toe and go."
  4. Jun 19, 2014 at 1:05 PM
    #484
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
  5. Jun 19, 2014 at 1:06 PM
    #485
    regtaco
    Lee
    07 Reg cab 4x4
    Correct. I ordered from RockAuto and didn't have a problem
  6. Jun 19, 2014 at 1:15 PM
    #486
    duckcmdr
    Joe
    New Jersey
    06 DCLB 4x4
    Thanks
  7. Jun 19, 2014 at 1:42 PM
    #487
    nj636
    Kev
    Jersey
  8. Jun 28, 2014 at 12:22 PM
    #488
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Tagged for reference. About to do the bushings and bolts.;)
  9. Jun 28, 2014 at 3:14 PM
    #489
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  10. Jun 28, 2014 at 6:50 PM
    #490
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
  11. Jun 28, 2014 at 7:03 PM
    #491
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I was under the impression that they are out, but haven't heard of anyone using them.
  12. Jun 28, 2014 at 7:39 PM
    #492
    splitbolt
    NW Arkansas
    According to the link, they do.
    Most reviews seem to be for the FJ.
    They cross reference with the Whiteline bushings; W53312(lower) & W53313(upper).
    For $78, I think I'll give them a shot.
  13. Jun 29, 2014 at 9:56 AM
    #493
    XXXX
    sKiP
    05 Prius
    They do say it now...hmmm...
    Id go for it. Just know poly bushings like grease or they can get squeaky. I load them up during install.
  14. Jul 4, 2014 at 10:41 AM
    #494
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    "One Set Will Cover the Left and Right Side
    Must Reuse All Metal Parts
    Lowers Must Reuse All Metal Parts"
    Does that mean on the bushing too? Like you have to reuse your rusted sleeve? Gonna read the instructions...
    Oh wait, looks like it includes upper bushings too. Wonder if you can skip em if you have aftermarket UCA's
  15. Jul 4, 2014 at 10:48 AM
    #495
    XXXX
    sKiP
    05 Prius
    what kit are you referring to? Many have been talked about in here.
  16. Jul 4, 2014 at 10:50 AM
    #496
    Dragons Taco
    Derek
    Cary/Raleigh NC
    The energy suspension link split bolt just put up that you quoted. Looking at the instructions now. They just send the poly. You have to construct the bushing with the factory inner bolt insert, and outer washers.
    Which may be just fine, but looks like quite a bit more work.
  17. Jul 4, 2014 at 10:54 AM
    #497
    XXXX
    sKiP
    05 Prius
    If that's the case screw that.
  18. Jul 4, 2014 at 10:56 AM
    #498
    Dragons Taco
    Derek
    Cary/Raleigh NC
    Check out the 2 page PDF instructions to check me. Looks like you reuse the lower inner tubes, and upper outer tubes. Upper inner tubes are supplied (really? Just happen to have that size laying around?)
  19. Jul 4, 2014 at 10:58 AM
    #499
    Dragons Taco
    Derek
    Cary/Raleigh NC
    You know, even in their magazine ad I am looking at shows most of their bushings empty of metal. No bolt sleeves.
  20. Jul 4, 2014 at 11:00 AM
    #500
    XXXX
    sKiP
    05 Prius
    yea...it's all coming back to me now as I read the instructions. we were all talking about this a while ago.
    screw that. my sleeves would of been rusted to nothing in a few more years.
