DIY Raptor Lights - $15-$30
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaDanK, May 8, 2018.
  1. Jun 8, 2018 at 8:34 PM
    #61
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
  2. Jun 8, 2018 at 8:46 PM
    #62
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
    Nice write-up!
  3. Jun 8, 2018 at 9:09 PM
    #63
    Sullivan0930
    Sullivan0930 Well-Known Member
    Daniel
    2024 TRD Offroad. iforce max. Bronze oxide.
    So Big problem here... I was quick splicing into the Purple wire and was clamping it down and then both my DRLs and the marker lights shut off, both sides. The wire isnt cut and everything is connected, checked the DRL fuse and its not blown. But i cant get my DRLs or markers to turn on. any help?
  4. Jun 9, 2018 at 10:17 AM
    #64
    Sullivan0930
    Daniel
    Well after many hours I’m finally all setup. Ended up running add a circuit off the engine. (I can’t see how it would effect the operation like the poster said, maybe didn’t have two fuses in idk. We will see.) Hard to see since its in direct sunlight.
    TacomaDanK[OP], Atl_taco_ and helix66 like this.
  5. Jun 10, 2018 at 11:09 AM
    #65
    gmazz73
    gmazz73 Well-Known Member
    Greg
    2018 Tacoma TRD Offroad Cement
    Can anyone verify that tapping into the side markers will allow these to run on both the daytime running lights and night on automatic?
    soup222002 likes this.
  6. Jun 10, 2018 at 11:11 AM
    #66
    gmazz73
    Greg
    Can you possibly show a pic of where you tapped into your fogs please?
  7. Jun 10, 2018 at 12:30 PM
    #67
    Sullivan0930
    Daniel
    I’ve checked the purple and white with a multi meter and get no current. I’ve tapped them and got nothing so idk how people are getting it. I did add a circuit to the fuel injectors and put a 2A fuse on top and the original 10A on the bottom. Works with no issues.
    gmazz73[QUOTED] likes this.
  8. Jun 11, 2018 at 1:38 PM
    #68
    plode682
    plode682 Well-Known Member
    Southern NJ
    2016 Tacoma TRD Off Road
    Thank god reverse polarity doesn't kill these lights. What idiot thought to make the ground white and black is positive?!
    That's like the opposite of every electrical wiring related thing I've ever done. I was beginning to think maybe I got defective ones, or that they weren't 12v and I killed them. Looked at Amazon description to find the wiring info.
    COYOCO likes this.
  9. Jun 11, 2018 at 1:46 PM
    #69
    Sullivan0930
    Daniel
    Lol same here. At first I was super mad came inside and then looked at the diagrams posted again and was like oooooooh.
  10. Jun 11, 2018 at 2:47 PM
    #70
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    I’d recommend using an add a fuse instead of tapping into existing wiring. Add a fuse is completely reversible and won’t interfere with the factory wiring. It is super easy as well
    ready6delta and Tullie D like this.
  11. Jun 12, 2018 at 5:55 PM
    #71
    TacomaDanK
    TacomaDanK [OP] Well-Known Member
    Daniel
    Spanish Fork, UT
    2016 Tacoma TRD OffRoad
    Custom Roof Rack by Rave Off Road
    I still have mine tapped into the Fuel Injector Add-A-Fuse and still haven't had any problems. I put a 7.5 A mini fuse into the second slot for the raptor lights and no issues yet. The dash lights flicker sometimes on the temperature/seat heater panel but not sure if it's related to the fuel injector...can't see how that would be the case...any insight to this? Engine runs fine though.
  12. Jun 12, 2018 at 7:35 PM
    #72
    Sullivan0930
    Daniel
    same, except with a 5amp fuse. Smallest i had. I think the issue might come from putting another 10 in there and overloading it, but idk.
  13. Jul 10, 2018 at 3:18 PM
    #73
    808Cementtaco
    808Cementtaco Well-Known Member
    Kea
    2018 trd sport dcsb cement 6sp M/T
    3in front spacer lift with 2in rear block, 17in Ballistic w/285/70r17s 25%tint in front and 15%rear Plastidipped all badges Removed trd stickers Etc.....
    Has anyone tapped into their fog light wires? I’m thinking of just splicing the power wire and just adding in an extended wire for the leds then just tap each power lead from each led into the main wire and all the grounds just ground somewhere on the truck??
  14. Jul 10, 2018 at 6:46 PM
    #74
    plode682
    Southern NJ
    I'm still debating on how to mount these. I currently have two blue emergency lights(for the fire dept) mounted about where the outer two raptor lights would go.
  15. Jul 11, 2018 at 12:08 AM
    #75
    808Cementtaco
    Kea
    Figured out how to tap into your fogs, there’s a clip for them in the center of our front end that travels up the middle. But on the bottom right above the bumper bracket there’s a spot where the fog lights have a plug, and at that spot I opened the conduit and spliced in my leads to my leds. Everything still running cherry but it’s only the first day lol
  16. Jul 15, 2018 at 4:49 PM
    #76
    JDW007
    JDW007 Well-Known Member
    Good info. Thanks!
  17. Jul 16, 2018 at 8:01 AM
    #77
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    Sorry to be replying to an old post, but I'm working on some grill lighting myself and I have a couple questions. I want to do as you suggested and use these connectors to tap wires to power my grill lights, but I see you guys saying to tap the side market lights. Won't that mean that the grill lights will only be on with the parking lights on? I never use the parking lights and I'd really prefer to have the grill lights on with the drls and the low beams, or just all the time. Can you help me understand how to make that work? Thank you
  18. Jul 16, 2018 at 8:12 AM
    #78
    txtaco87
    txtaco87 Budget Travel Hard AF
    Nik
    Houston, Tx
    08 PreRunner DCSB
    PreRun hard AF
    :rofl: Love the custom plate!!
  19. Jul 16, 2018 at 8:14 AM
    #79
    no vtec 4me
    no vtec 4me Well-Known Member
    Kevin
    West Chester, Pa
    2017 Tacoma TRD Sport
    I know you have an sr5 so it’s slightly different. By sidemarker bulb I’m referring to the small bulb under the amber lens on the outside of the truck. This bulb comes on with your marker lights, and stays on with your headlights. It’s only off when only your drl is on. If you want them on with your drl, you can wire it to that. Being that is also your turn signal bulb, I think they will turn off every time you put your turn signal on though.
    Atl_taco_ likes this.
  20. Jul 16, 2018 at 8:52 AM
    #80
    DLRIII
    David
    Baton Rouge
    Ok, that clears it up for me, I do think I want it spliced into the marker light then. Thanks man. Now I just need to find these little wire splice connectors you guys are talking about
