DIY pressurized water tank update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by daohaus, Jul 21, 2017.
  1. Oct 14, 2019 at 3:16 PM
    #81
    gmanrider9
    gmanrider9 Well-Known Member
    Garrett
    Longmont, CO
    2009 Blue Toyota Tacoma TRD DBC
    3" Toytec Lift, Rigid Industries Grill, 10" SR2 Light Bar, Auxbeam Front Spot Rear Flood, All Pro Bumpers, Projector Retrofit Lights, 33" Tires, Smittybuilt Winch, Raised K&N Air Intake
    Has anyone had any luck mounting this tank to their stock roof rack?
  2. Jul 13, 2020 at 10:56 AM
    #82
    josiemobile428
    josiemobile428 Well-Known Member
    Jake
    18 TRD OR 4x4 DCLB
    Did you use a nut to attach the pressure release valve, or use adhesive?
  3. Aug 21, 2020 at 7:16 PM
    #83
    Bonestocktruck
    Bonestocktruck Active Member
    Roy
    2001 White DCSB TRD 4x4 -> 2020 Cement DCSB OR
    Bone stock, from 1st Gen to 3rd Gen
    How are you all mounting your water tubes to the bed? I found 4" quick fists to strap the pipe down, but how can I mount that to the rail?
    Edit: I found slot nuts that I can insert into the railing.
  4. Aug 21, 2020 at 8:48 PM
    #84
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    And you could fix the dreaded taco lean at the same time!
  5. Aug 31, 2023 at 9:22 AM
    #85
    DonTacoma
    DonTacoma Well-Known Member
    Oklahoma
    2022 TRD Off-road DBSB MGM
    Non yet.
    For reference:
  6. Sep 11, 2024 at 10:54 PM
    #86
    LP808
    LP808 Well-Known Member
    2016 Base SR5 Tacoma
    None
    Would any of you have a parts list for this or know what schrader valve specifically would work for this. How did you guys install the valve? Drill a hole big enough for the thread to screw into?
