DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Jul 23, 2016 at 3:14 PM
    #801
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    I did mine with Energy Suspension bushings. What a pain in the ass it was. If I had to do it again I would either do rubber bushing replacements or full replacement of the arm. To much feedback with poly bushings. Makes for a somewhat harsher ride. But I do like the steering response from the poly.
    Crom likes this.
  2. Jul 24, 2016 at 9:52 AM
    #802
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    What did you use to press in the new bushings?
  3. Jul 25, 2016 at 7:13 PM
    #803
    719bloodhound
    719bloodhound Well-Known Member
    cos
    06 trd off road
    Omd rear leafs Ome 886 up front
    I had Napas machine shop do it for $40
    Crom likes this.
  4. Aug 15, 2016 at 8:32 PM
    #804
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    The passenger side rear lca bushing seems worn prematurely. Had the truck parked today with the wheel turned right, kicked the passenger tire and found lots of movement and I could see the rear bushing moving/compressing easily. So, I'm going to evaluate all bushings soon and will report back, but I'm certain at least one is done, 16k miles since I posted this, +/- a few. What a bitch. Think I might press them out and throw them at the napa dude.
  5. Aug 15, 2016 at 9:02 PM
    #805
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Terrible to hear that. Sorry for the trouble. And thanks for reporting back.
  6. Aug 15, 2016 at 9:30 PM
    #806
    White Bear
    Louisiana
    No sweat. Are the Whiteline bushings holding up? Thx.
  7. Aug 16, 2016 at 6:49 AM
    #807
    Crom
    Nick
    San Diego, CA
    Millions
  8. Aug 16, 2016 at 10:50 AM
    #808
    White Bear
    Louisiana
    Thanks Crom. I'll check out the link when time permits.
    Crom likes this.
  9. Aug 19, 2016 at 10:34 AM
    #809
    White Bear
    Louisiana
    One thing I thought about with the harder polyurethane bushings, how will that affect alignment adjustments? For instance if your front adj is at 3-9 o-clock (adjusted outward), and the rears are at 6 o'clock or less (adjusted inward). The way mine are adjusted currently (similar to example above), I can see where the rubber bushings are pulled off center/stretched by the differing axis of the adjustments. Just a thought. (edit added)
  10. Aug 21, 2016 at 4:49 PM
    #810
    White Bear
    Louisiana
    Well shit.
  11. Aug 24, 2016 at 8:47 PM
    #811
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    meh. I wanted the solid poly due to all the weight of bumper, armor, etc.
  12. Aug 25, 2016 at 12:40 PM
    #812
    White Bear
    Louisiana
    Good point, my thought above might be a non-issue.
    I'm going back with MOOG bushings.
  13. Aug 29, 2016 at 11:15 PM
    #813
    White Bear
    Louisiana
    I installed the moog bushings this weekend, the napa were shot, and cost more than the white line bushings.:bananadead: But ol napa dude gave me a refund since they didn't last 18,000 miles. The moogs are solid rubber at least, they went in really easy though which worries me. We'll see if these are worth a shit.:burnrubber:
  14. Aug 30, 2016 at 7:21 AM
    #814
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    You may have to tack weld them into place. Just a few tacks in case years down the road you have to change them out again. But mine were "loose" when pressed them in. 10 miles down the road they started popping out of place. But ever since I put a few tacks on them, they haven't made a sound or moved in over 6 months.
    Crom likes this.
  15. Aug 30, 2016 at 9:22 AM
    #815
    Crom
    Nick
    San Diego, CA
    Millions
    I have found two people using aftermarket arms now.
    Thanks for the feedback.
    I am still waiting on front end parts before I swap in my refurbished LCA's with the Whitelines.
  16. Aug 30, 2016 at 11:54 AM
    #816
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    The Dorman arm was fine so far as I could tell. However, I wanted to go back to OEM so I pressed the ball joint and threw it back on. Essentially, I just used the Dorman LCA to buy me some time till I could find a place to press out the lower ball joint and replace it. The price on those LCAs was low enough to make that possible. I ended up selling them to a member on here who's essentially going to do the same thing. I like to think of it like paying it forward...use the LCA for a bit and then send it to another member who needs it! :D
    Crom likes this.
  17. Sep 9, 2016 at 2:58 PM
    #817
    White Bear
    Louisiana
    Thanks bro.
  18. Sep 9, 2016 at 4:31 PM
    #818
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Installed Energy in mine recently. Use a MAP gas torch (yellow bottle), not LP (blue bottle). Makes a world of difference in ease of removing old bushings.
  19. Sep 17, 2016 at 8:44 AM
    #819
    SethB
    SethB Well-Known Member
    TDY
    **SOLD** 2009 DCLB 4X4 Auto
    OME Suspension, SPC UCAs, ARB Bumper, Smittybilt Winch, Ext Brakelines, SOS Sliders, 4x Innovation Rear bumper
    Update, couple thousand miles on them now and they are holding up just fine, bushings are good and in place, no knocking.
    Crom likes this.
  20. Sep 17, 2016 at 8:50 PM
    #820
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Moog are shit. As you saw they go in too easy, which means they come out easy.
    https://youtu.be/s-Ub2rUdqEI
    Crom likes this.
