DIY Noise isolating tool for around $30.00
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Dec 15, 2016.
  1. Dec 15, 2016 at 8:57 AM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Okay guys this tool is the best way to isolate noises. https://www.amazon.com/Steelman-066...srs=3043628011&ie=UTF8&qid=1481818368&sr=8-64
    I have one but you can put a few items from radioshack and an old pc mic together for around $30 bucks, with one pickup lead. You clamp it on to spots you think the noise is coming from. Drive down the road and listen. If you have more leads its faster and easier to find noise because you can switch between pickups. The Steelman I have has 6 pickups and a selector switch.
    DIY chassis listening device:
    1. One https://www.amazon.com/DricRoda-Professional-Karaoke-Portable-Amplifier/dp/B06XRXZ8YJ/ref=sr_1_13?ie=UTF8&qid=1511542754&sr=8-13&keywords=MINI+microphone+AMPLIFIER $23
    You'll need a cigarette lighter adapter to power it. It's 12vdc. Just make sure the plug is pinned correctly for box.
    2. Battery clip as many mics you decide to make: https://www.amazon.com/SODIAL-Coppe...d=1511544498&sr=1-33&keywords=alligator+clips $3.00
    3. Source for pc mic. peel the foam wind screen off and don't use small clip it comes with.. Epoxy it to the larger battery clip. https://www.amazon.com/Neewer-3-5mm...e=UTF8&qid=1511544654&sr=1-64&keywords=pc+mic
    Mic extension https://www.amazon.com/iMBAPrice-Pr...d=1511544907&sr=1-6&keywords=3.5+mm+extension
    4. Epoxy the microphone on the inside of the battery clip. Cover the hole up were sound enters mic but don't fill it. You want to block outside noises and just hear noise transmitted thru clip.
    6. A set of ear buds.
    Clamp you mic to a suspect area. Shock mount, shackle, etc. Secure wire with zip tie or wrap it around something to secure it if clip falls off. Run the wire into the drivers compartment plug it all together and turn it on.
    Go for a test drive.
    ThunderOne likes this.
  2. Dec 15, 2016 at 9:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    That's a pretty great idea, I've got a few rattles and squeaks I hope go away once I do my timing belt and water pump. If that doesn't do it, I might employ this idea!
    ...But the last pic on the add for the steelman: I just hope he cleans up those wires before is starts the engine! :)
    Radio shacks are getting harder and harder to find these days, at least 'round these parts... Well, I mean, if you want a cell phone or a stupid drone they're pretty good, but if you want a switch relay or some specialty electronic tool, they're garbage. I usually end up online.
  3. Dec 15, 2016 at 10:21 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    all you really need is the empty tube from a roll of paper towels
    put it to your ear and it blocks out other noises its not pointed at and you just follow the noise until you locate it
  4. Dec 15, 2016 at 11:30 AM
    jbrandt
    Justin
    Sacramento, CA
    I think the idea is that this method allows you to DRIVE it while listening for noises. Some noises only manifest while driving.
  5. Dec 15, 2016 at 11:38 AM
    ThunderOne
    ThunderOne Banned
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Best new member award goes to this guy
    jjsul likes this.
  6. Dec 15, 2016 at 11:43 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    The idea is to be able to drive it at any speed necessary to duplicaste noise. The make a better tool then a paper towel role. Stethescope with aluminum probe on the end. Found them at Harbor Freight for 2 bucks.
  7. Dec 15, 2016 at 12:02 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  8. Dec 15, 2016 at 4:10 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Lmao! Hahahaha... In no way am I laughing at someone, I'm just laughing at the second sentence. Hahahahaha
    mechanicjon [OP] likes this.
  9. Nov 24, 2017 at 10:36 AM
    mechanicjon
    Jon
    Scottsdale Arizona
