DIY LCA Bushing Replacement 2005+ Tacoma (4x4)
Discussion in 'Suspension' started by XXXX, Sep 7, 2011.
  1. Sep 17, 2013 at 6:25 AM
    #121
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you can pull nut, bolt and that sleeved bolt out completely, it's obviously not seized and there's no reason Firestone shouldn't have been able to align the truck. Mine were seized, I couldn't pull the bolts out from within the bushing, it was all a rusted together mess.
    As far as what's spinning, with the bolt out and nothing tightened, the bushing should stay with the LCA and spin within the LCA tabs. Once you put the bolt in and tighten it down, the inner bushing sleeve should stay with the bolt (and truck frame) and the outter bushing sleeve should move with the LCA, forcing the rubber to 'twist' as the suspension cycles.
  2. Sep 29, 2013 at 2:00 AM
    #122
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I follow your logic. In fact that was exactly what I was thinking. I'm going to get a 26mm socket and see if I can turn it myself. But when I had it apart last time I tried to hammer the sleeve out of the bushing and it didn't budge. I actually ruined the end of it a bit and almost couldn't put the plate/nut back on it.
  3. Oct 1, 2013 at 3:29 PM
    #123
    PATACO13
    PATACO13 Well-Known Member
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    Quick question on old thread. I've installed 5100's in the front and prior to getting an alignment, my shop warned me about the tendency of cam bolts to seize in LCA bushings. After plenty of research on TW, I've been soaking with PB Blaster for a week or so.
    My question is: If they are seized up, will the cam tabs be bent? Or rather, can the cam bolts be seized up without bending the tabs? My tabs are all perfectly straight. I know this thread is for 2nd Gen but I drive an 03.
    Thanks
  4. Oct 1, 2013 at 3:49 PM
    #124
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    tab can bend but not always
    go outside mark the cams position
    and take a 19mm socket and wrench and take apart
    if not seized grease them before they do....
    i dont understand why everyone does not do this when they get the truck or before getting an alingment.....
    just had mine apart..after greasing them the year before
    and even after irean and sandy and all the beach driving and such they still work smooth as silk
    good luck
  5. Oct 1, 2013 at 3:55 PM
    #125
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    I need to do this :/
  6. Oct 1, 2013 at 4:12 PM
    #126
    PATACO13
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    thank you. first i'd heard of this issue when the owner of the alignment shop told me that 9/10 tacomas are seized. they're a specialty shop in business since 1919 so I trust them. but I just picked this truck up a month ago, my second Tacoma. i'll get under there and check it out. do I need to jack up the LCA before doing so?
  7. Oct 1, 2013 at 4:18 PM
    #127
    brutalguyracing
    F.U> GUYZ
    broken mods
    you could jack it up but not needed...do one at a time.......
    mark the cams and take apart....
    if i remember right the front have the bolt and sleeve and the rears have only the bolt...
    i cant remember tho maybe some will chime in as to that
  8. Oct 2, 2013 at 8:45 AM
    #128
    Pugga
    Massachusetts
    I believe that is correct. The fronts are the weird sleeve and the rear is just a bolt.
  9. Oct 2, 2013 at 10:18 AM
    #129
    PATACO13
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    cool thank you! I was able to pull the bolt from either side in front and rotate the cams. appears that previous owner did replace them, they are by far much shinier than any other piece of hardware on the truck haha. they weren't greased though so I smothered them with red n tacky. sorry no pics. I didn't get into the rears because I don't feel like messing with steering gear boots and tie rods. but the fronts being that free put my mind at ease and i'll report back after I get it aligned. thanks again
  10. Oct 2, 2013 at 4:25 PM
    #130
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
  11. Oct 7, 2013 at 12:58 PM
    #131
    PATACO13
    Ian
    Erie, PA
    '03 V6 TRD 4x4
    stock
    I got lucky...all four cams were free inside the bushing and rides much straighter after alignment
  12. Oct 11, 2013 at 6:55 AM
    #132
    brutalguyracing
    F.U> GUYZ
    broken mods
    and you have been waiting for is now here
    and cheap too....
    stay tuned.....
  13. Oct 11, 2013 at 6:56 AM
    #133
    Pugga
    Massachusetts
    Nice! Servicable LCA bolts :woot:
    Is the bolt flat on one side so the eccentric washers stay oriented the same way?
  14. Oct 11, 2013 at 7:24 AM
    #134
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    From who
  15. Oct 11, 2013 at 9:34 AM
    #135
    XXXX
    sKiP
    05 Prius
    Not so sure I would want hollow LCA bolts, but I'm glad to see someone has finally changed it up and is trying something new.
    They sure as heck don't look like the Whitting bushing/LCA kit I want someone to try & they also don't have those cheesy plastic bolt liners like the other kit.
  16. Oct 11, 2013 at 10:18 AM
    #136
    brutalguyracing
    F.U> GUYZ
    broken mods
    And thats why u dont have them
    I trust moog
    Rep said they were engineered just for us
  17. Oct 11, 2013 at 10:19 AM
    #137
    brutalguyracing
    F.U> GUYZ
    broken mods
    Too each his own
    Saved me a boatload of money
  18. Oct 11, 2013 at 10:24 AM
    #138
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  19. Oct 11, 2013 at 10:39 AM
    #139
    Pugga
    Massachusetts
  20. Oct 11, 2013 at 10:42 AM
    #140
    Sandman614
    Tim
    '06 SR5 Off Road
    I did the same but didn't get a picture for that one.
