DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Jun 12, 2015 at 5:25 AM
    #581
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    @V5ioV has these in his truck
    V5ioV likes this.
  2. Jun 12, 2015 at 5:26 AM
    #582
    nj636
    Kev
    Jersey
    whose LCA did you go with?
  3. Jun 12, 2015 at 5:27 AM
    #583
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    @Alfuh has them
  4. Jun 12, 2015 at 5:37 AM
    #584
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    They fixed the issue i had with them, I don't see the play I did before (you know.. you took video lol) but I have to address the thump we were just talking about on hangouts
    Last time it was a thump but also a really bad squeak...
    Crom likes this.
  5. Jun 12, 2015 at 5:59 AM
    #585
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    Yup, I had a horrible creaking/pop and a lot of flex with my LCAs. Got rid of my shot rubber bushings and put these in and fixed my issue
    Crom likes this.
  6. Jun 12, 2015 at 11:40 AM
    #586
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    OEM Toyota. I found a pair on CL brand new for $150. Finally got to drive it today and no more noise and drives much better. I guess the other set were shifting around from the loose front bushings. I marked the alignment cams before taking it apart but the wheel is a little off and it pulls slightly to the right now so will go for another alignment soon. Guess marking the cams isn't a guarantee of things going back exactly where they were.
  7. Jun 12, 2015 at 12:00 PM
    #587
    nj636
    Kev
    Jersey
    I'm sure I'm experiencing the same problem as everyone else with the Moog bushings. I will attach a go-pro this weekend and see whats going on for sure.
    If it's the bushings I'm going to go with the Energy Suspension kit.
  8. Jun 12, 2015 at 3:17 PM
    #588
    Toy4me
    Tom
    NNJ
    You probably don't even need to go through the go pro step. Get under your truck and check the front bushings on each side. If their outer flanges aren't pressed up flush to the lca, there's your problem. Maybe I'll press the rear bushings and lbjs out of mine and sell 'em as a stripped set for someone to refresh and swap right in.
  9. Jun 14, 2015 at 11:29 AM
    #589
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    interesting, now I wonder if the complete LCAs that come with moog bushings and lower ball joints would be bad and cause the same issue. I figure if I can replace the whole LCA with a new aftermarket OEM replacement LCAs that comes with bushings and lower ball joints already assembled for cheaper and less of a PITA than changing out the bushings and lower ball joints. I just wonder the quality of the LCAs and the bushings/lower ball joints that are already assembled in there. Sure would be easier than messing with all the pressing out/in of everything.
  10. Jun 14, 2015 at 11:35 AM
    #590
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    My truck has seized alignment came too. I plan on buying oem lca's. It's expensive but it will save a lot of grief and I only want to do it once.
  11. Jun 14, 2015 at 2:22 PM
    #591
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    Do you live in northern NJ? I saw an add for same in CL guy was selling set of arms brand new for $150. Dick wouldnt work with me. Deal had to be done on weekends only. Was slow and tough trying to get any info from him.
  12. Jun 14, 2015 at 2:43 PM
    #592
    Toy4me
    Tom
    NNJ
    Agreed. It seems expensive (and I admit, that's why I bought the moogs first), but you'll do the job once. Now I've redone the job, throwing out the moog bushings and paying for a second alignment. As I said in an earlier post, the oem lcas come with lbjs too, so one more pita job not to worry about for a long time. I'd recommend buying the oem cams and bolts too. If you're local to me I'd be happy to lend a hand if needed.
    Yes, NNJ. Might be the same guy but I had no probs. He responded same day and I picked them up the next evening. Only 20min from me and by a friends' house so go to visit a buddy same nite.
  13. Jun 14, 2015 at 2:54 PM
    #593
    Armkb
    09 TRD Sport DCLB
    Good score! I always seem to miss all the great deals. Must have been same guy.
  14. Jun 14, 2015 at 5:16 PM
    #594
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    well I guess the way I look at it is if I am replacing OEM Lcas at 40,000 miles then maybe buying them again isn't worth the premium vs some other brand. :notsure:There are many not just moog brand.
  15. Jun 15, 2015 at 4:25 AM
    #595
    Armkb
    09 TRD Sport DCLB
    Press out the bushings leave the balljoint in and possibly I will buy them off you. Being how I missed that great deal on the new OEM arms that u were able to buy.
  16. Jun 16, 2015 at 8:46 AM
    #596
    nj636
    Kev
    Jersey
    maybe just install the OEM bushings & cams?
  17. Jun 16, 2015 at 10:10 PM
    #597
    Rosscopeeko
    BC
    08 DC LB 4x4 sport
    Toy4me, thx for the offer, but I'm up in BC Canada.
  18. Jun 19, 2015 at 5:45 PM
    #598
    nj636
    Kev
    Jersey
    Well I'm reporting back with my findings. I installed the Moog bushings in January of 14 when I rebuilt the entire front end and have put less than 5k miles on them. I noticed the clunk/pop a few months after installing the bushings. It started happening only when I backed out of my driveway but then I noticed it a bit more ie: pulling in and out of parking lots & while wheeling mostly. The last trip to Rausch in April of this year I noticed it was getting significantly worse (that was the ultimate test for it).
    My first instinct was a loose LCA bolt but they were still tight, second guess was a LBJ but that was nice and tight.
    I'm glad I found others having the same noise because I was loosing faith in diagnosing the problem. I've always had good luck with Moog parts so I wasn't thinking the bushings. Well I mounted the Go Pro tonight and here is what I found ....
    https://youtu.be/u-Lln299Ano
  19. Jun 19, 2015 at 6:07 PM
    #599
    nj636
    Kev
    Jersey
    so what's everyone doing, ditching the front Moog for OEM & keeping the rear Moog?
    I am thinking about dropping $200 on OEM bushings & never having to remove the arms again :notsure:
  20. Jun 19, 2015 at 9:43 PM
    #600
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yep, except I left in the moog rear LCA bushs, they seem fine.... For now.
