DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Apr 8, 2019 at 1:42 PM
    #881
    fivefoot
    fivefoot Scarlett, Scarlett Tacoma is the name!
    Temo
    Texas Panhandle
    2012 Tacoma TRD Offroad Barcelona Red
    Looks like the part of the bushing that sticks out more needs to face out, is that correct??? I need to do mine and im a bit confused as to which way the bushings go in.
  2. Apr 8, 2019 at 5:13 PM
    #882
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Yes, the instructions with the bushings detail it. :)
  3. Apr 8, 2019 at 9:40 PM
    #883
    fivefoot
    Temo
    Texas Panhandle
    Mine didn’t come with instructions. It was a craigslist purchase. Has everything but the instructions and grease
  4. Apr 9, 2019 at 8:57 AM
    #884
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    In that case, make sure the two holes in the bushings are horizontal with the arm, wider part faces out, and that's it.
  5. Apr 9, 2019 at 9:01 AM
    #885
    fivefoot
    Temo
    Texas Panhandle
    Facing out for both the large and small bushing?
  6. Apr 9, 2019 at 10:24 AM
    #886
    fivefoot
    Temo
    Texas Panhandle
    Called local dealership how much they charge to press out the old bushings and press new ones in, they told me $260 and it takes one and a half hours to do the job. I told them the arms are removed from the truck, it's just a matter of pressing out old ones and pressing new ones in, the still said $260
    :brianr::rofl:
  7. Apr 9, 2019 at 10:41 AM
    #887
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I doubt the dealership will press bushings.
  8. Apr 10, 2019 at 12:39 AM
    #888
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    anyone having hard time pressing in the moog ball joints?
  9. Apr 10, 2019 at 12:41 AM
    #889
    kingk0ng
    11 TRD OR AC
    just a few things.
    any reason why hole have to be horizontal? i just pressed it in with wider bushings out
  10. Apr 12, 2019 at 3:57 PM
    #890
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Wrong thread.
  11. May 19, 2019 at 12:53 PM
    #891
    Jultepod
    Jultepod Well-Known Member
    Oahu, Hawaii
    2013 Gray Tacoma TRD
    K&N cold air, Exhaust, rims and tires, 3" king extended travel coilovers and total chaos UCAs, rear diff breather mod, CBI off-road ditch brackets with Cali raised LED pod lights and painless wiring harness, 4xinnovations rock sliders, cab mount chop.
    Dddaaammnnn $216 just in parts to rebuild. Doesnt includ the cam bolts or whatever a shop will charge to press. Was hoping this rebuild would be a little cheaper :( debating on getting replacments from rockauto now.
  12. May 19, 2019 at 1:36 PM
    #892
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The biggest weak point of aftermarket LCA's, I have found out, are the ball joints. I have less than 15K miles on Dorman LCAs I got from Rockauto and the BJs are shot, especially the pass side BJ. I found out inadvertently when I separated the BJ bracket to install new coil springs. With no load on the BJ,'s they turn in place with no resistance; the pass side has play. So, who knows when they actually went out.
  13. Jun 4, 2019 at 12:42 PM
    #893
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    I'm curious if you or anyone can comment on their experience installing the aftermarket moog LCAs with whiteline bushings on their 2nd gen?
    The reason I ask is that I just tried installing my moog LCAs with brand new whiteline bushings, and the bushings will not clear the mounting tabs even without the washers. There's just no way it's going to fit. Another TW member was nice enough to give me his old factory LCAs and when I hold them side by side with the moogs, there is an obvious difference in the distance between the arms of the LCA...easily 1/4 of an inch. Either the Moogs are manufactured to slightly different tolerances than OEM toyota LCAs, or I bent the shit out of two control arms.
  14. Jun 6, 2019 at 10:30 AM
    #894
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    I would guess you probably bent the metal when pushing out the moog bushings or when pressing in the whiteline ones. You should go to the parts store and compare them to another set of moog arms if that's an option.
  15. Jun 6, 2019 at 10:35 AM
    #895
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    That's what I originally thought, but the shop of course swears it's impossible that anything they did would have caused them to bend. It's more of a curiosity for me at this point. They are currently pressing everything out of the moogs and into the toyota ones I dropped off.
    So you didn't have any trouble installing the moog LCAS with the whitelines?
  16. Jun 6, 2019 at 10:40 AM
    #896
    gunn_runner
    Rocky River, OH
    2013 DCLB TRD
    No trouble, they fit the same.
