DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Aug 20, 2015 at 6:36 PM
    #661
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I've got a while list of parts in the rust thread and my build thread.
  2. Aug 21, 2015 at 7:33 PM
    #662
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I was thinking more along the lines of letting another NJ winter take it's toll on it
  3. Aug 21, 2015 at 8:04 PM
    #663
    nj636
    Kev
    Jersey
    I've got surface rust but no holes
    my 05 had zero rust but had a hole on the driver side by the cat
  4. Aug 21, 2015 at 8:18 PM
    #664
    Sandman614
    Tim
    '06 SR5 Off Road
    That's what I thought. My hole is right in front of the rear-forward spring hanger beside the muffler. It's a double layer part with a manufactured hole in the inner piece.
  5. Aug 27, 2015 at 12:40 PM
    #665
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    Well after reading through this thread which took some time I have made no conclusion. lol However thank everyone for all the help I still learned a lot.
    This thread is like watching the search for big foot, you think they are going to find him, but they never do.
    I have this clunk everyone is mentioning. I have Factory LCA w/original bushings, but I am sure due to the abuse I put my truck through that is why they are worn out. I also have 56,xxx miles so it is time. If @nj636 ends up having a clunk free life with his new found option I will go that route.
    Right now it seems I'm either replacing with all new OEM LCAs or Upgrading to a different brand all together. Which I can't really afford right now. Either way I need to do something before I need new tires, because this whole shitty alignments and clunking isn't working for me anymore. I would like to take care of this and my Cam Tab Gussets all in one shot, but it isn't looking good.
    Crom likes this.
  6. Sep 29, 2015 at 10:47 PM
    #666
    Bearch
    Bearch Well-Known Member
    Mat
    Vancouver
    '06 TRD OR SWB
    @nj636, Did those Mevotech Poly bushings do the trick?
  7. Sep 29, 2015 at 10:54 PM
    #667
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
    I was in the same boat and ended up going new OEM LCA's and TC cam tab gussets while hoping to see better options after another 50k
  8. Oct 1, 2015 at 3:41 AM
    #668
    nj636
    Kev
    Jersey
    they have been working quite well so far.
  9. Oct 1, 2015 at 4:02 AM
    #669
    Large
    Large Red
    LCA's are out, any tips on getting the bushings out? I have the cam bolts out and I have a set of moog bushings to go back in.
    What the fuck?
  10. Oct 1, 2015 at 7:04 AM
    #670
    mandzach
    mandzach Well-Known Member
    Quick update, I burned out my old bushings from my OEM lca's and reused the metal bits along with the energy suspension parts for the 4-runner. Worked perfect and been running for 6 months.
    2007 Tacoma DC 4x4 and the parts were for the same year 4-runner. They didnt list the part for a Tacoma but they worked perfect. Just takes a little work burning out old bushings and salvaging the metal bushing sleeves.
    Crom likes this.
  11. Oct 1, 2015 at 11:01 AM
    #671
    Bearch
    Mat
    Vancouver
    '06 TRD OR SWB
    Mevotech bushings are on their way:) @nj636
    nj636 likes this.
  12. Oct 1, 2015 at 2:26 PM
    #672
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Update, replaced the Lower ball joint and shocks, and the clunk went away. Still loving the Moog greaseable bolts and energy poly bushings.
    AE
    Crom likes this.
  13. Oct 23, 2015 at 9:16 AM
    #673
    Large
    Large Red
    Well no answer from anyone, going to tackle this today .. wish me luck
  14. Oct 23, 2015 at 9:23 AM
    #674
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    use the bottle jack. i started a whole thread on LBJ bushings.
  15. Oct 23, 2015 at 9:25 AM
    #675
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    This will help when getting them out too 50/50 mix
  16. Oct 23, 2015 at 9:26 AM
    #676
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
  17. Oct 23, 2015 at 9:26 AM
    #677
    Large
    Large Red
    Looks like you have a first gen, it's a little different on 2nd gens but I will still give it a shot. I have about 40 different cup sizes and adapters for the bj press
  18. Oct 23, 2015 at 9:28 AM
    #678
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    yeah it is hard to find a cup to just fit over the bushing flange without sitting on the flange.
  19. Oct 23, 2015 at 9:30 AM
    #679
    Large
    Large Red
    99% sure I can get them out without much issues, how do you press them back in? Anti-seeze and gentle hammer taps?
  20. Oct 23, 2015 at 9:31 AM
    #680
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    my whitelines just tapped in but YMMV
    i also used nickel anti sieze
    Large[QUOTED] likes this.
