DIY pressurized water tank update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daohaus, Jul 21, 2017.
  1. Jun 22, 2018 at 3:08 PM
    #61
    theox26
    theox26 Well-Known Member
    '11 DCLB Sport
    That's a good plan. Most people don't know but plastic can be welded. So they may do that instead of setting up the mold for it and doing custom extrusion. There is a Mennonite guy here in PA that does it and the prices for custom work are crazy cheap.
    Geronimo1111[QUOTED] likes this.
  2. Jun 22, 2018 at 3:11 PM
    #62
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    Just talked with Plastic-Mart. They don't have anything in the size (height) I'm looking for...
    Unfortunately, it costs $2,000 to $3,000 to set up a mold for a custom tank.... I think I'm going to need to look at another company or go custom s/s fabrication. :fingerscrossed:
  3. Jun 22, 2018 at 3:13 PM
    #63
    Geronimo1111
    As long as it holds up to banging around off-road, I wouldn't mind if it is welded... Do you have contact info for the Mennonite guy?
    I can also ask Plastic-Mart if they weld plastic...
  4. Jun 22, 2018 at 3:18 PM
    #64
    theox26
    '11 DCLB Sport
    https://goo.gl/maps/gwaFw7hjeZC2
    Here is his info. I'd just search your area for plastic welding too. Shipping would add a significant cost for the size you are looking for.
  5. Aug 12, 2018 at 12:31 AM
    #65
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I've seen large flat bladder bags similar in shape to your notion. You'd need to pump it instead of pressurizing it though.
  6. Aug 12, 2018 at 5:24 AM
    #66
    lsutiger1
    lsutiger1 Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    Just bought a rigid shop vac pump that is designed to pump out a shop vac. Wonder how that would work with another type of container? I think it would work great as long as I could getting the fitting to work
  7. Oct 10, 2018 at 4:04 PM
    #67
    vytec
    vytec Active Member
    Gregg
    Austin, TX
    2018 Tacoma TRD Pro
    A.R.E CX Shell, Warn Hidden Winch, SmittyBuilt X20 Waterproof 10K Winch, BedSlide, LED Tail Lights, LED Headlights, More mods to come.
    Before I got the Tacoma I had an SUV with not a lot of room in the back so we got a portable RinseKit Soft Sided pressure shower. You can fill from hose and it will pressurize it to hose pressure and then you can also add a pump to add more pressure as you use it and it even has a 12V heater stick to warm up the water as well. Holds 3 gal of water and works very well. We used to rinse off our dog when we're out training in the mucky water so she doesn't stink up the truck. Now that we have the truck, I might have to look into some of these options.
    Amazon Link - https://amzn.to/2A3fXPp
    SkitchOK likes this.
  8. Oct 10, 2018 at 4:05 PM
    #68
    vytec
    vytec Active Member
    Gregg
    Austin, TX
    2018 Tacoma TRD Pro
    Where do you find those attachments for the track system to hold your shovels, jack, etc....? Sorry new Tacoma owner and still learning where to find all the cool stuff. Thanks.
    Bastek[QUOTED] likes this.
  9. Oct 10, 2018 at 5:03 PM
    #69
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    For the shovel and the axe, I made the attachments myself--I followed a diy thread in here. Let me look for it.
    Jack attachment, I winged a bit, mirrored Hi-Lift's design (Loc Rac) so I could fit it under my cover. But to tell you the truth, with the amount of time I spent messing with that, it makes more sense to buy something pre-made (unfortunately it wasn't commercially available, lol).
    Edit. BTW, welcome to TacomaWorld!! I should have started with that, lol.
    Black taco. likes this.
  10. Oct 10, 2018 at 5:24 PM
    #70
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Here. Found this one, it's a great guide!
    DIY Hi-Lift and Tool Mounts
    And another thread with some more links and good info
    hi-lift/shovel mount - pics please
    Have fun!
  11. Oct 11, 2018 at 5:41 AM
    #71
    vytec
    vytec Active Member
    Gregg
    Austin, TX
    2018 Tacoma TRD Pro
    THANKS for the info and the welcoming. Looking forward to tricking out my truck and so far I'm really enjoying it.
  12. Oct 21, 2018 at 2:40 PM
    #72
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  13. Oct 21, 2018 at 3:19 PM
    #73
    Zuba987
    Zuba987 Well-Known Member
    Enola PA
    2006 ACLB V6 auto 4x4
    Fully armored, STT Pros and Methods.
    I’m definitely making this before my next trip. Will be really useful after a long day of work in the summer too
  14. Oct 22, 2018 at 8:09 AM
    #74
    Taco Pusher
    Taco Pusher Well-Known Member
    Brian
    2016 Red TRD off road
    None yet
    have you thought about a heat exchanger inline with the cooling system https://www.youtube.com/embed/4TliLRT4btI
  15. Jan 11, 2019 at 6:10 PM
    #75
    peuki
    peuki New Member
    black 2018 trd pro
    not yet
    this is super
  16. Jan 11, 2019 at 8:35 PM
    #76
    ronin_yota
    ronin_yota Well-Known Member
    Nice idea
  17. Jan 12, 2019 at 2:54 AM
    #77
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Nice do you have more pictures and specs on build would like to make one
  18. Jan 13, 2019 at 12:31 AM
    #78
    bagleboy
    Scott
    Norcal, Santa Rosa
    You could probably strengthen the pipe by adding some straight couplers with the stops removed so they slip over the tube and space them along the length.
  19. Oct 14, 2019 at 3:36 AM
    #79
    gmanrider9
    gmanrider9 Well-Known Member
    Garrett
    Longmont, CO
    2009 Blue Toyota Tacoma TRD DBC
    3" Toytec Lift, Rigid Industries Grill, 10" SR2 Light Bar, Auxbeam Front Spot Rear Flood, All Pro Bumpers, Projector Retrofit Lights, 33" Tires, Smittybuilt Winch, Raised K&N Air Intake
    How did you end up mounting the tank?
  20. Oct 14, 2019 at 4:46 AM
    #80
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    For this, I bent some 1/8" steel, one side bolted to hi-lift bracket, the other is resting on in bed floor. Tank is mounted to it with quick fist clamps.
    But, I scrapped that set up. It was taking way too much space.
    I moved the tank to the bed rack
    gmanrider9[QUOTED] likes this.
