DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Mar 4, 2016 at 8:04 PM
    #741
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Yes we need more people to try the mevotech supreme bushings.
  2. Mar 5, 2016 at 7:06 AM
    #742
    pseudomike
    pseudomike Well-Known Member
    Michael LaValley
    2012 DCLB TRD Sport
    I installed new arms yesterday. For those who need to cut theirs out do yourself a favor, goto store and buy a Freud Carbide Tipped Sawzall blade. I made all 4 cuts on my cuntrol arm in 5 mins flat. I gave it as couple shots of WD40 along the way. Blade was still sharp as new when I was done. I really dreaded cutting these out and it proved to go really fast about 1hr per side.
    Biscuits, Sloth and Crom like this.
  3. Mar 6, 2016 at 6:26 PM
    #743
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'd go with the SPC cam bolts over moog. Seems like everyone is going back to stock bolts though. I didn't by choice, Toyota did that for me.
  4. Mar 7, 2016 at 9:06 AM
    #744
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Pretty sure SPC and Moog are the same, and even if the design is a bit different, still made from the same shitty steel that causes them to round out. I would only recommend OEM bolts personally.
  5. Mar 7, 2016 at 9:34 AM
    #745
    Sandman614
    Tim
    '06 SR5 Off Road
    I ran the SPC and never had an issue with then rounding out. They are designed a bit different and the SPC seem to be built with better metal.
  6. Mar 7, 2016 at 10:18 AM
    #746
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    Thanks for the input guys. I think I'm going to try aftermarket just because the oem seems to be about twice as costly. Sandman, have you used moogs as well as the SPC? I didn't find much feedback on the SPC bolts from Tacoma users.
  7. Mar 8, 2016 at 6:21 PM
    #747
    MrShoehorn
    MrShoehorn Well-Known Member
    Justin
    North Augusta, SC
    12 DCSB TRD Sport Blue Ribbon
    So I'm having a bit of an issue with my lr ucas, I purchased a set off a user here and one side had the newer bushings they I removed without issue. The other side has the older style with the following order of layers:
    Bolt sleeve > rubber > thin sleeve > rubber > thin sleeve > thick sleeve.
    I can't get the thick final sleeve out, I'm scared to keep cutting :-/.
    Any ideas?
  8. Mar 8, 2016 at 6:38 PM
    #748
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Grab that bitch with some vice grips and giver hell. Or a screwdriver wedged in there.
  9. Mar 8, 2016 at 6:45 PM
    #749
    MrShoehorn
    Justin
    North Augusta, SC
    Yeah I did some beating on it with a screwdriver and a small sledge.
    I think it hates me and doesn't want to go in the trash. I think I'll try cutting another slit on the thick edge and then try to bend it in at my two vertical cuts with a vice.
  10. Mar 8, 2016 at 6:48 PM
    #750
    Sandman614
    Tim
    '06 SR5 Off Road
    Bend the edges on one side in. The tension keeps them in tight
  11. Mar 8, 2016 at 6:48 PM
    #751
    Sandman614
    Tim
    '06 SR5 Off Road
    I have not used both. I noted the failures of the moog bolts and found a different option. Worked well and didn't notice any rounding like the moogs.
  12. Mar 8, 2016 at 7:00 PM
    #752
    MrShoehorn
    Justin
    North Augusta, SC
    I'll admit I haven't read every post in this thread, but are you all referring to the moogs and spc bolts for when the OEM bolts are no longer useable? The bolts that attach the uca. I'm just double checking for when I make the swap I don't want to be stuck figuring out what to do after the fact.
  13. Mar 8, 2016 at 7:01 PM
    #753
    Sandman614
    Tim
    '06 SR5 Off Road
    Yes but LCA
  14. Mar 8, 2016 at 7:11 PM
    #754
    MrShoehorn
    Justin
    North Augusta, SC
    Hah, I didn't even notice it said LCA and not UCA.
  15. Mar 10, 2016 at 2:46 PM
    #755
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    *update*. The ROCA LCA bushing have failed on me only after 200 miles. They started back popping and have concluded by photo and video that the front smaller bushings are moving back and forth. The inner diameter must be to small which is causing them to shift. I will be tack welding them into place and calling it a day:cheers:
    Oh yeah the back ones are working great and were much harder to press in.
    Crom likes this.
  16. Mar 10, 2016 at 2:50 PM
    #756
    1rooster
    Georgia
    2007 Tundra crewmax
    You can see from where my finger is that they have popped back out.image.jpg
    Crom likes this.
  17. Mar 10, 2016 at 3:32 PM
    #757
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you for your valuable feedback. Much appreciated. Sorry the bushing gave you trouble.
  18. Mar 11, 2016 at 7:08 AM
    #758
    Sevi88
    Sevi88 Active Member
    Sevi
    WY-CO-PA
    06 TRD Sport 4x4
    5100 Bilstein, 5-leaf rear springs, Borla Exhaust
    Has anyone found inner sleeves for lower control arms that can be used with Energy Suspension bushings yet?
    I had to cut my old bushings out.
  19. Mar 11, 2016 at 7:39 AM
    #759
    Sevi88
    Sevi
    WY-CO-PA
    06 TRD Sport 4x4
  20. Mar 11, 2016 at 8:27 AM
    #760
    1rooster
    Georgia
    2007 Tundra crewmax
