DIY prinsu style shell rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paranoid56, Nov 23, 2017.
  1. Jun 7, 2021 at 6:15 AM
    #1101
    Amstutz795
    Amstutz795 Well-Known Member
    Jordan
    2013 Tacoma TRD
    Man I am so happy i found this thread. Was just about to order off McMaster Carr and attempt this. Never knew about Tnutz.
  2. Jun 7, 2021 at 9:15 AM
    #1102
    hanahou7
    hanahou7 Well-Known Member
    2012 Tacoma DCLB 4x4
    Bilstein 5100s OME 885 2" AAL
    Sweet lookin rack bud! Yea, I have a cab rack I built and a camper shell rack and the wind noise is pretty loud. Only solution I've found is to turn up the radio.
    654ZOLn2Oo5SHJBN0PnmuTnOu_Q8kcxqCtsVQM2i_03c5ddcb538aad1337007ec333b75c23c33b7438.jpg
    RepoMarket and JRYTacoma like this.
  3. Jun 7, 2021 at 5:32 PM
    #1103
    TacoManSam
    TacoManSam Well-Known Member
    Sam
    Saint Augustine, FL
    2013 White Tacoma TRD Sport DCLB V6 4x4
    Faux TRD Pro Grille | 3rd Gen TRD-OR suspension | 6' Leer Topper | Running Boards
    Is that a double cab rack setup I see you've got going on? o_O
    Look like an OEM roof rack with a cab rack on top?
    Double cab rack POWER!!! :headbang:
    PS - Sweet ride by the way, I've got a white DCLB too. I love it! :thumbsup:
    hanahou7[QUOTED] likes this.
  4. Jun 12, 2021 at 10:22 AM
    #1104
    Tooshort
    Tooshort Well-Known Member
    Eric
    2022 DCSB TRD-OR 4x4
    What was the length of your bars after cut? Also what's your cut angle on the front and back? I need to grab a blade for my miter saw that can cut aluminum
  5. Jun 13, 2021 at 9:37 PM
    #1105
    hanahou7
    Yea haha I built both racks and they’ve been super helpful. I had the oem rack and figured I would just bolt a diy rack to that.
    thanks! I love the truck. Can’t imagine driving anything else haha
  6. Jun 18, 2021 at 6:01 AM
    #1106
    Stranger45
    Stranger45 Active Member
    Sevierville, TN
    Might I ask who did the CNC work?
  7. Jun 23, 2021 at 6:21 PM
    #1107
    Tooshort
    Eric
    So I finally finished up, I need to get a few more coats of bed liner on them.
    If you go for the 4 inch, you need to know that the prinsu feet are going to be about an inch short, you can rectify this with the 1" square tubing and it will match the victory 4x4 perfectly. I have the tubing but haven't cut it or drilled just yet as I didnt know this would be an issue until I put it all together.
    I opted to match victory 4x4 almost exactly, with just a couple small changes.
    I got 4" x 60" just in case then I examined victory 4x4 version and measured and marked.
    I started with a planer/router initially for the holes and decided that was a bad idea and went with the jig saw and metal blade.
    After cutting holes and drilling I used the planer to clean edges and round out.
    Next I cleaned with people power and used truck bed liner which matches really really wellIMG_20210618_174607.jpg IMG_20210618_185224_01.jpg IMG_20210620_121334.jpg IMG_20210620_184924.jpg IMG_20210622_222810.jpg IMG_20210623_210616.jpg IMG_20210623_210332.jpg IMG_20210618_174607.jpg IMG_20210618_185224_01.jpg IMG_20210620_121334.jpg
    TheTacomaInn, Kuntrykid and hanahou7 like this.
  8. Jun 23, 2021 at 6:22 PM
    #1108
    Tooshort
    Eric
    Somehow all the pictures came up out of order but I'm rocking my son to sleep so whatever
    scheme_addict likes this.
  9. Jun 23, 2021 at 6:22 PM
    #1109
    Tooshort
    Eric
    I'll get better pictures when it's fully finished
  10. Jun 23, 2021 at 6:28 PM
    #1110
    Tooshort
    Eric
    Also.... Primer, I think I should have primed........
  11. Jun 23, 2021 at 6:33 PM
    #1111
    Hunterdc1
    Hunterdc1 1st shift Waste Control stupidvisor
    Brrrrother
    Mamas don't let your cowboys grow up to be babies
    13 8 lug ltz gasser
    Looks really good
  12. Jul 10, 2021 at 5:07 PM
    #1112
    Tooshort
    Eric
    Finished
    I think I would have gone with the 3" if I had to do it again because I had to use the prinsu feet plus a 1" aluminum bar stock spacer to make it work. It's about a .25 inch above the front can rack but that's ok.
    Lastly I'm going to move the back piece of the cab rack to the back of the shell rack. Instead of having another bar on the far back, I'll have a nice piece to look as if it was intentional. Don't mind the wiring job. Gonna use it for my roof lights on the shell rack.IMG_20210710_164929.jpg
    wi_taco and hanahou7 like this.
  13. Jul 29, 2021 at 6:55 PM
    #1113
    CookieMonster
    CookieMonster Well-Known Member
    Wil
    Norfolk, VA
    '12 DCSB TRD Sport
    I gave this a shot and am pretty happy with the results.
    I had originally planned to draft plans on paper then transfer that design to a 1/4" hardboard template, then I was going use that template to make all the cuts with a flush trim bit on the router... And that went right out the window as soon as I got the materials home. I ended up basically just sketching out an idea on one of the side rails then stuck them together with double sided tape and got to work. I wanted something that looked... a little different from anything else mass produced. I started with two pieces of 1/4" x 4" x 60" and for the feet I used 3" x 1/4" aluminum angle and bent them to match the angle for the roof rails & rack side rails. My only real regret is that I cut them too short, I ended up cutting off about 5" and should've only cut off 2 or 3. The cross bars could've been 1 or 2 inches shorter too but I made it work. For the actual plans/sketch/doodle I had a rough idea on how I wanted it to look and measured for where I wanted the feet to go. Once I had that I marked out the angles taking a speed square and sliding it around until I found something that looked decent. Then marked it and kept repeating that same angle. After I had the basic shape marked out I randomly decided that 12" spacing was good for the cross bars and marked them out. I used then those measurements to symmetrically space out the holes 4" from the center of each cross bar. I measured a ratchet strap to determine the width of each hole and use a 1/2" drill bit and jig saw to cut them out after I made a template for the shape so it would be easily repeatable. Unfortunately I didn't get as many pics of the actual build process.
    228409845_10225822079249472_377958155621_0b335b769fbb9b884d81140b5ac8e7ef7190c3ab.jpg228143430_10225822080369500_707153698156_8b9912d11735d4b8931df9cabf43001caaaaa7e8.jpg228217586_10225822082129544_754272404615_82f9a24600baa9ec77c4c8d7f86a04da0e9a45f2.jpg228296176_10225822082649557_755407274799_d0034de8dee512cd74942b1c7670079425e226c1.jpg228284269_10225822083409576_430451523752_b699368e6ca51986628ec037296b1f08d717c432.jpg228431422_10225822084609606_744622800478_4159329381c486ea81e2aa03013d74611049ddb0.jpg226581596_10225822084289598_432381305862_433200a7224d042500bbbd265822b688ca7118b0.jpg
    TheTacomaInn likes this.
  14. Aug 4, 2021 at 9:27 PM
    #1114
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    Bringing this forward for a member a I ran into today in Fairbanks AK
  15. Aug 9, 2021 at 6:16 PM
    #1115
    coopjl
    coopjl Well-Known Member
    Jeff
    Fairbanks, Alaska
    2014 Double Cab
    ARB Deluxe bull bar ARB Fog lights ARB Driving lights 24" Vision X Light bar ARB Rear locker w/4.56 ARB Front locker w/4.56 ARB Compressor Warn M8000# winch OME HD suspension CBI rock sliders CBI Trail Rider rear bumper with tire carrier and fuel can carrier Lear Topper with wilderness package TRD Matte Black Wheels SlimLine FrontRunner II Roof rack
    Thank You Sir!
  16. Feb 2, 2022 at 2:25 PM
    #1116
    Railroad_Earth
    Railroad_Earth Well-Known Member
    Black 2010 DCSB
    Great write up and can’t wait to get started on this! That being said I’ve gone through more pages than I wanted too and still haven’t found the answer to my question lol. I already have some Thule track on my topper, what mounting feet should get to use my already installed tracks?
  17. Feb 2, 2022 at 4:45 PM
    #1117
    Trungtaco
    Trungtaco Well-Known Member
    Thomas
    Las Vegas
    2018 Toyota Tacoma TRD Offroad 4X4 DCLB
    Fox 2.5 DSC all around, Dirt King UCA/LCA, Icon RXT Leafs pack option 2, Archive hammer hangers.
    Nice works.
  18. Feb 2, 2022 at 5:33 PM
    #1118
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    Check out the Smittybilt ones listed in the ‘products discussed’ section at the bottom of the page. Others have used aluminum square tubing.
  19. Feb 3, 2022 at 9:28 AM
    #1119
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    https://www.tacomaworld.com/threads/diy-prinsu-style-shell-rack.521186/page-52#post-23075162
    ^^Here is a post from a few pages back ^^
    I have the Thule tracks also. I made some feet out of aluminum channel, slightly bent it with my vice to allow for the angled track. 3/4" x1/8" flat bar and some carriage bolts for the portion that slides into the track.
    Here is a link to my entire rack build if you are interested.
    https://www.tacomaworld.com/threads/diy-prinsu-top-rack-made-on-wood-router.653420/
    I have had it on for about 2 years now with frequent off-roading and have had no issues.
    These feet from Sherpa Equipment Co. are also a really good option if you don't want to DIY.
    https://sherpaequipmentco.com/products/adjustable-track-mounting-feet
  20. Feb 9, 2022 at 6:37 AM
    #1120
    Railroad_Earth
    Black 2010 DCSB
    Anyone have some prints or drawings of the side bars they’d want to share with me? I’d like to take em to a local shop to have them cut….
