DIY leather arm rests
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reid, Sep 1, 2007.
  1. Oct 5, 2012 at 7:11 PM
    #301
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    In the leather interior group buy thread there is a link to a company that sells the center console cover and door handle covers as well as replacement shifter boots... RedLine somethinorother... :eek:
  2. Oct 5, 2012 at 7:35 PM
    #302
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    just make sure there is at least a backing on the fabric. don't want the glue/adhesive to go through when you apply. It happened to me when I wrapped my center console top.
  3. Oct 5, 2012 at 10:07 PM
    #303
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    good point. thanks for the info. i'll keep that in mind when i get the fabric.:thumbsup:
  4. Oct 6, 2012 at 5:45 PM
    #304
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    so i dove in and went for it. did both rears. went with a micro-suede. i'm pleased with how they turned out. :D:cool:
  5. Oct 6, 2012 at 9:52 PM
    #305
    JayS
    JayS Well-Known Member
    Angleton, TX
    05 Prerunner Stock
    How many people here put padding under the material on the armrest? I am about to recover mine as they did not turn out very good, and I am not sure if I need to put padding back under there. I don't really use them anyways.
    dh920trd likes this.
  6. Oct 7, 2012 at 12:23 AM
    #306
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    i used realtree for mine :D
  7. Oct 7, 2012 at 6:38 AM
    #307
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Got a link ? I did a search for RedLine somethinorother and the closest I got was hood struts. Thanks.
  8. Oct 8, 2012 at 3:33 AM
    #308
    thomask
    thomask Active Member
    08 DC Radiant Red TRD Sport
    Westin Skid Plate Bull Bar PIAA Fog Lights JVC Navigation Stereo Unit
    How did you get the rear door power window switch out to paint it? I couldn't get it out for the life of me! Did you have to take the rear door panel off?
  9. Oct 8, 2012 at 10:31 PM
    #309
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    once i got the door panel off, i was able to get it out easier. on one side of the switch there is a spring clip, so i went from the inside of the door panel and squeezed the spring clip and lifted to switch out. then to get it unplugged, there is a small clip on the connector that has to be pressed down. while pressing the clip, pull the connector out. a small screwdriver helps to push the clip down.
  10. Oct 21, 2012 at 9:46 AM
    #310
    Fiend13
    Fiend13 Well-Known Member
    Chad
    Waddell/Phoenix area
    08 TRD O/R DC Prerunner
  11. Oct 21, 2012 at 11:11 AM
    #311
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Here you go (this is mine):
    Perforated vinyl to match upper door panel.
    Top part is the plastic upper part of the door panel and bottom is the perforated vinyl
    bender85, LamzTaco and kgarrett11 like this.
  12. Nov 15, 2012 at 11:22 AM
    #312
    wareagle1
    wareagle1 Well-Known Member
    Brad
    Fayetteville, TN
    07 Tundra DC 5.7
    notta
  13. Nov 15, 2012 at 12:19 PM
    #313
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    The company is called Redline Goods. I have their console cover and armrest covers.
    Very good quality.
  14. Nov 15, 2012 at 7:51 PM
    #314
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    This is how I want mine. Thanks for the pics. I am off work next week. This may finally happen......
  15. Jan 15, 2013 at 4:40 PM
    #315
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    Looks like I have another excuse to spend time working on my truck. My girl swears we a bangn :)
  16. Jan 15, 2013 at 4:45 PM
    #316
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    Sub'd, hope to do this soon.
  17. Jan 16, 2013 at 5:45 AM
    #317
    Bigcanoe
    Bigcanoe Active Member
    Moncure , NC
    06 double cab 4x4 sr5
    Hey, where did you get the matching vinyl and how much did you use, looks good!
  18. Jan 16, 2013 at 11:05 AM
    #318
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    Right on, you are in BC bro :D, you can hook me u:Dp on a deal for the leather, perhaps...:canada:
  19. Jan 16, 2013 at 11:11 AM
    #319
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    sub'd looks great!
  20. Jan 16, 2013 at 11:17 AM
    #320
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :wave:
    I looked at Joanns in Cary and didn't see it.
