DIY Oil Change Hiccups
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stripminer, Sep 22, 2014.
  1. Sep 22, 2014 at 5:18 PM
    Stripminer
    Stripminer [OP] Member
    CT
    14 DCLB TRD Sport
    not yet....
    So, I decided to change my own oil today. Hit up Wally world for some oil and filter and got set up in the garage. All was going well until it came time to change the filter. What I thought was the perfectly positioned oil filter, turned into a bit of a challenge. Spinning off the filter brought a lot more oil into the catch than I expected. I tried to catch the overflow but spilled oil into my frame and onto my garage floor. Suddenly my money saving venture was a huge headache.
    So, I searched it up with no real answers to be found ( ok I'm too pissed to really look hard). Where did I go wrong? Water bottle under the catch nipple? I liked turning the wrench and getting it done myself but don't want to have hose out my frame again. Any constructive criticism is appreciated. Thx!!
  2. Sep 22, 2014 at 5:22 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    There is a rubber nipple cover that needs to be removed to let the oil drain into your catch cup.
  3. Sep 22, 2014 at 5:25 PM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    I used some 3/8 hose and connected it to the nipple and dropped it to my oil catch pan.
  4. Sep 22, 2014 at 5:25 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Small coffee can (plastic one) worked perfect for me.
  5. Sep 22, 2014 at 5:26 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Make sure the drain for the shield is clear (mine is always clogged) and put a water or gatorade bottle under.
  6. Sep 22, 2014 at 5:26 PM
    Gatorstaco
    Gatorstaco Well-Known Member
    Gaetan ( Gator)
    ontario
    14 X-Runner
    AFE Cold air, Magnaflow exhaust, all AMS oil, tonneau cover, and Cap hitch, extra LED light(back). LED fog lights. Summer wheels Scan gauge II. Sirius radio
    Get a tub that will hold minimum 5 quarts of oil. Always have kitty litter on hand for emergency. Do get a small hose to attach at the bottom of the filter cup. The 4.0 L takes 5 quarts with the filter, my X-Runner does. Your set up should be the same as the X-R I think.
  7. Sep 22, 2014 at 5:29 PM
    jsi
    jsi Well-Known Member
    native earthling
    Been there - done that - got the oil stain on the floor :eek:
    I bought some clear plastic tubing to attach to the drain on the bottom of the filter thing-a-ma-bob. I put the other end into a pop bottle. That makes the change easy. (Especially if I've done it and not over tightened the filter like the guys at the quicky like to do)
  8. Sep 22, 2014 at 5:35 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    I am not sure if it makes a difference or not but I always drain the pan first, then remove the filter. BE SURE & REMOVE THAT NIPPLE file IFR mentioned, (& catch the oil there)I have used the hose method & the bottle or can under the nipple drain & both work well
  9. Sep 22, 2014 at 5:37 PM
    File IFR
    Central MA
    Fixed for you. ;)
  10. Sep 22, 2014 at 5:40 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I do the same. I use a rubber glove to catch the oil out of that little nub. Easy to manipulate into position.
  11. Sep 22, 2014 at 5:48 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Don't forgot to remove whatever you used to catch the oil with (ie. water bottle) or else you'll get oil all over the floor. Ask me how I know.
  12. Sep 22, 2014 at 6:46 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    Have read the suggestion to drain the pan, poke a hole in the top of the filter and walk away for awhile. The filter will drain most of the oil into the engine and out the bottom.
    I usually don't have the patience to wait long enough for the filter to completely drain. :)
  13. Sep 22, 2014 at 7:00 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I've not had a problem taking the rubber cap off, putting a plastic water bottle under it and spinning the oil filter off. My guess is the rubber cap wasn't off.
  14. Sep 22, 2014 at 8:06 PM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
  15. Sep 23, 2014 at 7:15 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    I used to use the plastic hose attached to the filter drain hole...switched to a small plastic bottle where I added a simple hook...hangs on the filter housing...easy
    And OP...don't buy filters at Walmart...they usually carry FRAM...don't fram your truck...go to Toyota and get some OEM filters. Check out the size difference. In a pinch I have used Valvolene and NAPA Gold.
  16. Sep 23, 2014 at 10:56 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This.
  17. Sep 23, 2014 at 11:03 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I changed the oil on a 2nd gen (4.0) the other day and I must have let the oil drain for longer than normal because there was no oil in the filter when I removed it. It was nice to not need a catch can under the filter.
  18. Sep 23, 2014 at 11:22 AM
    gooch14
    gooch14 Well-Known Member
    Kyle
    Michigan
    2011 Blk DC Taco SR5 4x LB
    Bestop, Child Seats, petrified french fry, dog hair, empty Mtn Dew cans cracked windshield, scratches.
    This, I cut the bottom off a 64oz juice bottle, thin enough plastic to bend and contort it into place and big enough to hold the filter's oil.
  19. Sep 23, 2014 at 11:25 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Drain tube attached to the nipple on the bottom of the filter housing. Even tells you in the manual.
  20. Sep 23, 2014 at 11:47 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Old oil will be about 5 quarts. I'd suggest at least at 10qt (2.5 gallon) drain pan. It will slosh a little when moved/carried. Did not find out the hard way.
