DIY LCA Cam replacement 2005+ Tacoma
Discussion in 'Suspension' started by XXXX, May 14, 2012.
  1. May 14, 2012 at 5:14 PM
    XXXX
    XXXX [OP] Well-Known Member
    sKiP
    05 Prius
    This is for removal and replacement of totally seized OE LCA CAM bolts and sleeves ONLY.
    I am not covering the removal of OE components that are in the way of LCA bolt removal and installation.
    You may be able to get them free once seized thus saving yourself time and money, but if they have been seized greasing them up will only delay the inevitable and they will continue to degrade due to pitting. I recommend replacement of the parts and proper maintenance (continual greasing throughout your trucks lifespan - yes I know it sucks). For those just greasing up the cam bolts: index them, remove all the bolts, clean, lube, and re-install them. Be sure to also clean and grease the inside of the bushings. You should still get an alignment afterwords.
    For LCA bushing replacement see here http://www.tacomaworld.com/forum/sus...ml#post3691528
    For LCA ball joint replacement see here http://www.tacomaworld.com/forum/su...oint-replacement-2005-tacoma.html#post3691540
    <<<A front end alignment is highly recommended after you swap CAM bolts and sleeves even if you indexed them>>>
    Tools required:
    Common Sense
    1/2" Impact ratchet
    1/2" Ratchet
    ??? mm impact socket (1/2" drive)
    PB Blaster or similar
    Mobil 1 or similar grease
    Gloves
    Safety glasses
    Grinder and cut off wheels
    Sawzall and metal blades
    Cutting wax
    Aluminum colored sharpie
    Cup, water, and Goof Off (or similar)
    It's YOUR responsibility to wear the proper PPE and use common sense. This could prove dangerous if the tools required are used in manners they were not designed or intended for. Do not apply torque to the tools past their recommended limit.
    Toyota Parts required:
    (2) of these
    (2) of these
    (2) of these
    You will need to remove the stickers on the front cams. Do not use anything abrasive. I soaked them in water overnight then cleaned off the adhesive with Goof Off.
    The remaining hardware can be reused as long as you cut the LCA's off correctly. IMO there is no need to replace good hardware.
    Everything needed for the front:
    Everything needed for the rear:
    Removal
    Note: Lube all threaded bolts, nuts, etc. before attempting to loosen them. I lubed mine up every days for about a week before touching anything.
    Step 1: Index the cams by marking them in 2 locations front and rear.
    You will still need an alignment, but being able to get them back to close will be safer.
    (I didn't take pics of my indexing mine so here is from the install - note I had to transfer the markings to the sides of the new cam)
    Step 2: Loosen all the nuts and cut the front of the rear bushing. Be careful not to cut into the frame.
    If you want you can try a sawzall, but I found this to be a poor tool for the job. It was time consuming even using high quality Lenox steel blades and wax. I found using cut off wheels to be much quicker although not as safe. Having some smaller cut off wheels (used ones) proved to be key for the final bits of cutting. They can be used where a larger wheel will hit the frame.
    Step 2: Loosen all the nuts and cut the rear of the front bushing. Be careful not to cut into the frame.
    At this point the LCA will come right out. You now need to remove the old bushings in the LCA and put new ones in. See here
  2. May 14, 2012 at 5:14 PM
    XXXX
    sKiP
    05 Prius
    Installation
    Step 1: Transfer index marks to new hardware. I usually lay them on a table and use a small framing square.
    (Sorry no pics)
    Step 2: Install LCA's with pre-lubed bushings
    Front
    Rear
    Step 3: Front LCA
    Install sleeve into front LCA mount towards the rear
    It will stick out the back of the front LCA mount if you did it right.
    Install re-used cam plate to the rear of the front LCA mount
    Insert front LCA bolt from front towards rear
    Hand tighten. When your done with the rear come back and torque to 110ft# or some shit
    Step [SIZE=3]4[/SIZE]: [SIZE=3]Rear LCA
    [/SIZE]
    Insert lubed bolt from front to back[SIZE=3]
    [SIZE=3][ATTACH=full]1665469[/ATTACH]
    [SIZE=3][ATTACH=full]1665472[/ATTACH]
    [SIZE=3][ATTACH=full]1665478[/ATTACH]
    [/SIZE][/SIZE][/SIZE][/SIZE]
    Install re-used cam tab and nut. Torque to balls ass tight. [SIZE=3][SIZE=3][SIZE=3][SIZE=3]
    [SIZE=3][ATTACH=full]1665481[/ATTACH][/SIZE]
  3. May 14, 2012 at 5:29 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    19 mm for LCA bolt removal :thumbsup:
    EDIT: NVM, this is for the sleeves, those are bigger.
  4. May 14, 2012 at 5:30 PM
    XXXX
    sKiP
    05 Prius
    lol...
    sorry I'm a little late for yours :D
    We also need a GOOD wheel bearing thread. The ones I have seen are seriously lacking
  5. Aug 9, 2012 at 10:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Fix yer damn threads
  6. Aug 10, 2012 at 10:24 AM
    XXXX
    sKiP
    05 Prius
    :brianr:
    we got 85,000 members.....maybe some of them should put down the platiderp and contribute to this place :D
    Maybe this weekend buddy.....maybe
  7. Aug 23, 2012 at 7:58 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    any updates?
    Is the Qty of parts to replace all 4 cams or just the one seized cam?
    I'm already piecing together pricing to see how much it will cost to refurbish a used set of LCA's with a Moog balljoint and aftermarket bushings.
  8. Aug 24, 2012 at 11:00 AM
    XXXX
    sKiP
    05 Prius
    This stuff is what you would need should you cut exactly where I did and had 4 seized up on you. If you cut the right stuff when removing it the less parts you will need (what I did).
  9. Aug 25, 2012 at 10:04 AM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    Got it. so if it looks like i only have one that's seized, then i will only need the parts for a "drivers front" cam. will it be fine to reuse the other ones as long as I grease them again?
  10. Dec 30, 2012 at 11:11 AM
    XXXX
    sKiP
    05 Prius
    You OK? Still got questions?
    I finally got around to completing the thread. Still needs some polishing, but it's 99% there.
    Sorry for the wait.
  11. Mar 21, 2013 at 11:25 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    has anyone used any other brands for alignment cams?? is Toyota in major centers more than like to have a toe set-up..... I kind of hit a snag tonight, how is it only 1/4 was seized ugh, I now know why the alignment was never able to be perfect though......
  12. Mar 22, 2013 at 7:31 AM
    OZ-T
    Peter North
    British Columbia
    SPC makes a kit
  13. Mar 22, 2013 at 7:33 AM
    OZ-T
    Peter North
    British Columbia
  14. Mar 22, 2013 at 8:31 AM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    thanks i think the factory kit looks a little more robust lol
    thanks though!! The good news is ill have a new part by noon
  15. Mar 22, 2013 at 8:33 AM
    OZ-T
    Peter North
    British Columbia
    I agree , but I do like that the SPC kit has a sleeve to keep the bolt from seizing to the bushing
  16. Mar 22, 2013 at 9:39 AM
    XXXX
    sKiP
    05 Prius
    Good find Peter!
  17. Mar 22, 2013 at 9:40 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i hate the factory front cams...ive broken 4 of them
  18. Mar 22, 2013 at 2:19 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
  19. Mar 22, 2013 at 4:49 PM
    OZ-T
    Peter North
    British Columbia
    Yeah , looks like 1 kit does 1 LCA
    Edit : It even says 1 kit per wheel in the link , lol
  20. Mar 22, 2013 at 4:56 PM
    XXXX
    sKiP
    05 Prius
    Someone needs to buy them and test them out to see how long that plastic lasts.
    I only have another 2-3 years on my new bushings & bolts :D
